Old 12-14-2008, 12:59 PM   #1
strelnikoff
My Ride: 2002 325i
Very weird idle issue!
Only happens at speeds of 20-40 mph and car is coming to a stop (foot off the gas pedal). The idle will fluctuate between 800-1000 rpm. Seems to happen only when the car is wormed up (about 5 mins into driving). Now here is the kicker: it does not happen when the A/C is ON! With the A/C ON, the idle speed does not fluctuate in that speed range. This weekend I replaced oil separator (CCV) + separator vacuum hoses. I have also cleaned the icv and throttle body. Need help, this is driving me nuts!!
strelnikoff is offline   Reply With Quote
Old 12-15-2008, 02:52 PM   #2
strelnikoff
My Ride: 2002 325i
bump
Old 04-23-2009, 10:29 PM   #3
strelnikoff
My Ride: 2002 325i
Turned out to be vanos oil pressure hose. there was a vacuum leak where the hose was crimped at the factory. replaced the hose this past weekend. the easiest way to get to the lower part of the hose is from under the car.
hope this info helps somebody
Old 04-23-2009, 11:36 PM   #4
dh0licious
My Ride: '00 325i
Thanks for the update dude. Can I grab the part number?
dh0licious is offline   Reply With Quote
Old 04-24-2009, 09:14 PM   #5
strelnikoff
My Ride: 2002 325i
the part # for the pressure hose is 11-36-1-705-532. you also have to use four new crush washers # 32-41-1-093-596. to get better access to the hose remove the filter box/maf sensor assembly. all in all a very easy job.
Old 04-25-2009, 02:04 AM   #6
dh0licious
My Ride: '00 325i
Good man, thanks for your help.
Old 04-25-2009, 02:32 AM   #7
vids_blk323Ci
DFW
My Ride: JB 323Ci SP PP
Send a message via AIM to vids_blk323Ci
do you know if the car was throwing a code via SES light?
Dinan Stage I S/W | ACS RSB | ///M FSB |UUC TMEs & Pulleys |Ate Slotted Discs | ScanGuageII | RockyMounts MTB Carrrier | OEM Rear Clears | LED Euro City Lights & Rear Fogs | Two-Tone Suede DIY | ACS Pedals | Bimmian Gauge Rings & M3 Face | Smoked Frnt Corners w/ Luxeon LEDs | EAS CF Roundels | JLevi Ti CF trim | Blk Suede shift/ e-brake boots | ECS Smoked Frnt Bumper Reflectors | DICE Duo
vids_blk323Ci is offline   Reply With Quote
Old 04-25-2009, 02:07 PM   #8
strelnikoff
My Ride: 2002 325i
no, it didn't throw any codes...
erratic, idle
