Rating:
Display Modes |
#21 |
Dude, nice write-up. I'm half done but got stuck on the rear seat reading lights. Thought I was going to bust something so I came back to the forum to look for more info. I'll try your tip. Thanks.
With LEDs I noticed the vanity lights would drive me crazy turning on or off with the position of the sun shade. With a bulb, light intensity would weaken or strengthen which I found less annoying. For these lights, plus the rear plate, I simply went xeon bulb over LED. |
#22 |
um, i realized that there is dimming with the xenon bulbs, so im guessing wit the leds, it'll just turn off instantly right?
#23 | |
As for the DIY, buying from JLevi I did not have to do anything to adjust the fitment of the dome light (no dremeling or taking off the cover), it fit nicely. |
#24 | |
I've had LEDs for a while, but I didn't know that the vanity light intensified or got dimmer based on the mirror position, I thought the light went on or off even with a bulb. Can someone else confirm this? EDIT: Pic is upside down but you get the idea. Those points worked for me. Last edited by JK1150; 01-19-2009 at 03:12 PM. |
#25 |
oo ic, i live in canada, i got some led bulbs from my store (i work at car accessory store) 194 bulbs, i nvr tried them on my car, i guess ill post back if other generic led bulbs have the semi dimming function!
#26 |
Good write-up... I did mine (ebay) about a month ago. However, I did have to use a dremmel to get them to fit.
#27 | |
Have a lighting problem? Read this first: Lighting-related Troubleshooting Guide |
#28 | |
#29 |
#30 |
yea i get it to go on/off/barely lit/half on that's like pretty much everything you can do with a bulb lol
#31 |
i did half of the diys, i realized he leds i bought from my store aren't that bright, gonna exchange for something brighter! but deifnitely looks nicer lool
#32 |
Do the LED lights pull less power from the battery? We do a lot of car camping and with the trunk and open and shut a lot, have had problems with the battery getting drained (had to have a boost).
#33 |
Yes, they pull less power. How long do you leave the lights on? I left them on for an hour straight so that my friend could take pictures of them.
#34 |
Where would one find LED's that are slightly more along the lines of 8000k?
Also, there is a light that shines down from where the map light is that illuminates where the shifter area is. Its normally orange, how do you change that one as well? |
#35 | |
Past Site Sponsor
Cameras have a tough time picking up the actual Pure White color indeed. Here are some new photos the Sillieidiot took with his friend's DSLR: 5500k Pure White ![]() There's no blue hue in real life: ![]() ![]() 5500k LED License and Reverse: |
#36 |
for the led reverse, wouldn't the "bulb check light" go on .. because leds uses less power? or does the one you sell have like a built in resistor to compensate for the less power used by led's
#37 |
there is no 8000k LEDs for interior. blue is probably the closest. as for the 2 orange LEDs, you need to know how to solder then find the correct LEDs and replace
#38 |
apparently, there is no rear warning lights for the reverse lights to begin with. so you just plug n play (literally)
#39 |
have you guys experienced license plate leds going out easily? I went thru so many license plate leds...they just would not last.
I wonder if interior lights will be the same.
#40 | |
i just finished the led diy mod. the bulbs i used were the eurolite 194s, and for the middle on in the front when the door opens, i managed to fit a led 921 bulb in there. its a 5 led bulb, in different angles...one shooting down, and 4 different sides. the bulbs i have is not pure blue. but white-ish-blue. will definitely take some pictures tonight to show u guys! |
