MS42 convert to MS43 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-13-2009, 01:52 PM   #1
rswtal
My Ride: E46M3 AA
328CI ->330CI
I want to put the MS43 into my car with Egas etc.
Hardware is no problem but what about the EWS in the Orig ECU.
Could someone replace the MS43 with my orig one ?
rswtal is offline   Reply With Quote
Old 01-14-2009, 07:49 PM   #2
SammyV
My Ride: CB M3
Send a message via AIM to SammyV
Not sure if i totally understand what you are asking,
but you will need a new ECU and subsequently a new EWS that will be able to be paired with the new ECU that is for the MS43.
You may be able to run a used MS43 ECU and MATCHING EWS, and then recode all the modules on the car to reflect the new index coding
bmw chuzo on the forums put a 330 motor in his 325 and went through the whole deal with electronics, you may want to search for his thread and hit him up for some tips
best of luck
SammyV is offline   Reply With Quote
Old 01-15-2009, 06:01 AM   #3
rswtal
My Ride: E46M3 AA
I have a used MS43 330ci ECU.
Could i put it in and make a EWS sync or something like this ?
thanks, will ask that guy.
Old 01-18-2009, 05:14 PM   #4
SammyV
My Ride: CB M3
not with a used EWS, EWS will be married to whatever ECU it was used on first, someone correct me if i am wrong.
if you buy a new EWS you should be able to sync it with the used Dme
Old 01-18-2009, 06:36 PM   #5
bmw_chuzo
My Ride: HPF M3
Send a message via MSN to bmw_chuzo
hey there,
this conversion is more difficulty than it appears. You basically need an used dme from a donor car with its matching ews and keys. If not you'll need very expensive tools in order to read and code the "rolling codes" from the DME to your original EWS. Apart from all this trouble comes the wiring issues. You will need to make some new wiring and modify your old one (for drive by wire gas pedal, alternator and oil signals and other bunch of stuff.)
I suggest you get a copy of the WDS (bmw wiring diagrams) and check yourself some of these differences. You'll also need some hardware like the 330 manifold, throttle body, engine harness, lol I did this swap cause' i'm crazy
any questions just ask me man..
p.s. wow sammy you already sold the car
bmw_chuzo is offline   Reply With Quote
