Old 12-16-2008, 10:25 PM   #1
ashleydean
My Ride: E46 325CI
Window problems - 2006 E46 325CI convertible
I have had constant problems with my electric windows in my 325CI convertible.
When I press the centre "ALL UP" button, to raise all 4 windows, amny times only 3 windows will raise up, and 1 will stay down.
Also, when I press the driver window to go up automatically, often the window will go up 3/4 of the way, then drop back down.
BMW have tried 10 times to try and fix these problems, changed the window regulators etc. Now they have given up, and said it is a "Safety Feature" anti-trap feature, that my windows dont work properly.
If anyone else has had similar problems, please email me at ashleydean@dodo.com.au, as I am taking legal action action BMW as they cant fix the problem.BMW claim they have never ever heard of this before, but I know of other people with the same car that also have this problem.
Regards
Ashley Dean
ashleydean is offline   Reply With Quote
Old 12-16-2008, 10:28 PM   #2
ashleydean
My Ride: E46 325CI
Electric Window problems - 2006 E46 325CI convertible
Regards
Ashley Dean
Old 12-16-2008, 10:50 PM   #3
TKC
My Ride: 330cic & R6
Send a message via AIM to TKC
I've never heard of this as a common problem, and I surf this board a lot and do a lot of DIYs.
Have you tried resetting your auto ups?
EUROPROJEKTZ - Director, NorCal Chapter
TKC is offline   Reply With Quote
Old 12-16-2008, 11:26 PM   #4
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
when this happened on a few infiniti's i worked on the window motor fixed it. i've done one or 2 in e46's. did they try replacing the window motor and reprogramming the window? i hope they did since u took it to the dealership. seems like the range of your driver window motor needs to be readjusted
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 12-16-2008, 11:31 PM   #5
JK1150
My Ride: 2004 325CI
the window going 3/4s up and back down is usually a sign of it hitting something or becoming caught. for example if it is off-track. that's unusual it only happens when u do the auto up though.
JK1150 is offline   Reply With Quote
Old 12-16-2008, 11:34 PM   #6
aw3964
My Ride: 02 325ci; 06 530i
it happens in my coupe with the moonroof, as stated above its usually because it is off-track. it would close then reopen to 3/4. i usually just hold the close button for 10secs and wait for it to reset. as for the windows, have they looked at the tracks? maybe they are just dirty..
aw3964 is offline   Reply With Quote
Old 12-17-2008, 06:35 PM   #7
ashleydean
My Ride: E46 325CI
yes, its always when going up. It usually happens in hot weather.
BMW has tried 10 times to fix it, changed motors etc but still the problem happens. They have given up on it now!
Old 12-17-2008, 06:39 PM   #8
Team_Persia
My Ride: '05 ZHP 'Vert - SOLD
i sometimes have the same issue with 1 of my windows staying down.
it also does the 3/4 up and then down thing sometimes when im rolling them up and then turn off the ignition.
anyone have any clue to why it does this?
-Amir
Team_Persia is offline   Reply With Quote
Old 12-17-2008, 07:22 PM   #9
ashleydean
My Ride: E46 325CI
BMW says they have tried everything. They have had the car for 6 weeks trying to fix it! It is totally random when it happens which is frustrating, because the car can be fine for 2 weeks, then next 2 weeks every time I go to use the windows or put on the roof and all windows should go up, one window will stay down
Old 12-18-2008, 10:37 AM   #10
JK1150
My Ride: 2004 325CI
I think this is actually a feature or something. Happens now and then on my coupe too. If you only hold the close for a bit it'll close only 3/4ths the way, then stop and go back a bit and stay at 3/4ths open...
Old 01-27-2009, 10:51 PM   #11
ashleydean
My Ride: E46 325CI
do you know of anyone else that has same problem? How frequently does this happen to you?
Old 01-28-2009, 02:23 AM   #12
mthreezycrazy
My Ride: ///M3
my buddy's convertible does all sorts of this wacky sh!t, he said its just a "common problem" with verts, so i guess it is
-Aria
mthreezycrazy is offline   Reply With Quote
Old 01-28-2009, 11:48 AM   #13
Team_Persia
^lol thats me
-Amir
