Sponsored by BimmerWorld
Old 02-23-2009, 01:33 AM   #41
KIRUXA
My Ride: '01 325XI
Originally Posted by damarck View Post
ENTCEE please ... give us your wheels / Tire sizes. Also "Eibach pro system" part number, will be helpfull to all.
go to modbargains or tirerack..they have them...or even better on eibach.com
mine are on they way!!!
KIRUXA is offline   Reply With Quote
Old 09-14-2009, 11:26 AM   #42
Mc 007
My Ride: 325ci Performance
Originally Posted by entcee View Post
I just recently installed new springs and stuts/shocks and thought I would share some pics. I purchased the Eibach pro system with sportline springs. It will lower a sport suspension about 1.2" and a non-sport 1.8".
I chose Eibach over H&R because I really do not like the raked look. I really like the ride. The suspension feels a bit softer than OEM but when you need it (hard cornering, etc..) if feels much, much stiffer.
Comments welcome
very nice look,tomorrow i can get my Eibach Spotline+Bilstein B8 Sprint shock absorber
Mc 007 is offline   Reply With Quote
Old 09-14-2009, 11:32 AM   #43
Riverbmr3
My Ride: MB E350 & BMW 325i
OP, are you running 18 or 19s? is it stagg? rubbing problems?
Riverbmr3 is offline   Reply With Quote
Old 09-14-2009, 05:31 PM   #44
Mc 007
i'm on 18',8 in front,9 in rear
Old 09-16-2009, 02:50 PM   #45
entcee
My Ride: 2002 325i Sedan
I am running 18" Non-staggered with no rubbing problems.
I recently put wider tires (255) on the rear so it is now a staggered setup (even though all 4 rims are the same width). It rubbed a little on some plastic where the rear bumper meets the fender, but a little trimming fixed that issue
entcee is offline   Reply With Quote
Old 02-23-2010, 05:18 AM   #46
Quenton
My Ride: 2002 BMW 320i
Sorry for reviving a dead thread but what kit did you install... The Eibach pro system or the eibach sport system? the drops your quoting are from two different systems in terms of Sport suspension vs non sport suspension....
What color are your springs?
I am interested in which kit got you that ride height.
Quenton is offline   Reply With Quote
Old 02-23-2010, 05:36 AM   #47
Mc 007
Eibach Pro Kit(black springs) low a bit,Sportline(red springs) muccher
if your car has originally M springs go on Sportline,because if you install the Pro-Kit your car can be a bit lower in the front,rear is the same like with M springs
look here
http://forum.e46fanatics.com/showthr...=590233&page=6
Old 09-25-2010, 05:31 PM   #48
spw
My Ride: 330D
Question please advice, i need some help with the suspension...
after riding this post i've decided to write my concern
my car is an e46 330d with m tech suspension...i've attached two pictures.
after i changed the 17" wheels with another ones on 18" but different sizes (j 8 with ET 20 front and j 9 with ET 22 rear, 215/35 with 225/35) the rear ones are rubbing the fender at hard bumps.
so, i lift the car to see how badly is the problem and i saw both dampers damaged by the rust and with oil leaks. definitely i must change the rear bumpers but i'm not sure i can solve the rubbing problem, anyway,
doing some research on the web about the m tech bumpers... i also want to change the front ones and i don't know what to chose.... the same M tech bumpers or Koni FSD with eibach pro kit (30/30)
right now the car is already litle bit low but i want lower.
after i solve the suspension problem i will se if the tire are still rubbing on the fender and i will roll it.
excuse me for my poor english
ID:	377067   Click image for larger version
spw is offline   Reply With Quote
Old 09-26-2010, 03:57 AM   #49
Mc 007
go on Eibach Sportline,is the best solution
Old 09-29-2010, 06:51 AM   #50
spw
My Ride: 330D
can i use Eibach Sportline springs with Koni FSD?
Old 09-29-2010, 03:16 PM   #51
Mc 007
why no,a good combination,i have this springs with Bilstein B8 shock absorbers
Old 12-12-2010, 04:05 PM   #52
huskerick
My Ride: 325i/C6/928/951
I just installed the Eibach Pro kit and the Bilstein Touring shocks - and running 255/35/18 in the rear and rubbing
I brought the car into a custom shop to have the fenders rolled, but am still having rubbing problems with rough roads. very annoying, and these tires aren't that big.
huskerick is offline   Reply With Quote
Old 12-12-2010, 04:47 PM   #53
TrickTizzle
My Ride: 325i
omg! looks perfect. Well done sir!
Now you should get a new front bumper to top it all off.
Old 10-12-2014, 08:03 PM   #54
Rush4ever1
My Ride: 2000 323ci
Prokit or Sportline?
New to this forum and want to say hello! Sorry for posting on a old thread. I have a e46 323 coupe on eibach prokit with stock shocks and struts. I'm looking to upgrade a lot of things...My question is is it worth spending the near $300 for the sportline opposed to the prokit I have now? is the sportline that much better with handling and lowering compared to the prokit?
Also, will koni yellows work directly either eibach spring kit?
Rush4ever1 is offline   Reply With Quote
Old 10-12-2014, 08:27 PM   #55
Rush4ever1
My Ride: 2000 323ci
Old 10-12-2014, 09:40 PM   #56
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Keep your Pro-kit & buy your Koni Sports. Then get an alignment.
Good luck,
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 10-13-2014, 10:17 AM   #57
Rush4ever1
My Ride: 2000 323ci
Should I get the Koni yellows? or Eibach pro dampers, or bilstein? Looking for best handling, not so much ride quality. They're all around the same price
Old 10-13-2014, 02:42 PM   #58
Rob43
Rob43's Avatar
It will be Koni Sports or Bilstein Sports.
Whichever one you pick, buy the 95-99 E36 M3 rear shocks, they're a direct fit & will work better.
1) Bilstein Sports: An excellent strut/shock (I run them w/ E36 M3 rears) what I refer to as "set & forget" because they're non-adjustable. Compared to the koni, they will raise your Bimmer up about 5-6mm higher based on their high pressure gas design.
2) Koni Sports: These are adjustable so you can dial them in based on your needs. If you ever go to a bigger/higher spring rate, these can be readjusted to compensate. The rear shock adjustment is a PITA because you need to un-bolt them to make any adjustments.
3) Ground Control "Special Koni Sports" $199 each. These special Koni's are better for several reasons, read provided link.
http://forum.e46fanatics.com/showthr...522&highlight=
Good luck,
Rob43
Old 10-15-2014, 10:02 AM   #59
Rush4ever1
My Ride: 2000 323ci
Not to sound like a complete idiot, but i'm new to the forum and I cannot figure out how to post a new thread. I separate question I want to ask and do not want to post it on this thread. Thanks
Old 10-15-2014, 03:34 PM   #60
Rob43
Rob43's Avatar
First go to the sub forum you want to post in like "Forced Induction", then look at the upper left hand corner of the page for "New Thread", click on "new thread".
Now start typing.....
Good luck,
Rob43
