Old 01-01-2009, 11:39 AM   #1
tommygunz007
My Ride: 325i 2001
Idle Stall Again
I have searched and read every post on here about stalling so here goes my E-46 Issue.
Sometimes:
1. When I brake going around turns, sometimes my idle drops and stalls
2. When stopped at lights, it revs and drops, up and down
3. Sometimes when breaking fast, like at a stoplight, it will idle drop and stall.
4. When at a light, and idleing up and down, I can put it in neutral, and it will usually slow and stop to normal fixed idle. Or, I can put it in park and jam on the gas, or I can turn off the car, and turn it back on again, and it 'resets'
One post mentioned turning off the seat warmer because of voltage. I live with the seat warmer on all the time, so I will try this and see it it helps.
My old Ford Escort did the same thing whenever I put in HIGH ETHANOL gas or Cheap gas, and the ford only did it with the 'summer blend' of gas. I am wondering if my BMW has issues now with the Cheap Wawa 92 gas? Again, I am sure it has high ethanol...
Any thoughts??? Not trying to spend any money.. broke.
tommygunz007 is offline   Reply With Quote
Old 01-01-2009, 12:17 PM   #2
kamaqazi
My Ride: 00 328i
Send a message via AIM to kamaqazi
Happens to me to. but just in the cold.
And when i first start it up till the motor warms up.
kamaqazi is offline   Reply With Quote
Old 01-01-2009, 12:27 PM   #3
Telex840
My Ride: 2000 328i
I try to avoid wawa gas. My dad and I were talking about this last night. It says on their pumps that its like 10% ethanol or somethin like that. He thinks it makes his corvette run poorly so he doesnt use it. I usually go to royal farms since there is one next to every wawa here.
Telex840 is offline   Reply With Quote
Old 01-01-2009, 12:29 PM   #4
Arsevader
My Ride: '90 325i, '02 325it
Vanos seals would be a good guess.
- James
'85 E30 325e
'90 E30 325i
'02 E46 325it
'03 E46 320i
'96 Volvo 850R
Arsevader is offline   Reply With Quote
Old 01-01-2009, 12:37 PM   #5
bmwpdx
My Ride: BMW 325it
My car was stalling around corners with same idle problems slowing. The inlet cam shaft sensor was bad and finally hard failed at Costco and required a tow to the dealership. Previous, I had the car at the dealership complaining of these symptoms but, unfortunately, no codes, so no fix. It had to hard fail.
bmwpdx is offline   Reply With Quote
Old 01-01-2009, 12:48 PM   #6
tommygunz007
My Ride: 325i 2001
response
Yeah.. that is what i was afraid of. When I read all the other posts, there was like 10 different possible issues with the car, and no way to tell which it is. If i pay to have the seals replaced, it could be something else, and so on and so on.. when I had both my honda and my ford, I spent 1000's chasing various problems, and I am trying to not pay anything for this.. I will try some gas additives like injector cleaners and crap like that, avoid wawa gas for a little while and see if it helps. I just spent $100 for my regulator, $30 for my washer pump, and I am spending $50 for the cowl. I still haven't changed my plugs, tranny fluid, and air filter and that will set me back $400 too.. so I am not really up for spending more than I have to.. P.S. I am now an E46 window regulator pro.. I can change it out in like 30 min start to finish.. I did a buddies of mine, and both of my front ones. But anyway,, thank you for the help!!!
Old 01-01-2009, 12:53 PM   #7
BMWNV
My Ride: 2001 330i
I have an 01 330 and have the same issues as you. Ive also heard other guys with 01's say the same thing. I wonder what the deal is with that year?
BMWNV is offline   Reply With Quote
Old 01-01-2009, 01:32 PM   #8
myxr4
My Ride: 05 330i ZHP
The final fix for all of my idle problems was flashing the DME with an updated program. This was after throwing $$$ after $$$ on replacing parts.
You don't have to go to BMW but you might want to call them and ask how much they charge. I went to an independent I know and paid $100
for the update. The car seems to run better and shift better too.
myxr4 is offline   Reply With Quote
Old 05-12-2009, 04:12 PM   #9
MattJason92
My Ride: '01 330ci Tit. Slvr.
Send a message via AIM to MattJason92
I've got an '01 330ci...same damn problem. Here's my thread: http://forum.e46fanatics.com/showthread.php?t=674164
MattJason92 is offline   Reply With Quote
ethanol, idle, stall
