Old 02-18-2003, 08:34 PM   #1
embrau
My Ride: 2001 330i
M3 Steering Wheel Installation
I just picked up an M3 Steering Wheel for my 2001 330i and would like to install it. I've seen a couple of DIY guides and most posts I've read on the subject say its an easy install. However, I am not the most mechanically inclined person and would like to know how easy. I don't want to end up doing a half-assed job and have the airbag not go off when I need. Would you all say its pretty easy for anyone or should I try and get it professional installed?
The only mod I've done so far is installing the clears all around. That was pretty basic so would the wheel be about the same or tougher?
Thanks!
embrau is offline   Reply With Quote
Old 02-18-2003, 09:54 PM   #2
ecng
No more mods
My Ride: 325I
It is pretty easy and just make sure disconnect the battery first. And use the new M3 wheel to practice first.
http://www.bmw330ci.com/DIY_M3_Wheel.htm
ecng is offline   Reply With Quote
Old 02-18-2003, 09:56 PM   #3
vinnymac
St. Louis BMW Fanatic
My Ride: 2011 335is
Send a message via AIM to vinnymac
It's pretty easy...the most difficult task is releasing the spring clips if you've never done it before.
vinnymac is offline   Reply With Quote
Old 02-18-2003, 09:58 PM   #4
CarFreak
My Ride: Audi A6 3.0T
I agree. Once you get that off, it's smooth sailing. Just make sure you get all the tools you need and you're set.
Audi A6 3.0T Superchaged
CarFreak is offline   Reply With Quote
