Thread Tools Search this Thread Rating: Thread Rating: 33 votes, 5.00 average. Display Modes
Old 12-12-2008, 10:12 AM   #1
impee
My Ride: BMW 2002 318i SE
Gear & Differential Oil
Hi ppl,
my car (e46 2002 318i) is at 70k miles and i am having the gear and differential oil changed, as many people on this forrum recommened.
I went to BMW and they said they do not sell this oil and i would have to bring it in to have it changed...(they must be joking).
i went to my own mechanic and asked him to change the 2 oils...he just called me and he said the gear and differential have life time oil stickers on them hence he doesnt want to change them.
he has not told me that if i want them changed, i will have to sign a disclaimer that any issues with the gear or differential later on, due to the oil change, will not be his fault.
I am happy with signing that, as i know changing the oil is only going to be a GOOD thing to do...but does anyone have any views regarding this?
thanks.
impee is offline   Reply With Quote
Old 12-12-2008, 10:23 AM   #2
havnfun328
My Ride: '99 328i, '03 M5
I used Redline when I changed mine. I've gone at least 50K since and no probs. Their website will tell you the proper weight to use. I've heard Royal Purple is good too.
2003 E39 M5 Lemans Blue: Truly an amazing car
1999 E46 328i Bone stock 5-speed: Beater and Track Car
250K!!!!!!!!!!!!!!!!!!!
havnfun328 is offline   Reply With Quote
Old 12-12-2008, 01:30 PM   #3
sycE46
My Ride: 323ci
I'm using mobil 1 synthetic. I doubt you really need to change it. Maybe if you had an LSD or something. I don't think that much can go wrong in an open diff (besides having a seal leak)
sycE46 is offline   Reply With Quote
Old 12-12-2008, 08:14 PM   #4
sprintman
My Ride: Ex 325CI owner
Manual or auto trans?
sprintman is offline   Reply With Quote
Old 12-12-2008, 08:18 PM   #5
jeffro3000
My Ride: 2000 328i
i recommend DIY. nothing easier than pulling a fill/drain plug, for the transmission at least. (my rear sway bar blocks one of the diff plugs )
btw, assuming its a manual.
jeffro3000 is offline   Reply With Quote
Old 12-12-2008, 08:48 PM   #6
gregetski
My Ride: 2000 323 Ci, 2007 M
impee
Assuming a manual transmission, the BMW transmission fluid (Pentosin MTF2) is available from Pelican parts. BMW says the fluid lasts for life which may be true but the floating metal flecks don't go away. The first time I did this the bottom of my catch pan looked like Id been panning for steel so I'd be on the side of doing it. The DIY is easy if you've got the tools.
As for the differential (also an easy DIY if you have a stubby hex driver to get by the sway bar) any good 75W-90 gear oil works - I like Royal Purple. This one did not really show any wear when I changed it.
gregetski is offline   Reply With Quote
Old 12-12-2008, 08:55 PM   #7
itscoo2pyopants
My Ride: E53 4.8is
Send a message via AIM to itscoo2pyopants
DIY. i did my fluids at 80k miles and it was smooth as butter. never really had any problems before the fluid change, but after you really notice the difference. i have an auto trans, i dropped the whole pan and put a new filter and new gasket. filled with redline fluid (dont have the weight right now) the diff was straight drain and fill. filled it with the purple stuff i fit about 6 quartz in the trans and 1 quart for the diff (i also used additive) came out to about $100 for all the parts and did it in less than 2 hours. im at 90k now and still running smooth. i plan on doing it every 30k (drain and fill)its too easy not to do it!
itscoo2pyopants is offline   Reply With Quote
Old 12-13-2008, 02:11 AM   #8
Alex D
My Ride: BMW 330 CiC
Just shy of 110K miles now. Did a major service ... oil changes ... cooling system overhaul ... spark plugs and tadaaaa ... UUC short shifter and DSSR ...
At this service I changed the 5-speed to Redline ATF D4 (don't use MTL!! It's too thick) and the rear diff to Redline 75W-80 GL-5 gear oil.
The difference in how much smoother and better the 5-speed shifts (especially when cold!) is UNBELIEVABLE!
2007 335i Convertible - Karmesinrot/Korallrot, 6-speed, Sport, Premium, Cold Weather, i-Drive/Nav w/iPod/Sirius
2008 Infiniti G35S Journey - Obsidian Black/Stone, Premium/Sport Packages
2006 Saab 9-3 2.0T SportCombi - Steel Gray Met./Grey, Sentronic, Premium/Premium-Sound/Cold Weather Packages, Xenons
BMWCCA #407025
My Retired Bimmers:
2001 E46 330CiC
1990 E30 325iC
1982 E28 525iA
1980 E21 320/6
Alex D is offline   Reply With Quote
Old 12-15-2008, 06:05 PM   #9
impee
Gear Oil
an update...my mechanic did finally refuse to change my gear oil (and differential)!
When i went to pick up my car, he said he couldn't find any oil for it and when he spoke to his suppliers, nor could they.
Infact, on the way to my mechanic, my taxi driver also said, don't change the gear oil, you never need to do that, unless major issues with the gear.
I called the Stealership today and they more or less said the same...don't change it if there is no problem and they didn't recommend it either. And if i insisted, they said 235 (155 labour).
Why is no one willing to change it? It is no that I am asking for free work to be carried out?!?!?
I admit there is no major issue with the grear, but its very stiff during a cold morning and isn't as smooth as it used to be when I bought the car about 4 years back.
Old 12-15-2008, 06:32 PM   #10
Alex323Ci
My Ride: M3 & 323Ci (sold)
I used Redline products for my tranny and diff. The dealer usually won't sell the oil as it's in large barrels they buy it in. I've heard of some dealerships selling it as a favor in smaller quantities, but most won't.
Yes, they are both listed as Lifetime fluids as part of BMW marketing claims and more likely due to the maintenence schedule they don't want to do for free. At 70K I'm sure you are fine. But if you decide to do yourself it's not that hard. But will need a handpump to fill it.
Old 12-15-2008, 09:40 PM   #11
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
redline 75w-90 for diff, i have step so cant comment on fluid, but i did both of mine, oh , and find another mechanic
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 12-16-2008, 08:49 AM   #12
strelnikoff
My Ride: 2002 325i
you can get castrol oem fluid from Tischer:
http://www.trademotion.com/partlocat...catalogid=4462
strelnikoff is offline   Reply With Quote
Old 12-16-2008, 09:20 AM   #13
ZHPChas
My Ride: '04 330i ZHP
Originally Posted by impee View Post
Hi ppl,
thanks.
If you have a manual trans, just do it your self with Redline MTL and the diff should be Redline 75 90. It is super easy and will save you a few bucks.
If it is an auto trans, check the threads on that subject as I have heard mixed reviews.
Charles
"The road goes on for ever and the party never ends." - REK
ZHPChas is offline   Reply With Quote
Old 12-16-2008, 10:34 AM   #14
wasp9166
redline d4 for step
Old 02-01-2009, 08:58 AM   #15
impee
Hi All,
As above mentioned by various of you, there does not seem to be a consensus as which Gear Oil I should use. The below 2 are the ones you mentioned.
- RED LINE ATF D4
- RED LINE MTL
Both of these are available at this website:
http://www.opieoils.co.uk/c-415-redl...atfs-mtfs.aspx
...but as my car is 5 Speed, Manual, 2002, 318i, N42, which one does everyone think is the most suitable?
Also, how many bottles would I require? (they appear to come in 0.9 Litre bottles)
many thanks.
For e46 DIYs visit - www.impee.co.uk
Old 02-01-2009, 09:22 AM   #16
kwikt
My Ride: 2003 330i
I just bought the MTL for my 330i 5-speed. I'm changing it today so I can't give you any thumbs up or down yet.
Kevin
kwikt is offline   Reply With Quote
Old 02-01-2009, 10:14 AM   #17
B33MER
My Ride: 330i SMG M-Sport
for manual transmission does it have a gearbox oil filter???
330i SMG M-Sport Paket II Euro Spec
Mods:
CF Roundels all around, Black grillz, 7000k Angel eyes,6300k HID fog lights, Hamman Lip reps, ACS roof spoiler reps, Alutech front and rear struts, BMC CDA with DIY heatshield, Pro RS braided brake line, ///M Billet Oil Cap, OEM ///M mats, ///M aluminium pedals,
B33MER is offline   Reply With Quote
Old 02-01-2009, 10:21 AM   #18
todd92
My Ride: 05 330i ZHP
I use Mobil 1 ATF in the manual transmission and Mobil 1 75W-90 gear oil in the diff. Mobil 1 synthetics are as good as any, readily available, and slightly cheaper than the boutique oils. Nothing wrong with Redline oil, but I don't see any advantage over Mobil 1.
todd92 is online now   Reply With Quote
Old 02-02-2009, 01:16 PM   #19
impee
right, I am about to embark on the gear oil change for my car when the snow clears up. It is a 318i, N42, Manual 5 Speed Gear.
I have more or less everything I need for the oil change, but still am not sure about what torque to use on the the nuts.
1) Can anyone with a similar car / gear and also who may have carried out the DIY please advise?
2) Also, why does the Torgue actually matter? Why not just tighten the nuts, so the oil doesnt leak out?
many thanks.
Old 02-02-2009, 03:30 PM   #20
sprintman
Redline 75W90 in diff, and for hot Florida Redline MTL in manual trans.
