Old 12-14-2008, 12:15 PM   #1
lamaker
My Ride: 2005 325ci
HELP: Service Engine Soon Light On
I started my engine this morning and it was pretty cold in my garage...it took a few more nano-seconds for it to start (more than normal) but it started fine and drives fine...it also happened to me yesterday morning but today the Service Engine Soon light came on...so I drove the car around for a while, turned it off and then started it again and it started as normal...
I am thinking the light came on because since the engine was so cold it took a little longer to get things going..
Any suggestions? How I can check why it came on without going to the dealer?
Thanks!
2005 BMW 325ci/Front Stress Bar/Rear Stress Bar/AFE Stage 2 Intake/Silver Calipers/Siruis Custom Install/AUX Custom Install/Euro Lights/Homelink/Black Out Decals/Angel Eyes
lamaker is offline   Reply With Quote
Old 12-14-2008, 12:25 PM   #2
IxNay
My Ride: 2000 328Ci 5sp SP
First check the easy stuff: is the gas cap on tight? If that is the problem, it will still take a few start/stop cycles before the light goes away.
You can usually get your SES code read for free at an Autozone type place.
Jeff
IxNay is offline   Reply With Quote
Old 12-14-2008, 12:27 PM   #3
boxtyp3
My Ride: Hellrot
You might be right about too cold. But Im not too sure about it since Im from Norcal.I think the first thing to do is pull out the error code(s) and we'll go from there.
boxtyp3 is offline   Reply With Quote
Old 12-14-2008, 12:45 PM   #4
e46vert
My Ride: 330ci
my car did the same thing. run the error code and its p1345 misfire cylinder 5. I change all 6 spark plug and have the shop turn off the ses light. so far the light is gone so hopefully it wont come back on. Check your spark plug....
e46vert is offline   Reply With Quote
Old 12-14-2008, 02:15 PM   #5
lamaker
My Ride: 2005 325ci
Thanks for the suggestions...I will go to Advance Auto Parts today to see if they can read the code....as for the spark plugs, I recently (within 30 days) changed them so I hope that is not it...will keep you all updated...thanks again...
Old 01-07-2009, 11:54 AM   #6
supratter
My Ride: 2001 330i
any updates? it was cold this morning and my engine light came on as well, searching around for code pulling tips now...
supratter is offline   Reply With Quote
Old 01-07-2009, 01:35 PM   #7
ken@bimmertools
Is NOT A Mechanic
ken@bimmertools's Avatar
My Ride: F30
Please read the article linked in my signature titled "Is your check engine light on?"
Lots of good info in there.
Good luck!
Ken
Bimmertools is under new ownership! Please welcome Taylor@bimmertools.com.
Click Here to say hi.
ken@bimmertools is offline   Reply With Quote
Old 01-07-2009, 01:39 PM   #8
TKC
My Ride: 330cic & R6
Send a message via AIM to TKC
Your car is not going to tell you to check engine just cause it's cold outside
The only thing it does is the on board computer on the dash will beep and flash the temp to alert you that it's below 37 degrees F and beware icy conditions.
If your SES light is on, just go rent a code reader and find out what codes it's throwing!
EUROPROJEKTZ - Director, NorCal Chapter
TKC is offline   Reply With Quote
engine, light, service
