Old 01-02-2009, 05:33 PM   #1
StahlBlau3
My Ride: '99 328i, '88 528e
HELP!!! Super glued badges?
Hey guys, I went to go debadge the 328 and the numbers had the double sided tape on them as well as what kind of appears to be a super glue like substance. The numbers werent too terribly hard to take off but when I went to clean the car, parts of the black double sided tape are still stuck to the car by a hard clear substance....wtf? Does anyone know what I can use to attempt to get this stuff off without jacking the paint up? Thanks.
StahlBlau3 is offline   Reply With Quote
Old 01-02-2009, 05:53 PM   #2
SpecC
My Ride: 07 Scion tC, E90 330
Send a message via AIM to SpecC
what was your removal process? this is how it's usually done
hairdryer. move it around the area for about 5-10 minutes
dental floss the words out
goo gone the glue residue before it hardens again
asdf
SpecC is offline   Reply With Quote
Old 01-02-2009, 06:01 PM   #3
StahlBlau3
I just used fishing line and pretty much cut the tape from the numbers. Should I try heating it up and then wiping it off or will it even do any good?
Old 01-02-2009, 06:12 PM   #4
DetailDan
My Ride: Jeep
Send a message via AIM to DetailDan
3M adhesive cleaner.
DetailDan is offline   Reply With Quote
Old 01-02-2009, 06:18 PM   #5
StahlBlau3
sweet thanks
Old 01-02-2009, 07:20 PM   #6
DetailDan
My Ride: Jeep
You could also try isopropyl alcohol, 91% use it at full strength. You should be able to get both locally, alcohol will obviously be cheaper.
Old 01-02-2009, 07:51 PM   #7
//TRD power
My Ride: 3.0 | 200hp | 214trq
use goo-gone and polish the spot. or any other adhesive remover. I actually used my finger to slightly peel it off gently and sort of scraped it off without scratching and it came off clean, I polished it anyway.
//TRD power is offline   Reply With Quote
Old 01-02-2009, 09:21 PM   #8
StahlBlau3
Tomorrow I am going to try the hair dryer first then the goo gone. I appreciate the help guys.
Old 01-03-2009, 02:23 PM   #9
StahlBlau3
okay so I just got done trying the hair dryer and used it for 15 minutes and this clear stuff stayed hard and never got soft. After the trunk was nice and hot from the hair dryer being on for 15 minutes I tried the goo gone....nothing? Does anybody have any other suggestions?
Old 01-03-2009, 02:49 PM   #10
DetailDan
My Ride: Jeep
What about my other two recommendations, have you tried any of those yet? Last resourt should be lacquer thinner.
Old 01-03-2009, 02:55 PM   #11
CWABimmer
My Ride: '01 AW on Black 325i
http://www.griotsgarage.com/product/...rrivals&page=1
there is your answer! I think it was already mentioned above but here is a link. GL!
[IMG]http://************/c5zumy[/IMG]
ChrisTKHarris's Official Apprentice
19" HM2s | H&R Cupkit & Sways | BMP RSMs | AFE Intake | UUC TSE3 | RE Underdrive Pulleys | Schroth QFPs | 20% Tint | OEM Clears | Tinted Tails | Umnitza 50w P46s w/ Orion V2s | Silvannia Mirrored Bulbs | Jlevi LED Reverse, Sidemarker, & License Plate Lights | Bimmian Blacked Out Roundels, Black Handbrake Handle, ACS-Style Pedals, & Xenon Interior Lights | Custom Boots
CWABimmer is offline   Reply With Quote
Old 01-03-2009, 10:21 PM   #12
//TRD power
+1 to the alcohol
Old 01-04-2009, 05:25 PM   #13
StahlBlau3
I tried the isopropyl aclohol and it did absolutely nothing. Havent tried 3M adhesive remover yet, but it seems like super glue for real. When you buy new badges from the dealer they only have 3m tape on the back right? nothing else right? The previous owner told me that the car had been rear ended and the work was done at the dealer? I am pretty sure that is what he told me, so if that is true then the badges should be oem.
I guess I will have to go to Advance or O'Reillys tomorrow and pick up some of the 3M Adhesive Cleaner...I sure hope that works because I really dont want to use something that could ruin my paint.
Old 01-04-2009, 06:30 PM   #14
DetailDan
My Ride: Jeep
Another recommendation would be Stoners Tarminator.
Old 01-05-2009, 10:31 PM   #15
StahlBlau3
I took a really long good look at the molested area and seriously I swear it is super glue. When the work was done on the car it looks like they kept the old badges and put super glue on the back and put them back on. There are even smudges like what you would see if you put super glue on something and put it on and accidently moved it a little. I am taking it to the dealer where I was told it was worked on and ask them what they used and what they expect me to get it off with.
Thanks to everybody for your help...this is soooooo frustrating.
Old 01-06-2009, 06:57 AM   #16
Ian B
My Ride: 2003 330 Clubsport
It does look like sticky fixer residue, if so you can use tar remover - I removed my plates and found the previous ones had been stuck on with 2 layers of sticky fixer pads. Right bugger to get off, put plenty of tar remover and some elbow grease later it was gone. Just put it on, let it soak it and rub, repeat. If that don't work then yeah it may be something more nasty.
Ian B is offline   Reply With Quote
Old 01-06-2009, 10:57 AM   #17
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
that will rub right off with your thumb, mine did
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 01-08-2009, 10:01 AM   #18
StahlBlau3
I will try the tar remover next, this is ridiculous.
I know that alot of people keep saying that it should just be able to be rubbed off by your thumb...youre right, it should. But this stuff isnt even sticky, tacky or anything, except for clear and solid with rigid texture. I hope to resolve this situation very very soon.
Old 01-08-2009, 11:00 AM   #19
DetailDan
My Ride: Jeep
Get some Stoners Tarminator, should be able to find it locally.
