Old 12-15-2008, 07:02 PM   #1
Bimmerboii
My Ride: is refreshed
no start, bogging down, and Code
i have an 01 325ci 5speed
first sometimes when i go to start the car, it dosent turn over, like no power is going to the starter. all the lights come on in the dash and there is no ticking, like the starter would be engaging. sometimes i lock the car then i unlock it then it would start, also sometimes i would pump the clutch pedal, and other times i would just turn the key back and forth and after a while it would start. this is not in the morning it occurs at any time during the day!
the second thing would be, when my wheels start spinning on a slippery wet road, when i would give it gas to countinue the so call burn out the car would bog down around 3500rpm ( with traction control off)?
finally i have the code P0171 System too Lean (Bank 1), is this my oxygen sensor? if not then what could it be and what do i need to change to fix it!
thanx you jason
01 325Ci Black | Caught On Fire
01 325i Silver | Muffler Delete | 3.46 Diff | White Halo's | H&R Sport Springs | OEM Style 67 | 15mm Spacers | Smoked Corners |
Bimmerboii is offline   Reply With Quote
Old 12-17-2008, 09:33 PM   #2
Bimmerboii
any one im sure someone knows at least one solution!
