Old 01-16-2009, 12:40 PM   #1
///Orient3
My Ride: can't be defined
Removing dried Menzerna splatter
About seven or eight weeks ago, I let my cousin try out my Metabo rotary on the trunk lid. It needed to be repainted anyways, which was taken care of about a month ago when some idiot went demolition derby on the back of my car. I don't think he ever really started to break the clear down, he did get splatter all over the rear windshield.
What should I use to clean off/remove old, dried, Menzerna SIP polish (mainly from the rear window)?
///Orient3 is offline   Reply With Quote
Old 01-16-2009, 01:28 PM   #2
DetailDan
My Ride: Jeep
Send a message via AIM to DetailDan
Rubbing alcohol is fine, water would probably work as well as a standard window cleaner. You dont need anything special.
DetailDan is offline   Reply With Quote
Old 01-17-2009, 04:40 PM   #3
Greg@DetailedImage.com
Clean Shine Protect Expert
My Ride: is clean & protected
You should be able to remove it with a number of different products like rubbing alcohol, clay bar, Glass Science Glass Scrub (on the glass), degreaser, etc. If the marks are really horrible you can use a little quick detailer and a clean razor blade on the glass, assuming the other methods didn't work.
Greg @ Detailed Image
Old 01-18-2009, 11:34 AM   #4
PuckMan
My Ride: 335i Coupe
How about some window cleaner and 0000 steel wool if you have any.
M3 + trailer hitch = oxymoron
PuckMan is offline   Reply With Quote
