Old 01-07-2009, 08:44 PM   #1
Titanium3Series
My Ride: E90 330i
Why is my traction control and brake light on?
I was wonder why my traction control and emergency brake in yellow light on? I just got done replacing my idler pulley, put everything back on and started the car to drive and now these lights are on. I did not disconnect anything exept for my MAF, and the the plug on the radiator shroud. WHat could this be?
Titanium3Series is offline   Reply With Quote
Old 01-07-2009, 08:45 PM   #2
k7780446
My Ride: 323i
speed sensor?
5492_121783803182_586518182_2342960_2124492_n
k7780446 is offline   Reply With Quote
Old 01-07-2009, 08:45 PM   #3
GRIDLOCK
My Ride: E36 / E46
Go get codes pulled.
Have an EVAP code? Replacing gas cap did not fix? Give me a holler, I can do a smoke test for ya.
GRIDLOCK is offline   Reply With Quote
Old 01-07-2009, 08:57 PM   #4
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
why would his dsc lights throw a code?
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 01-07-2009, 08:58 PM   #5
GRIDLOCK
My Ride: E36 / E46
Because they do.
Old 01-07-2009, 09:05 PM   #6
ahull
My Ride: 2003 330i
Surprisingly (or maybe not but it doesn't make sense to me), a fault in your intake readings can cause this. Make sure all the contacts on the MAF plug are clean and there's no damage and that all the intake connections are tight. Then get your codes reset.
I had the same codes/lights/limp mode from a leaky intake pipe and just tightened everything up and it was fine.
ahull is offline   Reply With Quote
Old 01-07-2009, 09:06 PM   #7
ProchaineStation
My Ride: 03 Corolla
Send a message via MSN to ProchaineStation
maby u turned of traction and stability control off
did u press and hold the dsc button?
Next Stop: ProchaineStation™
www.youtube.com/AntoDamicoShow
ProchaineStation is offline   Reply With Quote
Old 01-07-2009, 09:25 PM   #8
Titanium3Series
My Ride: E90 330i
Nope I did not do that, plus I have pressed it cause I tried to try turn it off.
Where is the speed sensor, I did not mess aroundthe wheel At all. Also no CEL is on so no codes.
Old 01-07-2009, 11:27 PM   #9
//TRD power
My Ride: 3.0 | 200hp | 214trq
check your brake fluid level
//TRD power is offline   Reply With Quote
Old 01-07-2009, 11:29 PM   #10
00bmw323
My Ride: 00 323/91 integra RS
did u jack up the car anywhere?
-Jorge
All low no go
00bmw323 is offline   Reply With Quote
Old 01-07-2009, 11:34 PM   #11
LABMW13
My Ride: M3, 330i, '89 325i
There is something wrong with your traction control system, who knows what caused it though
M3: SSR GT3 Wheels, H&R Coilovers, JL 12" W6, Eisenmann 83mm, SS Headers, 4.10's, CF CSL Trunk & Diffuser, Euro Front Bumper, Hamann CF front lip, 3000k Fogs, NX 125 Shot
UUC Parts: SSBC Brakes, Lines, Sway bars, 8LB Flywheel, twin disc clutch, Evo 3 Shifter, RK7A Shift Knob, CF E-brake, Rasp-X Mid Pipes
Coming Soon: VRS Vented Race Hood & VCSL CF Roof Panel
LABMW13 is offline   Reply With Quote
Old 01-07-2009, 11:49 PM   #12
kosnosferatu
My Ride: 2000 323ci
this used to happen to me too, and for me getting a new battery fixed it. perhaps that might be it?
kosnosferatu is offline   Reply With Quote
Old 01-08-2009, 01:03 AM   #13
Titanium3Series
My Ride: E90 330i
my brake fluid level is perfect, and the battery is about 2 months old and has not caused any problem so far. Does anyone have a diagram or picture of the speed sensors? Maybe i knocked something loose when i was putting the plastic undertray on.
Old 01-08-2009, 12:04 PM   #14
justdru
My Ride: BMW 330ci
Bump. This fixed the exact same issue for me... I have no idea why either.
justdru is offline   Reply With Quote
Old 01-08-2009, 12:26 PM   #15
Titanium3Series
My Ride: E90 330i
Well I tightened everything up, so we will see, I hve not had the chance to drive it to see if it will clear. I started it up and the lights gave not gone off yet. Also I notice that is turns on with the car, opposed to comming on when the car starts moving like I have seen.
Thanks everyone for helping me out and throwing Ideas out there.
Old 01-08-2009, 12:49 PM   #16
ferrarix99
ferrarix99's Avatar
My Ride: 87 325e - 05 M3 Vert
Originally Posted by k7780446 View Post
speed sensor?
click for pics of the old ride...
-Nick the Greek-
euro.techniks
Bimmerworld Epic Tune | OEM Euro Headers | CSL Brakes | B&B TriFlo | aFe SuperStock | PSS10 | Varrstoen TE37 | V1 | ZKW Lens Swap | Orion Golds
Want your car coded? PM me.
ferrarix99 is offline   Reply With Quote
Old 01-08-2009, 01:00 PM   #17
wasp9166
so if i were to hook up my peak , turn off dsc, even tho ses light is not on, it would read a code? or only if it turns off by itself?
Old 01-08-2009, 01:07 PM   #18
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Sorry Cystal ball is broek and I lost my magic turban.... Get the codes read in the ABS DSC only way you will know whats wrong. A maf can set a DSC codes as the DSC needs to see a load input over can from the DME to calculate slip rate and traction control. Primary load signal comes from the Maf.
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 04-11-2009, 11:01 PM   #19
Titanium3Series
My Ride: E90 330i
well i found my problem. My lights came on after i replaced my fan blade. Well looking around the other day i relized that the fan shroud was on 100% bolted down. I put a plastic clip where i metal screw should have gone, on the passenger side at the top of my fan shroud. I put this bolt back on, just take it right now even thinking it had anythign to do with the DSC, and when i drove my car after that the lights went off......i dunno, why that screw mattered, but i dont care cause the lights are off not
Old 04-11-2009, 11:15 PM   #20
Acarder
My Ride: 69' M3
That doesn't sound like it would have caused the problem... theres a possibility that the lights are turning off intermittently and theres still a problem.
Acarder is offline   Reply With Quote
