Thread Tools Search this Thread Rating: Thread Rating: 85 votes, 5.00 average. Display Modes
Old 01-01-2009, 06:30 PM   #21
DiceyOne
My Ride: 1999 328i
Send a message via AIM to DiceyOne
excellent DIY, paraklas. I plan on doing this in the spring as some preventative maintenance. I will no doubt be referring to this thread as a guide.
DiceyOne is offline   Reply With Quote
Old 01-02-2009, 05:11 PM   #22
paraklas
My Ride: ESS TS2 320ci
And in case somebody is wondering what sound a faulty wp does, here it is (notice the hishhhhh hishhhhh hishhhhh):
Old 01-02-2009, 05:19 PM   #23
itscoo2pyopants
My Ride: E53 4.8is
Send a message via AIM to itscoo2pyopants
^ how many miles before you started hearing that from your pump? i want to get the stewart pump but dont want to if i dont have to.
itscoo2pyopants is offline   Reply With Quote
Old 01-02-2009, 05:54 PM   #24
paraklas
Around 40K miles
Old 01-03-2009, 01:17 PM   #25
itscoo2pyopants
My Ride: E53 4.8is
wow i got 90k, probably should replace it.
Old 01-03-2009, 04:02 PM   #26
danlauz
My Ride: 330 cic + X5
thanks
take note I must change the tires when the car return to the road as after 4 years, thet are all cracked on the edge. (did not run enough) goodyear gsd3.
danlauz is offline   Reply With Quote
Old 01-04-2009, 08:59 PM   #27
jabast09
My Ride: 330ci, 9114S
Quick question - thermostat
Paraklas: Awesome DYI!
I have a quick question...while removing the expansion tank I broke the thermostat plastic...I just ordered the part, however, it seems that there is still a piece of the old thermostat plastic where the expansion tank connects from the bottom...can you let me know how to remove it?
thanks!!!
jabast09 is offline   Reply With Quote
Old 01-05-2009, 05:31 AM   #28
paraklas
Can you post a pic of what you are refering into? The thermostat is not connected to the bottom part of the exp.tank.
Old 01-05-2009, 06:37 AM   #29
SaaDiesel
My Ride: 02 330i Tech 1
This is going to help me SO much come springtime, thanks for a great writeup.
E46-7 years STRONG
ZSP/ZPP/ZCW
BFP Intake, Euro Cooling Ducts, OEM Clear Lenses, 8000K HIDS
Matte Black-Grill, Headlight, Window, & Body Trim
SaaDiesel is offline   Reply With Quote
Old 01-05-2009, 08:58 AM   #30
DiceyOne
My Ride: 1999 328i
he probably has an auto. there is a small thermostat that leads to the trans.
Old 01-05-2009, 10:14 AM   #31
jabast09
Here are the pics....
The red rectangle on picture one (pretty faint) shows where the piece (in picture two) broke off. Picture 2 shows what seems to be a thermostat and a spring...your help is very appreciated...
ID:	297503   Click image for larger version
Old 01-05-2009, 04:33 PM   #32
jabast09
Unhappy more information
Gents,
Attached a picture on how the thermostat used to go. I was able to place it back but it does not feel real secure (it will surely come off with regular driving). So, given that the part is broken (both the plastic on the thermostat and on the mounting plate - I believe that is the plastic part that holds the thermostat and also the expansion tank, # 1 on the following diagram:
http://www.realoem.com/bmw/showparts...41&hg=17&fg=05 - do I have to also replace the mounting plate?
That seems like a JOB....and will probably require for me to take the radiator completely out...any of you done this?
thanks for your help!
Old 01-06-2009, 04:47 PM   #33
DMan328
My Ride: 2001 330i ZSP
This is quite possibly the best write-up that I have ever seen.
DMan328 is offline   Reply With Quote
Old 01-07-2009, 06:05 PM   #34
LSUKNUT
My Ride: 330i
Great write up Paraklas!
I start first thing tomorrow morning. Stewart water pump, new UUC under pulleys & belt, thermostat, belt tensioner and new hoses. Should be quite a day.
KNUT's Progress & Thank You to E46Fanatics Supporting Vendors - http://forum.e46fanatics.com/showthr...=1#post9933726
LSUKNUT is offline   Reply With Quote
Old 01-08-2009, 04:44 AM   #35
paraklas
No idea as I don't have an auto and therefore these parts are not in my car.
Good luck!
Old 01-08-2009, 12:29 PM   #36
tony325ci_51
My Ride: BMW 335i 2007 Coupe
nice work
tony325ci_51 is offline   Reply With Quote
Old 01-08-2009, 02:08 PM   #37
dreamdrivedrift
My Ride: 99 M3 & 95 325i
Send a message via AIM to dreamdrivedrift
3. Go below car and remove expansion tank drain plug (blue) and let the coolant drain in a bucket. Do not allow pets in the area, coolant is sweet and if your dog drinks it, he will die.
great DIY.
Chris
dreamdrivedrift is offline   Reply With Quote
Old 01-09-2009, 09:16 PM   #38
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
nice writeup
phamine is offline   Reply With Quote
Old 01-13-2009, 06:26 PM   #39
paraklas
Thermostat housing is leaking now. Anybody knows if it's repairable using gasket silicone (like the one used for valve cover gasket) or do I need to change the entire unit.
Old 01-13-2009, 06:46 PM   #40
LSUKNUT
My Ride: 330i
Why you asking us? You wrote this DIY so you're supposed to be the expert.
BTW - Great DIY Paraklas! I followed it almost point for point except the fact I have an automatic and besides installing the Stewart water pump, thermostat, expansion tank, belt tensioner, new hoses and belts I was also installing a new under pulley system. Couldn't have done it without your great write up. Thanks....
coolant, expansion, stewart, tensioner, water pump
