Old 05-29-2014, 09:24 PM   #1
gumanov
My Ride: 2001 325Ci 5-speed
Arduino and BMW I/K-bus integration
Hi all,
I've been doing quite a bit of research on interfacing with the BMW I/K-bus with an Arduino UNO board.
The I/K-bus is used on BMW's for non-critical systems communication and control; accessories, radios, some parts of the instrument cluster, steering wheel radio control buttons, window status and controls, seat adjustment controls, sunroof controls, rain+light sensor status, etc.. the list goes on. The bus is very similar to a typical serial bus. All modules transmit and receive on a single wire at ~9600 bits/s.
Most of my research has led to articles, and tutorials which refer to the steering wheel radio control buttons in particular - it seems to be a popular DIY. In those articles people have successfully used Arduinos to read I/K-bus HEX messages that relate to the button presses and then use that information for whatever purposes they had in mind.
I have a project in mind where I will need the rain/light sensor data specifically. The rain/light sensor (RLS) is an optional module mounted to the windshield on most E46's, behind the rear view mirror mount cover.
It serves two functions:
1) Monitor ambient(external) light in order to turn on the headlights when the lighting switch is in the "auto" position and it gets dark outside.
2) Detect water on the windshield in order to control the wipers when the wiper selector is in the first notch "auto" position.
I would like to use the external ambient light information to control an external device when it gets dark. I need the Arduino to put out 12V on one of it's outputs so that can power a relay to turn on my device.
Also would like to use the "rain detected" messages to have the Arduino respond with a I/K-bus message of "close sunroof".
I realize I can simply buy a light sensitive relay circuit and throw that into the car somewhere.. but I prefer the Arduino method because I plan on expanding the "features" at some point. There are many possibilities when you have access to this bus, I can think of many other uses I'd like to add later on, once I get more familiar with the bus messages.
I should mention I've very new to the world of Arduino and "hardware" programming in general. I understand bus systems and serial communication in theory, but I have no experience physically working with that sort of thing.
I'm asking anyone that's familiar with Arduino or has any knowledge of the BMW bus systems to please contribute to this thread; anyone that's ever successfully connected an Arduino to the I/K-bus would be of great help.
As a starting point, I obviously need to find a way to physically connect the Arduino to the K-bus line in my E46. I have a few ideas which I have found from my research, but maybe someone here has something better in mind.
Tomorrow I will sort through all of my research so far and post the information here for reference. I have a lot of the bus message ID's and data in my notes - including what I believe to be the rain/light sensor module ID in HEX format.
I'll include schematics I plan to use for the connection. I have also found several Arduino sketches(code) that others have used, mostly for the steering wheel button stuff - it'll be a great starting point for me; but I'll worry about the coding after I take care of the hardware first.
I'd like to eventually turn this into a tutorial - so I'll be keeping notes, schematics, code, and taking photos as I go
TL;DR
Calling anyone who has experience with interfacing an Arduino with the BMW I/K-bus.. looking for tips/suggestions on hardware implementation.
2001 325Ci 5spd
2004 330Ci ZHP 6spd :)
gumanov is offline   Reply With Quote
Old 05-30-2014, 12:08 PM   #2
kd7iwp
My Ride: 2001 325i
It potentially could be helpful looking into the code for the Car Kracker. There was a guy on here who was actively developing a kit (I bought one myself) which is based on the Parallax Propellor (similar idea to the Arduino but is a multi-core CPU) and he plugged it into the CD changer plug in the trunk to get onto the network in the car. I wondering if the light sensor will actually do anything when the car is off though since most sensors in the car go to sleep when the car is off.
kd7iwp is offline   Reply With Quote
Old 05-30-2014, 01:11 PM   #3
gumanov
Yeah I was considering buying a Car Kracker 3, it would be able to do exactly what I need.. but it looks like it's no longer being sold. And I couldn't get in touch with the owner of the website.
Update for references:
Best source of information I've been able to find:
http://www.northamericanmotoring.com...-r53-mfsw.html
2001 325Ci 5spd
