Thread Tools Search this Thread Rating: Thread Rating: 85 votes, 5.00 average. Display Modes
Old 07-21-2013, 08:23 AM   #201
Sansho
My Ride: 2001 325i
Silicone lube/paste is great stuff, however, I no longer use it on o-rings that seal against antifreeze. One time I used silicone paste on a VW thermostat o-ring, and it wouldn't seal properly and leaked. So I stick with antifreeze as a lube on the water pump o-ring, which works fine.
Sansho is offline   Reply With Quote
Old 07-21-2013, 08:47 AM   #202
Chris3Duke
Originally Posted by Sansho View Post
O-ring is the only "gasket" on an e46, as I recall. For o-ring lubricant I've used antifreeze mixture.
This is what I did. Had no problem.
Chris3Duke is offline   Reply With Quote
Old 07-21-2013, 11:13 AM   #203
jrrwired
My Ride: 2001 BMW 330CI
Re: DIY: Stewart Water Pump + Expansion Tank + Coolant Change + 2 Tensioner Pullies
Replaced my control arm bushings. Eliminated the shudder I was feeling and stiffened up the steering. Click image for larger version
ID:	517623Click image for larger version
ID:	517624Click image for larger version
Sent from my HTC ONE using BimmerApp mobile app
jrrwired is offline   Reply With Quote
Old 07-21-2013, 01:00 PM   #204
Sansho
My Ride: 2001 325i
That's great, however, how does that relate in this post that covers cooling system components? Maybe posted to the wrong thread?
Old 11-01-2013, 07:44 PM   #205
mgzzcool
My Ride: 01' 325XI
Just finished replacing the expansion tank and thermostat...the longest part was getting the expansion tank off...what a pain...till you figure it out. I opted to take the tank holder out too..as the bottom was stuck pretty good and i didn't want to break it. Flat head to pull up the tab on the holder and out it all came. Bottom heater return and electrical connector had to be removed. Hope that helps....
mgzzcool is offline   Reply With Quote
Old 11-02-2013, 03:06 AM   #206
saturn
My Ride: 525i
mgzzcool, what lubricant did you use on the thermostat gasket? Although it has been answered, and I have tried using Antifreeze twice on my thermostat gasket, but it still leaks. So, would appreciate your response.
saturn is offline   Reply With Quote
Old 11-02-2013, 12:32 PM   #207
Stinger9
My Ride: '04 330Ci
Unless using gasket sealer, use Silicone O-ring lube. Makes your life so much easier and a tube will last for many years.
This stuff is great: http://www.agscompany.com/lubricants/automotive/168
Old 11-02-2013, 02:05 PM   #208
hitbyastick
My Ride: 2002 325i
Silicone grease works better than coolant for lubing the cooling system o-rings. A little goes a long way.
hitbyastick is offline   Reply With Quote
Old 07-26-2015, 01:16 PM   #209
kcult
My Ride: 99 323i, 04 ZHP
I've changed out a busted expansion tank on a manual before, but I'm trying to change a cracked tank on an auto and had a question.
In the picture, the sliver box thing (I'll learn the name of it later) is sort of in the way. I haven't attempted to disconnect the level sensor or the pull the disconnect for the tank yet, but was curious if this silver thing needed to be removed just to remove the tank or does it stay as long as I can reach the sensor and disconnect?
kcult is offline   Reply With Quote
Old 07-26-2015, 01:36 PM   #210
kcult
One more question, Do I have to remove the fan just to get this out or is it just easier if I did?
Old 07-26-2015, 04:50 PM   #211
kcult
Update:
I did not have to take the fan out. It would have been easier with it out, but wasn't too difficult.
The new tank and thermostat should be here tomorrow.
coolant, expansion, stewart, tensioner, water pump
