Old 12-23-2008, 07:56 AM   #1
ATF
My Ride: plows snow.
Torque specs for Coils & Plugs
Morning all,
In preparation for doing my spark plugs today I decided to re-familiarize myself with the torque specs for the spark plugs. It came to my attention that the older E46's coil is actually bolted into place. Does anyone have the torque spec for these? I've also found some conflicting torque specs for the plugs as well.
For safety's sake I'm just going to torque both to 18 ft-lbs. I don't have a Bentley manual, if someone could chime in with the proper torque specs that'd be much appreciated.
TIA,
Nick
ATF is offline   Reply With Quote
Old 12-23-2008, 08:16 AM   #2
paraklas
My Ride: ESS TS2 320ci
18-20 Nm for Spark plugs. The older coils which are bolted in place do not require any excessive torque.
Old 12-23-2008, 02:28 PM   #3
ssm1991
My Ride: 2004 325i
For the spark plugs, Bentley calls for 25 Nm while TIS shows 30 Nm. So it's 18-22 ft-lbs, not Nm. I use 20 ft-lbs.
For the ignition coil bolts, they're size M6, so use 10 Nm (7.5 ft-lb). The smaller the bolt the lower the torque needed.
ssm1991 is offline   Reply With Quote
Old 12-23-2008, 05:12 PM   #4
paraklas
The spark plug box (OEM NGK) said 20Nm iirc.
Old 12-23-2008, 06:56 PM   #5
ssm1991
My Ride: 2004 325i
From www.ngksparkplugs.com:
Flat seat type (with gasket), 14 mm thread diameter, aluminum cylinder head:
18.0~21.6 lb-ft.
Old 12-23-2008, 07:03 PM   #6
reynaldo
My Ride: 2001 325i Sedan
Send a message via Yahoo to reynaldo
I did mine last week and never used the torque although I have one that goes from 5-80 ftlbs. I just tighten it with hand and a quarter tight. Well I replaced my coil and boots at the same time with bremi.
reynaldo is offline   Reply With Quote
