Engine burning oil quickly?! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-13-2009, 02:55 PM   #1
raceyoul8er
My Ride: '01 330ci convert
Unhappy Engine burning oil quickly?!
my 01 330 convert just had an oil change about a month ago, and the oil light has recently began turning on a few minutes into my driving. I took it to a local mechanic and he says my oil is low, he mentioned something that it might need an overhaul which seemed extreme and daunting. Im hopeing he just didnt know what he was talking about and its most likely a leak or somthing. The car does has 114K miles on it, which is high for its year. ANYONE know whats happening here?
http://i38.photobucket.com/albums/e147/spazmaster86/330sig.jpg
raceyoul8er is offline   Reply With Quote
Old 01-13-2009, 02:59 PM   #2
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Probably just low and/or the wrong kind of oil.
Old 01-13-2009, 03:00 PM   #3
raceyoul8er
i was told that using synthetic 5v40 was the best, am I incorrect? whats the best?
Old 01-13-2009, 03:23 PM   #4
aggieE46
Keep it clean
aggieE46's Avatar
Can't go wrong with Mobil 1 0w40.
Old 01-15-2009, 05:56 PM   #5
Arin330i
My Ride: 2002 330i
10w30 castrol full synthetic is what i use on my 02 330i
" Work like a Slave, Live like a King "
Arin330i is offline   Reply With Quote
Old 01-19-2009, 12:34 PM   #6
bimmerguy1012
My Ride: 323i
If you want to find where the oil is going have your mechanic perform a leakdown test.
This test will tell you where the oil is going, could be valve seals, valve guilds or bad rings
bimmerguy1012 is offline   Reply With Quote
Old 01-25-2009, 10:37 AM   #7
bobbydole
My Ride: 2002 BMW 330i
I am having the same issue with burning oil. It seems it is getting progressively worse. Every 700 miles or so my oil light comes on after I shut off the car. I check the dip stick and the level is below normal and I would put about 1 quart back in. I've already changed the PCV (aka oil separator) but it didn't fix the problem. I am using Synthetic Castrol 10W-40. I know some say to use 5W-30. I'll give that a try and see if it improves things. Hard to believe a slight difference in oil viscosity will make any significant changes.
My car has about ~114K miles.
bobbydole is offline   Reply With Quote
Old 02-16-2009, 10:48 AM   #8
vminev
My Ride: 325ci
I just noticed that my car is burning oil too.....
BUMP....
vminev is offline   Reply With Quote
Old 02-16-2009, 02:42 PM   #9
bcs325ci
My Ride: blown
Same here actually....
edit: mine has 110,000 miles on it.
bcs325ci is offline   Reply With Quote
