Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 12-28-2008, 08:36 PM   #1
vladvm
My Ride: 2002 325i
DIY - Alternator Disassembly
My alternator died..Car was driving fine. No drivability problem. then I felt the symptoms...
Symptoms:
1. Battery red dash light kept turning on/off intermittently
2. DSC/DTC/Brake light turn on intermittenlty
3. Battery red light stayed on, then all lights dim including headlights...
4. Car shuts down and died.
Checks:
1. I jumpstarted the car, but as soon as I removed the booster cable, car died...
2. I fully charged the battery, car started, drove around the block, but battery red dash light starts blinking intermittenty again...
The alternator was not charging my battery.
I wanted to see what is inside my alternator. It crapped out on me. Disclaimer: You are responsible for all your actions. This is for information purpose only.
First take out the alternator. There is a DIY on how to do this. If you have a 5-speed, you can easily take out the cooling fan and airbox to gain access. This can be done in 15min., no need to jack up the car. If you have auto, it will take longer.
FYI, I have a Bosch 120A.
ALTERNATOR DISASSEMBLY
Tools needed:
1. philips head screw driver
2. flat head screw driver
3. long 15mm socket
4. pliers
Here is the picture of the alternator.
1. To take off black plastic cover, take a philips screw driver and loosen one screw.
2. Use 15mm socket to loosen the 2 nuts. one of the nut is covered by black plastic, just pry it off to gain access.
3. Once cover is off, remove the voltage regulator using + screw driver (3 screws total).
4. Pull off the voltage regulator
5. Here is the voltage regulator.
6.Use - head screw driver and pliers to loosen the copper coils.
7. Use screw driver to loosen the diode assembly, and pull it off.
8. Here is the diode assembly.
9. Loosen the 4 screws to open the alternator casing.
10. Here are the bolts removed.
11. Pry open the top casing using the flat head screw driver.
12. Pry the bottom casing using the flat head.
13. Pull the coil out.
14. Here is the copper coil.
15. Here is the alternator internal without the coil
15. Reverse process to put it back together.
ID:	296691   Click image for larger version
ID:	296692   Click image for larger version
ID:	296693   Click image for larger version
ID:	296695   Click image for larger version
ID:	296696   Click image for larger version
ID:	296697   Click image for larger version
ID:	296699   Click image for larger version
ID:	296700   Click image for larger version
ID:	296701   Click image for larger version
ID:	296703   Click image for larger version
ID:	296704   Click image for larger version
ID:	296705   Click image for larger version
ID:	296707   Click image for larger version
BMW 325i
vladvm is offline   Reply With Quote
Old 12-28-2008, 09:55 PM   #2
Whammy
My Ride: ZHP
Great thread!
I placed a request to move this to the correct forum. Thanks for posting this.
Whammy is offline   Reply With Quote
Old 12-28-2008, 10:34 PM   #3
Guest100615
Account closed per your request
so, if your alternator went out, would you be able to rebuild it with available parts or is it better to just replace the whole thing?
great write up though !
Guest100615 is offline   Reply With Quote
Old 12-29-2008, 07:56 AM   #4
Whammy
My Ride: ZHP
It is probably a matter of cost.
Old 12-29-2008, 10:33 AM   #5
vladvm
My Ride: 2002 325i
I would think you can replace parts individually, but a rebuilt one would be better choice if you have money. Plus it will have the manufacturer warranty.
Taking apart the alternator would be a good way of clearing debris like dead leaves etc...
Personally, I am replacing the whole assembly.
BMW 325i
