Old 01-14-2009, 07:14 PM   #1
Tater49
My Ride: 04' G35 Coupe
Header Torque Specs
I used thesearch feature already, so please no one tell me to use! Anyway, I can't seem to find the torque specs for headers for my 328i. I just ordered headers and they should be here on Friday, and before I install them on Saturday, I want to make sure I have all of the neccesary information. Anyone got them?
2000 328i 5 Spd Black on Black SOLD!
2004 G35 Coupe 6 Spd Gray on Black Current
Daily
FS. JB Racing Lightweight Flywheel (Non-M 6 Speed ONLY) - $450 obo
FS. Spec Stage 3 Clutch Kit (Non-M 6 Speed ONLY) - $400 obo
Tater49 is offline   Reply With Quote
Old 01-15-2009, 12:26 AM   #2
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
If you can fit a torque wrench in there, you deserve a prize. You'll be lucky to fit a wobble drive / flex socket in there...
What I would do, is get all new studs and nuts from your local BMW dealership. It's well worth the cost considering the headaches you'll have with the rusted out original ones.
Old 01-15-2009, 12:31 AM   #3
LABMW13
My Ride: M3, 330i, '89 325i
I think 15 ft-lb to the cylinder head, O2 sensors should be at 37 ft-lb, connecting to the front pipes 22 ft-lb
M3: SSR GT3 Wheels, H&R Coilovers, JL 12" W6, Eisenmann 83mm, SS Headers, 4.10's, CF CSL Trunk & Diffuser, Euro Front Bumper, Hamann CF front lip, 3000k Fogs, NX 125 Shot
UUC Parts: SSBC Brakes, Lines, Sway bars, 8LB Flywheel, twin disc clutch, Evo 3 Shifter, RK7A Shift Knob, CF E-brake, Rasp-X Mid Pipes
Coming Soon: VRS Vented Race Hood & VCSL CF Roof Panel
LABMW13 is offline   Reply With Quote
Old 01-15-2009, 04:15 AM   #4
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Your #s are correct, but I have yet to use them. For example, the socket that properly fits over O2 sensors costs more than what most people spend on a torque wrench. The torque # for the front pipes is usually irrelivant, because the fasteners are usually so rusted out that it takes a fair amount of effort just to turn them.
Speaking of rust, make sure you apply a small amount of anti-sieze on the threads of the o2 sensors when installing them. I've seen a few O2 sensors destroyed trying to remove them because they are rusted in...
Advice from a guy that doesn't know jack!
