Angel Eyes, DDEs, lighted rings, Clear Turn Signals, LEDs, Xenon, HID, or Bi-Xenon. If it lights up and you want to discuss it, post here! |
#1 |
2001 BMW 330ci Coupe LED Tail Lights
I am in the process of compeletely rebuilding/modifying a previously neglected 2001 330ci coupe, and have a set of DEPO LED Tail Lights that will be going on after the body work. My question is, I have read many posts and comments about needing resistors and/or an LCM Reflash once the LED sets are installed for many 2002 models, but have not been able to isolate exactly what I need to do to make these work correctly with my 2001, so there are not blinking issues or Tail Light-Out Indicators present. Does anyone know for sure? I have extensive experience with electronics installations (over 10 years), so feel free to be as technical as needed.
#2 |
My Ride: 2001 AW 330Ci
You will need resistors and capacitors. I saw a very good and technical write up by an EE who was able to fix the issue. Off the top of my head I think you will need three (Stop,parking,turn) ~6ohm 50w resistors for each tail and caps too. It will require some work. I'll try to find the info.
![]() Headers - KW V2 - Hotchkis Sways - 55w 6000k HID - 35w 6000k HID fogs EVO 3 SSK mit ein DSSR - EE Tails - Meyle LCA, FCAB, & RTAB w/ Rogue Limiters - M3 Mounts .... -Paul BSME Last edited by KriTiKaL AspecT; 12-24-2008 at 03:09 PM. |
#3 |
did you buy them recently? if so, you should be fine. the newer ones have fixed most of the warnings issues. the reflash only applies to OEM LED tails.
Have a lighting problem? Read this first: Lighting-related Troubleshooting Guide |
#4 |
_
Like said above, the newer build tails have been "updated" and should work.
You wont know 100% until you plug them in and fire them up--no need to fully install them to know.
#5 |
1.888.JLEVISW
You may have trouble with the DEPO versions as their resistor setups were not compatible with all cars so some cars got bulb out warnings.
#6 |
Okay, thanks everyone. I suppose I will pick this back up if I have issues after I put them in once the body work is done. I was just seeing if someone knew the exact impedance the tail light monitors look for and if needed, which capacitors may be required to prevent blinking/flickering issues, so I could be prepared in advance. Thanks again!
#7 |
1.888.JLEVISW
Mike,
I did a write up about the install for the Eagle Eyes LEDs we carry. It's plug and play and could not be easier. http://forum.e46fanatics.com/showthr...&highlight=LED |
#8 |
I purchased these taillights for my coupe last year, and just recently within the week only on the right hand side on the turn signal section I have led's going out one by one. I only have 6 led's left Im not sure as to why this is happening. Maybe the resistor is going bad? or just a defective part within the unit.
how would someone go as to buy the proper led's to replace the bad ones or get a new resistor. Im wondering if replacing the led's is possible at all or its just one fixed unit. |
#9 |
you can wire multiple LEDs and use one resistor. usually it's like 4 LEDs in the row maximum (dependent on the LED used). you just need the specs of the LEDs and some math to figure out what size resistor you need.
| Tags |
| led, led tail lights, led taillights, tail lights, taillights |
