Thread Tools Search this Thread Rating: Thread Rating: 85 votes, 5.00 average. Display Modes
Old 08-05-2012, 10:29 PM   #161
Stinger9
My Ride: '04 330Ci
Seen this DIY yet: http://www.pelicanparts.com/BMW/tech...lant-Flush.htm
Pic of coolant drain plug here too
Name:	Coolant Drain.jpg
ID:	463762   Click image for larger version
Name:	Coolant Block.jpg
Old 08-06-2012, 12:25 AM   #162
Steven747
My Ride: 05 330ci
hmm bad angle sort of looks like the block drain plug. thankfully i have headers so i can actually remove it from the top
Old 08-06-2012, 01:37 AM   #163
Stinger9
My Ride: '04 330Ci
Did it from underneath on my Ci without too much drama. Only thing I can remember is that it required some wrist strength. No room to use arm strength.
How in the world do you have headers in CA and pass inspection?
Would be interested to know if that's legal?
Old 08-06-2012, 12:46 PM   #164
fanatic128
My Ride: 2005 330i
Isn't this DYI just a drain and not really a flush? I would consider a flush running the system under pressure with some type of cleaner or something. I would think we would need some type of special equipment for this. I guess what I'm asking is do I need to backflush it or just drain and filll fine?
fanatic128 is offline   Reply With Quote
Old 08-06-2012, 03:02 PM   #165
YOnpds
My Ride: E46
Great DIY OP. Thanks!!!
YOnpds is offline   Reply With Quote
Old 08-06-2012, 03:31 PM   #166
fanatic128
My Ride: 2005 330i
One of the links above mentions" The BMW 3-Series six cylinder engines will hold just shy of 3 gallons (10.5 liters)" yet this write has a parts requirement of just 4L oem 4L distilled water. How much do I need if I'm draining engine block too?
http://www.pelicanparts.com/BMW/tech...lant-Flush.htm mentions 10.5
also, is it worth adding this ? Red Line Water Wetter
Old 08-07-2012, 01:39 AM   #167
Stinger9
My Ride: '04 330Ci
Do your coolant changes regularly and forget the water wetter.
System holds just over two gallons total
Old 08-07-2012, 08:07 AM   #168
paraklas
My Ride: ESS TS2 320ci
Filling capacities as per manual attached
Old 08-07-2012, 08:10 AM   #169
fanatic128
My Ride: 2005 330i
Thanks.. Going to do it this weekend. Really getting into this fixed my oil housing gasket myself. The Power steering return hose was leaking and I fixed that. Did my brakes. Starting to become a hobby. Still debating to do transmission or not because I keep getting mixed reviews about how changing it could cause problems since my car has 105K miles and it's never been changed. I don't want to open up a can of worms. I called several BMW and they said the texaco ATF last 250K which I believe is not available anymore and if I do change it , it could cause failures and I would going forward have to change every 30K. I don't know who to believe.
Old 08-07-2012, 02:27 PM   #170
paraklas
I did the first transmission change at 70k miles, with Redline MTL. Ultra smooth shifts for a year or so. Second change was with OEM BMW MTL-LT-02 which I didn't like so much because of the effort required to shift specially when gearbox was cold. So my next change will be again with Redline again
Old 08-07-2012, 07:03 PM   #171
Steven747
My Ride: 05 330ci
Yeah it's illegal but no problems yet and I drive about. 80 miles a day mixed city and highway
Old 08-07-2012, 10:17 PM   #172
Stinger9
My Ride: '04 330Ci
Originally Posted by fanatic128 View Post
Starting to become a hobby. Join the club! That's what most of us here do!
If you intend to keep this car a while, I'd strongly consider doing your fluid change. It's still young enough so no damage is done, and you'll then be operating with as little incremental wear as possible from now on.
And if you change fluid, you'll certainly not be obligated to change frequently into the future. Use the best quality fluid you can find.
Old 08-08-2012, 08:57 AM   #173
fanatic128
My Ride: 2005 330i
Which Fluid do you recommend? Should I stick with what bavarian auto has to offer?
See below
which fluid to you recommend?
Well , BMW says I have a GM trans yet guy at Bavarian said I can use the ZF lifeguard. Do you guys agree? One DYI guys used Mobil dexron VI would this be a better choice?
went with Liqui Moly Top Tec 1200 Automatic
Old 10-29-2012, 02:12 PM   #174
jrrwired
My Ride: 2001 BMW 330CI
I'm doing the same thing to my car. Do I install the Stewart pump with the open slot facing up, or down? (Since the old one was open on all sides, I'm not sure if it matters - but thought I'd ask anyways.)
jrrwired is offline   Reply With Quote
Old 10-29-2012, 02:18 PM   #175
Sansho
My Ride: 2001 325i
I don't think you have a choice on which way to mount it, based on where the 4 bolts line up.
Sansho is offline   Reply With Quote
Old 10-29-2012, 03:03 PM   #176
Stinger9
My Ride: '04 330Ci
+1
Bolts are not symmetrically arranged.
Only goes in one way.
Old 11-10-2012, 10:34 AM   #177
nzvlnr
My Ride: 2005 325i
When you put the pump back in , there is no use of sealant? Do you put a little coolant on the rubber seal prior to the new pump install?
nzvlnr is offline   Reply With Quote
Old 11-10-2012, 10:46 AM   #178
Stinger9
My Ride: '04 330Ci
Definitely use some lube on that O-ring!
Mistake to put it in dry.
I like silicone O-ring lube, but most use coolant.
Old 11-10-2012, 12:06 PM   #179
Sansho
My Ride: 2001 325i
Use coolant, as recommended by BMW.
Old 11-13-2012, 12:16 PM   #180
nzvlnr
My Ride: 2005 325i
what is a good brand for replacement on the clutch fan? I cannot find a behr replacement part that is local. Should the pulley be replaced as well, I am thinking yes with all that I have read?
coolant, expansion, stewart, tensioner, water pump
