///M3 Forum
Old 12-25-2008, 10:40 PM   #1
TARLASHA
My Ride: bmw m3
how much psi should be in 19" tires
Hello guys need help , would like to find out what psi should be in 19" tires .I have toyo t1r 235x35x19 front , and 275x30x19 rear some people saying
35psi other 40psi.?????
k&n cold air intake 57,race exhaust eisenman section1,2, and rear mufler shark injector, i forged aero high polish 19x8,5 front 19x10 rear 2,5 " lip front and 4" lip rear,full bilstein pss10 coilover suspension.Invisible bra front,sides,mirrows and rear bumper.Chicago pkg, umnitza angel eyes 62 led.Interior LED kit and plates
TARLASHA is offline   Reply With Quote
Old 12-25-2008, 10:50 PM   #2
FromE55toM5
FromE55toM5's Avatar
My Ride: 6spd E60 ///M5
35psi all arround
Previous Whips:
330ci | ///M3 | E55
FromE55toM5 is offline   Reply With Quote
Old 12-26-2008, 12:18 AM   #3
jmrcracer
My Ride: Topaz M3 2002
read the side of the tire it will tell you min and max then just go in the middle not for nuthin it should be around 35ish anyway
front lip, gtr hood, roof, csl trunk. SSR SP1's in 19"
jmrcracer is offline   Reply With Quote
Old 12-26-2008, 09:56 AM   #4
trympower
My Ride: 2001 m3 convertible
actually you are suppose to look in the door jam on the sticker that gives you the size of the tires your car came with from factory and the set psi for the tires front and back.this is what the tires are set at for all factory tests.
trympower is offline   Reply With Quote
Old 12-26-2008, 10:12 AM   #5
DeutschlandATL
My Ride: 2005 M3 Coupe
Yeah, 41 in the front, 48 in the back....
2005 BMW M3 Coupe - Stock
2000 Audi A6 2.7T Quattro - Not
DeutschlandATL is offline   Reply With Quote
Old 12-26-2008, 10:31 AM   #6
///M3Turk
My Ride: M6 ,X5, R6, M5, M3
Send a message via AIM to ///M3Turk Send a message via MSN to ///M3Turk
+1
Firat
///M3Turk is offline   Reply With Quote
Old 12-26-2008, 10:33 AM   #7
GreekLSBm3
My Ride: drops panties
actually that's with stock wheels and tires setup which OP isn't using. 35-40 psi is fine not like your going to see any big difference with either anyway. I run 38ish all around
360 Gamertag - GreekM3
GreekLSBm3 is offline   Reply With Quote
Old 12-26-2008, 10:34 AM   #8
SteveX82
My Ride: 2001 325i
Tires do not list a minimum air pressure....
SteveX82 is offline   Reply With Quote
Old 12-26-2008, 12:53 PM   #9
jagLacs
My Ride: M3
I have the same wheel setup with Nittos and i run 36psi all round.
jagLacs is offline   Reply With Quote
Old 12-26-2008, 01:08 PM   #10
vision_promo
My Ride: M3
I usually run 35-38ish.
.45.hwf.HH.
vision_promo is offline   Reply With Quote
Old 12-26-2008, 01:11 PM   #11
tblue3cibm
My Ride: allroad / Hayabusa
i run 79 psi front and 85 psi rear
tblue3cibm is offline   Reply With Quote
Old 12-26-2008, 01:17 PM   #12
DropTopKingM3
My Ride: All German
Brooklyn potholes will make you do things like that
..George..
..Is now Alpine White/Cinnamon...
^Don't say my car is topless, say the t!tties is out^
DropTopKingM3 is offline   Reply With Quote
Old 12-27-2008, 12:02 PM   #13
ejhlb
My Ride: 2003 ///M3 coupe
i have the same tires,same size,same problem...
i used to go on 35 but then noticed the sides of the tire were so close to earth and were not protected,and it actually cost me a rear tire
i went for 40,they are still down,but the ride feels more comfortable,and steers better
im planning to go for 45 and will let u know the result
ejhlb is offline   Reply With Quote
Old 12-31-2008, 01:30 AM   #14
e46brat
My Ride: IS250 F-Sport
I put 38 psi all around on my 19's. I don't want anymore bent wheels on potholes if they're too close to being underinflated.
Hamann/Euro-Spec/AA/Tein/Work Meister.....Gone but not forgotten.....
e46brat is offline   Reply With Quote
Old 12-31-2008, 01:43 AM   #15
frobie15
My Ride: has a door star
Send a message via AIM to frobie15
Fairly safe to go with recommended stock psi plus two times the diameter increase on the wheels. Then adjust accordingly to reach the perfect psi for your car. So if you started with 17's and were recommended to run 36. You'd run 40 as two times two (inch increase in wheel diameter) equals the increase.
This is how I run my car and haven't had uneven wear that wasn't caused by worn FCAB's/RTAB's.
Go ahead, ask me a question... Check out the CopTalk thread in the California forum
Thank you Sam
frobie15 is offline   Reply With Quote
Old 12-31-2008, 03:27 AM   #16
NorCal Einstein
My Ride: E92 335i
Send a message via AIM to NorCal Einstein Send a message via Yahoo to NorCal Einstein
We fill all our tires from 38 to 40 psi at the shop.
Anything between 35-40 should be fine.
Current:
2009 E92 335i Alpine White/Coral Red
Past:
2007 E92 335i Sparkling Graphite/Black
2000 E46 323i Steel Blue/Grey
NorCal Einstein is offline   Reply With Quote
Old 01-02-2009, 03:24 PM   #17
driftcars
My Ride: M3
Most tires' maximum pressure are 44 psi to 51 psi, what you have in there seems dangerous.
driftcars is offline   Reply With Quote
Old 01-02-2009, 05:06 PM   #18
jlcool007
My Ride: E46 330ci Smoked Out
omg i think that was sarcasm? ahah def a joke mayne
_FOR SALE_ (below)
***staggered style #68 330ci spt. pgk. wheels w/ PS2's***
***full set amber 2001 330ci lights***
***99-01 coupe smoked corners***
Jason Le Blanc's Facebook profile
jlcool007 is offline   Reply With Quote
Old 01-03-2009, 03:54 PM   #19
bobm3
Senior Eurowerkz Member
bobm3's Avatar
My Ride: 2003m3smg
in bklyn new york i go with
42 lbs in the front
40 lbs in the rear
to protect the wheels you put the air press. a little higher to protect the wheels.. but you should not go over 45 lbs of air press. because when you drive for a while the air press. will go up some when the tires get warm up.
in bklyn the streets are really bad with pot holes and speed bumbs.. you have to put alittle more air in the tires to protect from bending the wheels... that is what you have to do in the new york area of the country....
bobm3
bobm3 is offline   Reply With Quote
Old 01-03-2009, 09:55 PM   #20
syazoo
My Ride: M3, X3, Taco
I like 40 all around for handling with a staggered setup on 19's.
syazoo is offline   Reply With Quote
