Thread Tools Search this Thread Rating: Thread Rating: 23 votes, 5.00 average. Display Modes
Old 01-16-2009, 03:59 AM   #1
sillieidiot
My Ride: '06 AW 330ci
DIY: Installing LED interior lights
Hello there. Here's another lighting DIY. This is pretty easy really. But a DIY was requested by another fanatic, so here you go. I've got lots of pictures for such a simple DIY lol. So have fun with your DIY.
THE PURPOSE OF THIS DIY IS SO YOU CAN INSTALL THE LEDS WITHOUT DREMELING/PERMANENTALLY MODIFYING YOUR HOUSINGS.
***Note: Follow this at your own risk. I am not liable for any damages or injuries that may have resulted or caused by this DIY.***
Ok got the liability stuff out of the way.
I got my LED interior kit from Mike@F1 Autohaus. They are great and bright, had no issues with them at all really, other than having to open up the housings to install it. But that's really no big deal, you'll see how easy it is in a minute.
Here's a picture of the package:
Here's the thread where I got them from. The sale might be over by then so don't blame me. But just give Mike@F1 Autohaus a PM about your kit:
http://forum.e46fanatics.com/showthread.php?t=634065
While you're buying the LED interior, might as well buy the rest of the bulbs he's offering, they are great too lol
Tools needed:
- BMW screw driver (or any flat head and phillips screw driver)
- A precision screw driver (or something really thin and strong, you'll see in my DIY why)
- Gloves (optional really, i didn't use them because i couldn't find them)
First, we are going to replace the vanity mirror lights. These are so easy, you don't even need to you tools. If you do, go do some finger exercises now. You want to place your hand like you are going to open the glove box (with the thumb on the long side facing you, and the rest of the fingers on the other side) and dig your fingers into the gap a little bit and pull on it like you were opening the glove box.
Here's a picture of where your fingers should go (without the thumb in position):
And voila:
Yea I know, Xenon interior bulbs FTL. Thank god I replaced them with these
Find the bulb that matches the length of these. It should be the longest one:
How it looks in the housing:
Keep in mind. The LEDs are polarized. So if put them in and it doesn't work, flip them 180 degrees and it should come on. So don't start crying when it doesn't work. The bulbs are not defective.
Also to note, you need to have your key in the second position in order for the vanity mirrors to light up. And make sure the visor isn't bent all the way back or else it won't come on.
Put it back. Test it out, make sure it works. What do you think?
**They aren't this blue, it's just my camera. There are more like pure white, I would say they are about 5500k in color**
Repeat steps to do the other side.
Now for the dome light. You will need a flat head screw driver for this. You want to wedge it in at the side where the buttons are. About 1" to 1.5" from the side. Here you will be pressing some metal prongs in and them pull it down. Takes little force really.
Picture of where to put the flat:
Here's what you are pressing (circled in blue):
Now you have it out. Just unplug it. There's 2 small tabs on the plug. Nothing too bad.
We are going to start with the center light. The 194 bulb that is included is too big to fit into the housing. Of course you can dremel it if you like, but if you did, then why are you here? lol
Anyways, you will need to take out 2 Phillips (has a flat slot so you can use a flat if you need to). The space is sort of small, so use a skinny one. They are circled in blue here:
Close up of one of them:
And they just come apart just like this:
What you want to do is take out the original bulb holder and bulb by twisting it counterclockwise. So basically from it's vertical position to this:
Take out the bulb (it's the 194 wedge bulbs that you'll need) and place the black bulb holder back on (without the bulb) and twist to lock. Then you will put in the LED from the other side like this:
Then test to see if it works, don't put the cover on yet. Because if you do and it doesn't work, well you have to take it apart again If the bulb doesn't work, like with the vanity mirror lights. Just take out the bulb and flip it 180 degrees.
There it's on:
Now put the cover back on. And you're done with the center light. Next you'll do the 2 maplights on the side. Ironically, these fit through the back with a little bit of wiggling. Twist like above and pull out:
If for some reason yours doesn't fit from the back, just go at it from the front with the same method describe above. Should look like this when you're done:
Yes I know the middle one is still blue, I didn't do it in the order I am writing the DIY. Plug it in and check to see if all the lights are working once again, now put it back. You want to place the side opposite of the buttons in first and then push up on the side with the buttons. Here's a refresher picture in case you were too lazy to scroll up:
Next we move onto the footwell. You'll need a flat head for this. Well not really, but it'll just make it easier still. There's a small notch on the side for you to put in the flat, just stick it in and pry it out. It should pop out with ease.
Picture of the driver's side footwell:
Unplug it and take it out. On the back you will see a metal piece. It has arrows on it to tell you how to slide it. Just slide it to open, it will only let you go one way (depends on what orientation you are holding it, it will slide left/right)
Here it is with the metal piece slid open:
The festoon you need is the shorter, blockier one. You may need to bend the prong out to fit it in, then bend it back a little to make it stay fit. Should look like this:
Plug in, and check. If it doesn't come on, flip 180 degrees and try it again. Then put it back. Now you are done with the front. Gather all your tools and head to the back seat, now for the hard part. Ok not really, but you're going to have to put a little more effort for these.
For the rear, you'll need a flat head. You'll want to put it on the little notch (it's not really a notch, but if you look at it closely, you'll see a space for the flat head to go) and push on it and pull it out. Again you will be pushing on one of those metal prongs. There's 2 of those places (circled in blue). What I did was start on the side facing the front of the car, pop it out a little bit, then take my finger and hold the housing there. Then go to the top notch and pop that out. It make take you a little while to get this, so take your time. Don't do it too hard, you might dent/scratch the surrounding carpet.
Placement of flat head:
Close up. You see the rectangular indentation looking spots?
Whew, that was hard work huh? Take a look at the housing, most likely you sorted bent the metal prongs. Just take a pair of pliers and bend it back into shape. The prongs should look like this:
You still with me? I hope so, because we are almost done. Again, the 194 bulbs won't fit through the back of the housing, so we will have to open the covers. That's not a problem.
There are 2 plastic clips that you will need to pop up and push off. One side is the easy side where you can you your regular old flat head, the other side is where that precision (or what every thin, strong tool you got [in my case, i used a sharp knife lol. I don't recommend you use a knife though] flat head will come in handy. What you want to do is pop the clip up (circled in blue), then use the screw driver to push on the tab (while keeping the clip up) forward (direction shown with blue arrows). You should see the cover start to create a gap. You want to do this to both sides.
Easy side:
Harder side:
You want to push them enough so that both sides have an even gap and big enough so that your fingers can fit in. Then pry them apart with your fingers. It's a little harder than all the others, so use more force. It should snap apart (well you'll kind of hear it, and you'll know once it's apart).
You should have 2 pieces when you're done:
Again, like the method used for center dome light. Twist off the bulb and bulb holder, take the bulb out, and put the holder back on. Then put in the 4 194 bulbs. Plug them in and test to make sure they work before snapping the covers back on. Then put them back in, you want to put the side facing the rear windshield in first and then push the other side in.
Now you are done with interior
Oh yea, I forgot about the glove box Well that's easy. Just like the footwell, take a flat, put it in the notch and pop it out. Then just replace it, you may need to bend the prong. Sorry I don't have any pictures for this.
Ok, you're not totally done, you need to do the ones that light up your trunk. Pretty easy. Just like with the footwells, there's a notch (circled in white), just stick a flat in there and pop that out. and replace the bulb. The 2 remaining long festoons goes here. You might want to take the whole black piece out, might be easier. I was lazy so I just did it while it's in there.
Here's the final product for the trunk:
Ok now, you are officially done. Now go have a beer or whatever you want to drink. It shouldn't take you too long. It took me like an hour because I had to stop and take pictures for you guys long the way.
Also to note, there have been reported issues of the big 5 (the 3 lights that come on when you unlock, and 2 footwells) not working with some angel eyes set up. I believe it has something to do with the footwell tap. I also ran into this problem when I was installing the kit (for my sister's car). What I did was just replace one of the footwells (just one) with an incandescent bulb and they all work perfectly fine. Again this is not to say that all cars with angel eyes will have this problem. My car didn't have this problem. But having 13 LED bulbs and one xenon bulb should be fine.
Enjoy your LED interior. I'll have some picture of the LEDs shortly for those that are interested.
Old 01-16-2009, 04:04 AM   #2
sillieidiot
wow it all fits. i was worried that it wouldn't lol.
anyways, for those that want to piece together their own kit (which will probably end up costing more than this kit at regular price), here are the bulb sizes:
Originally Posted by sillieidiot
2 39mm x 10mm for the footwells
2 39mm x 10mm for the license plate
2 44mm x 10mm for the vanity mirror lights
2 44mm x 10mm for the trunk lights
3 194 bulbs for the center light/front maplights
4 194 bulbs for the rear/rear interior lights
1 39mm x 10mm for the glove box.
Old 01-16-2009, 04:12 AM   #3
k7780446
My Ride: 323i
pm sent
great DIY
5492_121783803182_586518182_2342960_2124492_n
k7780446 is offline   Reply With Quote
Old 01-16-2009, 07:02 AM   #4
stussystatus
My Ride: 2002 BMW M3
Mike told me you were going to make a DIY, he kept his word! I'll be posting up pics once I install them on the M.
2002 TiAg ///M3 : / VCSL Bumper 1 peice CF splitter / Smoked Corners & Side Markers / Matte Black Kidney Grills & Side Gilles / Tints / Gloss Black Roof Vinyl
stussystatus is offline   Reply With Quote
Old 01-16-2009, 07:41 AM   #5
Anub!s
My Ride: e46 330ci, e92 M
Send a message via AIM to Anub!s Send a message via MSN to Anub!s Send a message via Yahoo to Anub!s
nice diy as usual bro
Anub!s is offline   Reply With Quote
Old 01-16-2009, 07:43 AM   #6
LSUKNUT
My Ride: 330i
Great DIY Sillieidiot! I wanted to do a DIY for the install but was too excited for the end result to stop and take pics. The more DIY's we get for Mike's products the less phone calls he should get......
How come the light isn't coming on Mike?
Did you try flipping the bulb over?
No.
Try it.
OK, I flipped it over. Hey! It works now. Thanks Mike!
KNUT's Progress & Thank You to E46Fanatics Supporting Vendors - http://forum.e46fanatics.com/showthr...=1#post9933726
LSUKNUT is offline   Reply With Quote
Old 01-16-2009, 03:37 PM   #7
sillieidiot
ok, i just edited the post to add that first bolded sentence lol.
yea i tried to cover all the bases to reduce the number of questions.
Old 01-16-2009, 05:41 PM   #8
LeontiyZHP
My Ride: '04 330Ci ZHP
Nice write up!
Leo
2015 BMW 335i M-sport (BSM)
2014 BMW x3 28i M-sport (BSM)
2004 330Ci ZHP SOLD and very much missed.
DIY Facelift Angel Eyes | AVIC-D3 Install | flickr
LeontiyZHP is offline   Reply With Quote
Old 01-16-2009, 06:43 PM   #9
q0192837465
My Ride: 99.4 A4, 03 330xi
Send a message via ICQ to q0192837465
nice, great reference for the future. Thx for spending the time.
q0192837465 is offline   Reply With Quote
Old 01-17-2009, 12:20 PM   #10
Mike@F1 AutohaŘs
Past Site Sponsor
My Ride: E46 330ci
Great DIY Hieu
Mike@F1 AutohaŘs is offline   Reply With Quote
Old 01-17-2009, 02:22 PM   #11
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
Sold me on these bulbs. Can't wait
phamine is offline   Reply With Quote
Old 01-17-2009, 02:37 PM   #12
taghirap
My Ride: tricycle...
Send a message via Yahoo to taghirap
nice diy!!
taghirap is offline   Reply With Quote
Old 01-17-2009, 03:53 PM   #13
sillieidiot
my friend just took some pictures of the interior. we tried to adjust the setting to show how it really looks in person (instead of pictures that make it look over exposed or a completely different color and stuff like that). i'm going through them right now and will probably up them tonight.
Old 01-17-2009, 09:48 PM   #14
roddykaregaran
My Ride: 2004 smb 330Ci ZHP
finished this installation last night.
Looks beautiful.
Ill post pics after ive completed the halos.
CCFL ANGEL EYES | SMOKED SIDE MARKERS | JET BLACK GRILL | 6000K HEADLIGHTS | 6000K FOGLIGHTS | APLINE TYPE R 12"
LED INTERIOR KIT | LED LICENSE PLATE | BRUSHED METAL ROUNDELS | SAPPHIRE METALLIC BLACK REFLECTORS | 15% TINT
roddykaregaran is offline   Reply With Quote
Old 01-18-2009, 03:58 AM   #15
T330
My Ride: X5
Send a message via AIM to T330
I did the install today... I did not modify my housings.... nor did I take them apart as in your DIY..... I feel retarded now .... Thanks for the DIY hieu
T330 is offline   Reply With Quote
Old 01-18-2009, 04:18 AM   #16
sillieidiot
lol how did you put the bulbs in then? did you modify the bulbs?
Old 01-18-2009, 04:22 AM   #17
stussystatus
I was going to buy the ones from JleviSW, but those pictures gotten me. My interior looks 10x better and updated. I haven't installed the passenger footwell ones yet but will do soon. Great product Mike@F1Autohaus! Thanks for DIY Sillieidiot.
Follow sillieidiots DIY and you should be good to go! I was just so eager to installed these, even in -14deg temperature lol! Here are you teasers. Like sillie said they are not really that blue but pure white, ~5500k.
Old 01-18-2009, 03:22 PM   #18
T330
My Ride: X5
No... I opened the housings a little bit with my finger.. (my fingers are all cut right now dit dee dee) Then I squeezed the Led bulb into the housing. After it was in the housing, I had to roll the housing around hoping the LED would poke through the socket. Eventually it did. Then to plug it in I had to hold the LED in place with a screw driver so that the plug would not push the LED back into the housing. It was really tedious
Also, I didn't have these fat ones for the footwells
Old 01-18-2009, 06:28 PM   #19
sillieidiot
ahaha, damn that is really hard. i wouldn't imagine doing that. i was pissed off the first time i did the interior LED install, then i just sat there and was like "there has to be a way to open it" then there was.
oh yea for the fat ones, those are the license plate LEDs. I put those in cause it's a lot brighter lol. But you're supposed to use the long festoon with the 3 LEDs on them.
Old 01-18-2009, 11:36 PM   #20
T330
My Ride: X5
lol yeah it was not fun....
Hmm I'll try the fat ones in the wells and then put my old LED license plate lights back on for now
