Old 12-16-2008, 05:50 PM   #1
InterlagosMcoupe
My Ride: M coupe
Where to tap for il temp sensor.
Where do most people tap for oil temperature? I can't figure out a good place to tap in the pan for a probe. I was thinking off the drain plug hole but cant find an m12 elbow to make use.
InterlagosMcoupe is offline   Reply With Quote
Old 12-16-2008, 07:08 PM   #2
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Im sure someone online sells it. Have you looked into AN fittings? They make pretty much every size.
-Charles@VMRWheels
www.vmrwheels.com
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 12-16-2008, 08:30 PM   #3
InterlagosMcoupe
My Ride: M coupe
I'm not sure how that helps me get a temp senor into the oil pan.
Old 12-16-2008, 08:51 PM   #4
VMRWheels
VMRWheels's Avatar
Ok i think i might have misread what you wrote. So the temp sensor bolt does not fit into the pan? is that the problem?
-Charles@VMRWheels
www.vmrwheels.com
Old 12-17-2008, 09:37 AM   #5
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
You can try this.
http://leatherz.com/Merchant5/mercha...ry_Code=Gauges
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 12-17-2008, 11:11 AM   #6
InterlagosMcoupe
My Ride: M coupe
-Charles@VMRWheels
www.vmrwheels.com
Wait what are you talking about, the bolt is not meant to just fit into the pan, you have to tap for it.
Originally Posted by bigjae1976 View Post
That's for the oil filter housing.
Old 12-18-2008, 12:30 PM   #7
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
TMS has a mounting kit that replaces the oil level sensor with a bung for a temp sensor.
The best place to have an oil temp sensor is after the oil pump just before the oil goes into the main oil galley...but this isn't easily done.
Old 12-19-2008, 12:21 PM   #8
InterlagosMcoupe
My Ride: M coupe
I'm thinking about trying to put a T fitting on the oil return (from head) line that's at the front of the rear of the pan.
Only problem I'm thinking right now is that theres no clearance to screw a t fitting in <_< (would hit the oil pan as you turn it around)
Old 12-19-2008, 03:57 PM   #9
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
I feel like an idiot. You have an M-coupe which should have an oil cooler mounted which you can tap into those lines.
The oil drain-back line on the side of the head doesn't flow oil the way you think. It's more of a crankcase pressure balancing system...in other words there's more air than oil passing through there.
Old 12-19-2008, 06:16 PM   #10
InterlagosMcoupe
My Ride: M coupe
Id rather not tap the oil cooler lines.... more importantly, I don't think you could anyway.
Also, its a drain and there's really nothing passing through it, just some oil dribbling down from the head, but it ends at the bottom of the oil pan which means there is always oil at the bottom of the line from the oil pan.
The crankcase pressure equalizes through other passageways.
Old 12-28-2008, 12:56 AM   #11
bluejeansonfire
ninja editor
My Ride: m5xual
Send a message via AIM to bluejeansonfire
what's wrong with the factory s54 oil temp sensor? i know the m3 gets a gauge, does the s54 in the z4 get left out? Is the factory sender mounted in a poor position? I don't think bmw is dumb enough to buffer that gauge.
01 330cit-92 s13c-99 328i/5-04 x5/6
bluejeansonfire is offline   Reply With Quote
Old 01-01-2009, 04:09 PM   #12
Mr Paddle.Shift
Mr Paddle.Shift's Avatar
My Ride: B3 epsilon
I designed an adapter for the drain plug on my setup since my oil temp sensor is a little different.
What's the thread size of your sensor? Metric, NPT ?
Technik Engineering ASA Stage 1.
Supercharged E46 M54B25.
2011 NASA TTC So Cal Champion!
Track blog.
Technik Engineering oil cap o-ring maintenance kit available.
Mr Paddle.Shift is offline   Reply With Quote
