Old 01-14-2009, 03:06 AM   #1
loknaster
My Ride: 2009 STI
Send a message via AIM to loknaster
Just installed UUC clutch/ssk
I understand the clutch/flywheel spins super fast...but uh...if I'm not pressing the clutch in, I hear it...and its loud. Is that normal? I still have to break it in, will the sound go away after that period? Or did my mechanic fux up?
Otherwise, I love the ssk, and aside from the noise, I'm loving the clutch/flywheel
Yamato - 1994 lifted Toyota 4Runner - KILLED
Boris - modded 2006 BMW 330CI - KILLED
Tojo - ICE Subaru WRX STI - SOLD
Marty the Mazda - loaded 2010 Mazda 3 - SOLD
Jasper the Jeep - 2012 Jeep Wrangler Altitude - Alive!
loknaster is offline   Reply With Quote
Old 01-14-2009, 07:43 AM   #2
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Did you use the suggested fluid cocktail?
Old 01-14-2009, 12:30 PM   #3
loknaster
My Ride: 2009 STI
MY mechanic did the entire installation, so I dont know.
unless that was a joke..in which case: woooooooosh, over my head.
Old 01-14-2009, 01:48 PM   #4
TxZHP04
My Ride: ESS TS2+ ZHP
Not a joke. Brady is referring to the mix of Red Line fluids that UUC recommends to help quell the gear rattle you're hearing.
http://www.uucmotorwerks.com/html_te...nny_rattle.htm
You might want to discuss this with your mechanic.
Old 01-14-2009, 02:43 PM   #5
Autobot325i
My Ride: 2003 325i E46
Send a message via AIM to Autobot325i
+1 not until you use the special blend the noise will be loud...if not scary
even after the mix of redline fluids you can stil hear the little chatter but of course not as embarassing when ppl think your tranny is falling apart
***NEW UPDATE***
1985 318i E30
Autobot325i is offline   Reply With Quote
Old 01-14-2009, 04:46 PM   #6
aggieE46
Keep it clean
aggieE46's Avatar
Ding!
If I were being sarcastic, it would have been blatant
Hope that helps.
Old 01-14-2009, 08:22 PM   #7
loknaster
My Ride: 2009 STI
word, thanks! im gunna get some of this over to my mechanic
Old 01-18-2009, 07:49 PM   #8
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Also, the UUC says that there might be some chattering after installation which will lessen over time.
