Thread Tools Search this Thread Rating: Thread Rating: 23 votes, 5.00 average. Display Modes
Old 03-27-2010, 09:16 PM   #141
Brilliant
My Ride: E46M3 Blk/Blk
Thanks for posting about how to get those lights out. Its about 4 hours too late for me though. I mangled mine getting them out. TIS really doesnt show what needs to be done. Its opposite I think, or at least how I read it. Anyway... new housings on the way.
Brilliant is offline   Reply With Quote
Old 03-30-2010, 07:17 PM   #142
mekaneck
My Ride: 2003 325xi
I personally think it's ten times easier to just remove the C-pillar liner with the light still attached to it. There are just two snaps near the top of it, so if you grab up near the top and pull it'll come right off.
Here's a post of the back of the trim so you know where the snaps are.
2003 325xi Black
mekaneck is offline   Reply With Quote
Old 03-30-2010, 09:46 PM   #143
sillieidiot
My Ride: '06 AW 330ci
yea you can do it that way too i guess. iono it wasn't so bad my first time. just take it easy, and if nothing is happening add a little more force and keep going until you got something.
Old 04-13-2010, 02:52 AM   #144
rapper4u
My Ride: 320 CI
Hi there ... kinda new here and new to the BMW family ... my little problem is that as many of u guys i did replace all my interior lights with LED lights ... everything works fine beside the "bulb check light" which is on for both reverse lights ... i've read about that 40 Ohm resistor but that one was for the footwork lights ... any idea how can i solve the problem ? i got a '99 320 CI
rapper4u is offline   Reply With Quote
Old 05-26-2010, 06:32 PM   #145
sarconi11
My Ride: 2002 Black 325i
Hey guys I ran into the common problem where a few of my rear LEDs wont turn on. I went ahead and purchased a resister that was suggested on this thread, but my problem now is Im not sure where to put the resiter or how to install it. If anyone can give me feedback on how to fix this it would be greatly apreciated!
sarconi11 is offline   Reply With Quote
Old 05-26-2010, 08:49 PM   #146
genuity
My Ride: 2001 330iS
Did you try reversing the bulb positions? Most LEDs I have come across have polarity.
I am running all "low powered" LEDs all around and they work fine--still have yet to find license plate LEDs that are the closest in color and brightness with the latest E92's. Then, all I need is sidemarkers and front corners with LEDs and I'll be fully converted to LEDs (except the fogs and DRLs/high beams).
I have not had the need for any resistors at all, except whatever came with the eagle eyes for the rears, but for all internal LEDs, I have no resistors and it all works fine
genuity is offline   Reply With Quote
Old 05-26-2010, 11:23 PM   #147
sarconi11
Yes I have tried switching bulb positions and its no help.
Old 05-26-2010, 11:35 PM   #148
Mike@F1 AutohaŘs
Past Site Sponsor
My Ride: E46 330ci
^ You need more resistance on the interior circuit
Mike@F1 AutohaŘs is offline   Reply With Quote
Old 05-27-2010, 09:55 AM   #149
sarconi11
Yes and thats done through a resistor correct? I just need to know how to install this thing, considering my electrical skills are probably not up to par ha.
Old 05-30-2010, 11:23 PM   #150
sillieidiot
you shouldn't have a bulb out warning for the reverse lights at all. are you sure it's even that?
Old 05-30-2010, 11:25 PM   #151
sillieidiot
which ones don't turn on? usually the ones that's comes on with the center dome light will be out. if the center dome light is still on, it could be the polarity of your bulbs. if not, then i would just use one incandescent bulb and go around and stick it in each spot until you can find one where they all light up with that bulb in place. then that is where you want to put the resistor.
most people have this problem in the driver's side footwell so you might want to try there first.
Old 05-30-2010, 11:27 PM   #152
sillieidiot
most of the LEDs sold won't come close because they are using neutral white LEDs. and most vendors use cool white. the OEM LEDs are not that bright tbh. you just see more of the plate because it has more usable white/yellow light
Old 06-16-2010, 11:23 AM   #153
Black n Tan
My Ride: 01' 330i, VW Corrado
Hey guys, I installed this kit the kit from khoalty on my 330i and everything works fine except the two license plate lights. They work fine but they cause a bulb failure light on my mfa. Any help?
Black n Tan is offline   Reply With Quote
Old 06-16-2010, 11:39 AM   #154
profor
My Ride: E46 320d 2003
hide somewhere normal bulbs and wire them parallely to LEDs
profor is offline   Reply With Quote
Old 06-22-2010, 12:46 AM   #155
Spee D
My Ride: '02 325ci
first time doing a DIY to my car... and im a little confused.
exactly how would i install a resistor.
Also, I have the 5 light problem (dome, 2 rears, both footwalls). At first, the dome and left side light where working but when i switched over to the right one it would turn on. Eventually, it lead to the dome and left light now working. Also, the two footwells worked once i got them in but suddenly shut off. I tried putting one of the stock bulbs in them and nothing happened.
This is how we chill
Spee D is offline   Reply With Quote
Old 10-27-2010, 12:01 PM   #156
pez319
My Ride: 2001 BMW 325i TiAg
Hey guys, this is my first post, I just joined. I really want to do this swap. I found 37mm Festoon LED bulbs on amazon for $8 each. I was wondering if the 2mm is really going to make a difference? I figure I can just bend the contacts inward to hold it in place.
Thanks!
pez319 is offline   Reply With Quote
Old 10-27-2010, 12:52 PM   #157
sillieidiot
no it won't make a difference if the bulb is smaller. if it's bigger than, it's harder to make work.
Old 10-27-2010, 01:21 PM   #158
pez319
Awesome! Thanks for the write up too...
Old 10-27-2010, 01:22 PM   #159
sillieidiot
no problem. i also have a vid of me taking out the rear if you have trouble with that. it's hidden somewhere in this thread. i wasn't able to edit it in my original post
Old 11-09-2010, 04:44 PM   #160
nightrunner20
My Ride: will eat your dust
Send a message via AIM to nightrunner20
This is so frusterating. Installed all led lights. Now the interior lights won't work at all. None turn on when door is opened. I'm guessing I blew a fuse or need more resistance
nightrunner20 is offline   Reply With Quote
