Thread Tools Search this Thread Rating: Thread Rating: 20 votes, 5.00 average. Display Modes
Old 01-13-2009, 12:39 AM   #1
garabatoss
My Ride: 325i 2003
Transmission Jerk?
Hi,
Bought a 2003, 325i STEPTRONIC with a small problem.
This problem is only present in D mode, not in SD (weird). But when you are coming to a stop, and the car is downshifting speeds, right around 15 mph the car does a sudden jerk, like a strong downshift from 2nd to 1st. kinda like someone rear ended you, but not as hard. Even when you don't use the breaks, if you are just rolling to a stop, it does it.
What's wrong with it? it's every time and only on D mode.
i replaced brake pads, rotors and bushings recently so it's not that. Sounds to me like a transmission problem, but only from 2nd to 1st when almost at at a full stop.
Any help ? suggestions?
thank u in advanced
garabatoss is offline   Reply With Quote
Old 01-13-2009, 02:06 AM   #2
DWA626
My Ride: 318i
I have same problem... Don't know if it is normal or not
DWA626 is offline   Reply With Quote
Old 01-13-2009, 03:13 AM   #3
Chris@ModBargains
Past Site Sponsor
My Ride: E46 325Ci
Try and have your tranny software re-flashed to see if that can correct the problem.
Chris@ModBargains is offline   Reply With Quote
Old 01-13-2009, 02:40 PM   #4
garabatoss
My Ride: 325i 2003
do i need to take it to a BMW dealer to have the software re-flashed?
I think my car is not under warranty, so would that be costly?
thanx
Old 01-13-2009, 02:46 PM   #5
vminev
My Ride: 325ci
How much does it cost to upgrade the software? I would like to do it too...
vminev is offline   Reply With Quote
Old 01-13-2009, 02:54 PM   #6
Goldman Sachs
My Ride: 01 BMW 325i
This is supposed to work on 04-current bmws but you could give this a try. I did it on my 01 and seemed to do something for me and it couldn't hurt you.
put you key in the ignition and turn it to the 2nd position ( farthest you can go without turning the car on)
Then push and hold the gas pedal down all the way for 30 sec. That is supposed to reset the transmission which learns your driving habits.
Start her up and take it for a drive.
Good luck, thought it was worth a try!
Goldman Sachs is offline   Reply With Quote
Old 01-13-2009, 02:59 PM   #7
The Jerk
My Ride: E46 M3
I like Jerk transmissions
The Jerk is offline   Reply With Quote
Old 01-13-2009, 03:07 PM   #8
vladvm
My Ride: 2002 325i
when was the fluid changed? maybe it's time to replenish the friction property of the fluid.
BMW 325i
vladvm is offline   Reply With Quote
Old 01-13-2009, 09:42 PM   #9
vminev
My Ride: 325ci
Thanks ... Im gonna try that tomorrow morning and report back if I feel any difference..
Old 01-13-2009, 09:50 PM   #10
sunydude
My Ride: Boost
Ok Mine exactly had the same issue as above, I had the transmission flash done at the dealer which costed me around $250-300 (had some other maintenance done too). It definitely improved that jerk issue.
However I seem to be noticing it again now when its too cold out there in winter. Mine has 75k miles, so Im going to get the ATF changed soon.
E46 325i - sold
E46 M/// - sold
2011 WRX - sold !!!
Back to BMW :-)
sunydude is offline   Reply With Quote
Old 01-13-2009, 09:50 PM   #11
zx9rbart
My Ride: 2001 325I
The gas pedal to the floor trick resets the drive by wire (throttle) adaptation values, and it only lasts for a few miles, this is in no way related to your tranny. The reflash at the dealer costs typically 1 hour labor (108 dollars for me). There is a TSB about rough 2 to 1 downshifts on early steptronics (according to my dealer) and they said that a software upgrade fixes 99.9 percent of the problems. Dont waste your time with the key2 throttle down trick.
zx9rbart is offline   Reply With Quote
Old 01-13-2009, 09:53 PM   #12
walkabout
My Ride: 325xi
Garabatoss,
there is a software upgrade for your transmission concerning "harsh shifting" to a stop. It cost me $240 at the dealership. My car is 2003xi
walkabout is offline   Reply With Quote
Old 01-15-2009, 02:57 AM   #13
jakajuka
My Ride: E46 330iA M Tech II
Hi everybody.
I have a E46 330iA from 2002 with the same steptronic problem. I have changed the transmission oil and filter but the jerk remain.
The next step is a software upgrade/flash for the gearbox and then I will see.
regards
jakajuka
jakajuka is offline   Reply With Quote
Old 01-15-2009, 11:45 AM   #14
n2Bimmer
My Ride: Loves Corners
this happens to me when the tranny is cold, maybe the first 2 shifts that i come to a stop, but only when cold. change your oil.
Old 01-22-2009, 02:46 AM   #15
DWA626
My Ride: 318i
i'm hving my software re-flashed at the dealer today, hopefully it will work
Old 01-22-2009, 02:54 AM   #16
jai_c
jai_c's Avatar
My Ride: 2001 325ci
im experiencing the same prob, but i notice it more when the car is cold. I had the solenoids replaced and the fluid changed about 4 months ago after my tranny died.
jai_c is offline   Reply With Quote
Old 01-22-2009, 09:36 PM   #17
garabatoss
My Ride: 325i 2003
Went to a mechanic and had the transmission software upgraded and IT WORKED!! so awesome. Thanks for the help. The software they used was EGS 0624.
Old 01-22-2009, 10:22 PM   #18
//TRD power
My Ride: 3.0 | 200hp | 214trq
the tranny downshifts to 2nd gear in D mode. 1st in SD doesn't it?
//TRD power is offline   Reply With Quote
Old 01-23-2009, 03:44 AM   #19
johnyvirsis
My Ride: 2000 323ci
I have a 200 323ci, with a steptronic. But mine also does the jerking when i put it in R. I checked the tranny oil, looking good... Just recently bought the car... Does anyone know how much are the software updates for that?
johnyvirsis is offline   Reply With Quote
Old 01-23-2009, 10:39 AM   #20
SUHLeen
My Ride: 2005 Saleen Mustang
Originally Posted by walkabout View Post
Garabatoss,
Originally Posted by johnyvirsis View Post
...Does anyone know how much are the software updates for that?
SUHLeen is offline   Reply With Quote
jolt, stopping, transmission
