Old 01-02-2009, 02:02 PM   #1
Krystian_E46
My Ride: E46 M3,AA3 ZHP,S544D
Send a message via AIM to Krystian_E46
Arrow Engine Burning Oil
Hey
My car is almost reaching 120k miles, i use royal purple 10w30 oil.
i drive around 1000 miles and then the oil light pops up, and its low on oil.
Im thinking it's because of the high mileage that it is burning oil i dont see any leakage of oil.
And I always have to carry an extra bottle of oil.
Any thoughts about this.
- Krystian
http://www.facebook.com/kgawlak
Instagram : KrystianGawlak
Owner of many E46's :)
[Currently own 2004 M3, 2002 325i S54 M3 Wagon, S54 ZHP, 2004 ZHP HARD MOTORSPORT Flares & Centerlocks, 2005 AA 2.5 Kit ZHP(SOLD), S54 Sedan, 01 330ci and 1 Coupe 1 Sedan 1 E46 M3 parts cars]
Krystian_E46 is offline   Reply With Quote
Old 01-02-2009, 02:52 PM   #2
itscoo2pyopants
My Ride: E53 4.8is
Send a message via AIM to itscoo2pyopants
my oil light comes on for like 10 secs even when i just changed the oil. even though the oil level is fine on the dipstick. could just be the oil level sensor, hows the oil look on the dipstick?
itscoo2pyopants is offline   Reply With Quote
Old 01-02-2009, 04:04 PM   #3
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
For one thing, you're using the wrong oil.
Old 01-02-2009, 05:14 PM   #4
I8URAMG
My Ride: BMW 325i
Do you have any leaks?
I8URAMG is offline   Reply With Quote
Old 01-02-2009, 08:32 PM   #5
Krystian_E46
no no leaks
- Krystian
Old 01-02-2009, 09:27 PM   #6
sbocaj55
My Ride: 330
Send a message via AIM to sbocaj55
Are you checking the dipstick or just going by the oil light?
You should be using BMW 5w30 or Mobil 1 0w40...or a few others but those are my recommendations. Make sure you check the dipstick. In case you haven't heard...our oil level sensors are garbage. Mine comes on frequently, even the day I change my oil. After you run your car, open your oil cap...does it smell like burnt oil? Does your exhaust smoke?
sbocaj55 is offline   Reply With Quote
Old 01-02-2009, 09:32 PM   #7
Krystian_E46
yeah i check the the dipstick
- Krystian
Old 01-03-2009, 09:45 AM   #8
paraklas
My Ride: ESS TS2 320ci
Start by using the correct oil
Old 01-03-2009, 10:38 AM   #9
aggieE46
Keep it clean
aggieE46's Avatar
He doesn't want to listen.
Old 01-03-2009, 10:52 AM   #10
brewster240
My Ride: 02 325it, 95 m3
royal purple is good shit.
bmw's by design comsume a certain amount of oil. it is used to lubricate the valve train. if it was just low enough to set the light off, top it up.
if you have the proper oil level it could be a few things. bad oil level sensor, moisture contamination, or if you take short trips the oil will get aerated and throw the sensor off. etc etc.
just keep an eye on it with the dipstick, its work since the begining of time, and is better habit then relying on the oil light.
brewster240 is offline   Reply With Quote
Old 01-03-2009, 10:57 AM   #11
TKC
My Ride: 330cic & R6
Send a message via AIM to TKC
If your oil light is coming on AT START UP and only flashed on for a few seconds and then turns off, you have a dead oil level sensor. Follow the DIY in my sig to replace it.
If your oil light is coming on AT SHUT DOWN of your car, you are low on oil, check your dip stick. If you are truly losing oil, one thing you might look into is the Oil Separator.
http://forum.e46fanatics.com/showthr...=oil+separator
EUROPROJEKTZ - Director, NorCal Chapter
TKC is offline   Reply With Quote
Old 01-03-2009, 11:34 AM   #12
aggieE46
Keep it clean
aggieE46's Avatar
Right, but he's using the wrong Royal Purple.
Old 01-06-2009, 01:57 AM   #13
DaShoker
My Ride: 328
It's oil level sensor.
BMW 328i/5mt
DaShoker is offline   Reply With Quote
Old 01-06-2009, 08:04 AM   #14
Arin330i
My Ride: 2002 330i
Bmw says to use 5w30 Full synthetic Castrol!
Arin330i is offline   Reply With Quote
Old 01-15-2009, 10:41 AM   #15
majicalqadi
My Ride: bmw m3 e36
i have same problem
majicalqadi is offline   Reply With Quote
