Thread Tools Search this Thread Rating: Thread Rating: 20 votes, 5.00 average. Display Modes
Old 01-25-2009, 12:57 AM   #21
DWA626
My Ride: 318i
software re-flashed at the dealer and it worked
and now my transmission is smooth as!!
DWA626 is offline   Reply With Quote
Old 02-23-2009, 05:45 AM   #22
jakajuka
My Ride: E46 330iA M Tech II
The same for me.
Last week my steptronic Ecu was updated at the local BMW service and the problem (jerky step) disapear.
By
jakajuka
jakajuka is offline   Reply With Quote
Old 05-12-2009, 09:42 PM   #23
tigermooch
My Ride: E46 Sport Package
I have the same problem. I had all bushings checked, had an atf oil changed as well but still didn't resolve this issue.. Damn... Good thing I found this thread.. Thank you thank you..
Since it is suggested to have a software re-flashed which should 99% resolve this issue. Do you think it will have the same solution if I update the transmission software through Dinan other than the dealers?
Thanks,,,
tigermooch is offline   Reply With Quote
Old 05-16-2009, 01:36 AM   #24
Richneerd
My Ride: Abarth
this started to happen to me too , jerking
Richneerd is offline   Reply With Quote
Old 05-16-2009, 02:45 AM   #25
Cowspoo
My Ride: 328Ci
dwa, how much did it cost?
was it 108?
Mine does that in the cold too, first couple 2-1 stops in M mode (steptronic)
Cowspoo is offline   Reply With Quote
Old 05-16-2009, 12:39 PM   #26
Richneerd
My Ride: Abarth
I might bring it to the dealer to have them check it out
Old 05-19-2009, 04:03 AM   #27
issacsierra06
My Ride: bmw 325i
was it 108?
same thing here! need to find a fix
READ BEFORE YOU BUY
issacsierra06 is offline   Reply With Quote
Old 05-19-2009, 11:59 AM   #28
Richneerd
My Ride: Abarth
I'm going to Dinan this Thursday since they are doing free Oil Change and Safety check inspection!
I'll ask them about the transmission problem and my squeaking break pedal .
Old 05-19-2009, 12:41 PM   #29
BMERGUY
My Ride: e90 335i Boooost
same thing happen to me, just had the dealer re flash the software fo free
"6o percent of the time it works, every time"
BMERGUY is offline   Reply With Quote
Old 05-19-2009, 02:49 PM   #30
iansanderson
My Ride: 2001 330CiC
have the DME flashed too.. not just the EGS! Many improvements with new software.
iansanderson is offline   Reply With Quote
Old 05-19-2009, 02:55 PM   #31
Richneerd
My Ride: Abarth
Free?! Do you have cpo? T_T can they do mine free too?
Old 05-19-2009, 03:17 PM   #32
iansanderson
Make the same complaint.. even point out the TSB. They just might. I wasn't aware software updates were covered by CPO.
Old 05-19-2009, 08:01 PM   #33
RWMorganJr
My Ride: 325ci
I had mine re flashed under CPO and they did not charge me, apparently this was a mistake on their end. It totally took care of the problem your having. Goodluck!
RWMorganJr is offline   Reply With Quote
Old 05-25-2009, 05:55 AM   #34
dh0licious
My Ride: '00 325i
Any idea where I can find the TSB for this to take to the dealership mate?
dh0licious is offline   Reply With Quote
Old 05-25-2009, 07:38 AM   #35
Arby1028
My Ride: 2002 330i Sedan
Gentlemen - please try this FREE technique prior to chaning your tranny fluid or having the dealer reflash your software. Disconnect your battery for a couple minutes and it will reset your tranny software. I had this same transmission downshift jerk and this cured it for me almost instantly.
Arby1028 is offline   Reply With Quote
Old 05-25-2009, 12:30 PM   #36
Cowspoo
My Ride: 328Ci
arby, that would really be awesome if true!
Old 05-25-2009, 03:57 PM   #37
marc.g
My Ride: 328i
High,
i have just brought a 98 328 and have a no over run engine breaking on down shift in tiptronic. when i select 4th down to 3rd or any gear in tip tronic when i lift off the engine drops to idle
marc.g is offline   Reply With Quote
Old 05-26-2009, 09:29 AM   #38
Arby1028
Someone said to do this in a thread I read a couple years ago...all I can say is that it worked for me...just trying to pass-on the love.
Old 05-26-2009, 11:24 AM   #39
kkeddy
My Ride: 325i
i got mine relfashed at my local shop @ rmp motors. apparently he put a euro software ..no problems ever after dat..costed only like 60$
kkeddy.
03 325i
2010 Civic SI
2001 m3
kkeddy is offline   Reply With Quote
Old 05-26-2009, 11:52 AM   #40
dh0licious
My Ride: '00 325i
was that your egs flashed or dme?
jolt, stopping, transmission
