Old 01-20-2009, 08:11 PM   #1
inlinesicks
My Ride: E46, Jeep, Subaru
330 crank in a 323?
So my question is, if I bought the crank, rods, and pistons from a 330 and swapped them into my 323 and reprogrammed the ecu would I basically have a 330 engine? Would I have to get a head from a 330 or are they the same? Are there any other things I would have to do?
This is just a theoretical question because I am aware of how much those parts would cost, Im just asking out of curiosity.
inlinesicks is offline   Reply With Quote
Old 01-20-2009, 08:19 PM   #2
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
The bore is different aswell. so even though you are stroking, you would need that extra displacement to fit those pistons with the proper rings.
I think this should be moved to the engine and dme section of the forum btw
SL Blak Soldier is offline   Reply With Quote
Old 01-20-2009, 08:27 PM   #3
inlinesicks
Oh I didn't know the bore was different, what if I did the same thing but with the parts from a 328, Im sure the bore is the same on a 328 right?
Oh and sorry about putting this in the wrong place, Im a forum noob
Old 01-20-2009, 09:04 PM   #4
BMW_Stu
My Ride: HPF 330ci
No the m54 engines are bored and stroked versions of the m52. The 330's 3 liter has the largest bore.
BMW_Stu is offline   Reply With Quote
Old 01-20-2009, 09:31 PM   #5
mkodama
mkodama's Avatar
If I remember right, the bore of the 325 and 330 are the same.
Old 01-20-2009, 09:47 PM   #6
SL Blak Soldier
hmm so you saying that the stroke is whats diff between 325 and 330?
Old 01-20-2009, 09:59 PM   #7
mkodama
mkodama's Avatar
Yep, the M54B30 (E46 330) reuses the crankshaft from the S52B32 (US E36 M3) and has a better flowing intake manifold. Most of the power gains are from the intake manifold though.
Old 01-20-2009, 10:11 PM   #8
SL Blak Soldier
are you talking about the differences between the m54 vs the s52 being the mani? if so where did that extra .2 liters come from? or the m54 vs the 325 motor (sorry don't know the code)
btw stick with the 190e evo sig, it looks sick compared to the csl sig.
Old 01-20-2009, 10:23 PM   #9
ejamin73
My Ride: '04 325i Sport Pkg
This is interesting. I was thinking the same a few weeks ago.
So,I have a '04 325 sedan sport.What do I need to upgrade from 2.5L to 3.0L?
I just can't imagine the world without the smell of burned gas coming out of a well tuned engine:drool:
Originally Posted by zhp pilot View Post
nice try on the sig you tard. unfortunately, when you click the link you see the actual quote.
you are on a roll with the FAIL tonight. :lmao:
ejamin73 is offline   Reply With Quote
Old 01-20-2009, 10:43 PM   #10
mkodama
mkodama's Avatar
I was talking about the differences of the 325 and 330. The crankshaft, and intake manifold are the two main differences.
And thanks about the sig, but it's a rotating signature. Everytime you refresh the page it will be 1 of 5 or 6 cars I like.
Crankshaft, intake manifold, ecu, MAF, throttle, intake system, and other things. I'm not sure on all the details.
It's probably easier to just get a 330 engine and ECU, and swap it with you engine, and then sell yours.
Old 01-20-2009, 10:56 PM   #11
ejamin73
Thanks for the info
I think is better to get a 330 engine & keep the other for a while just in case.
Old 01-20-2009, 11:04 PM   #12
bigdog2003_99
My Ride: 2009 Audi B8
bore on both m52b25 (323ci) and the m54b30 (330ci) are the same 84mm the difference between the displacement is the 14ish mm of stroke..... look up bmw_chuzo's thread about his 3.0 stroker
btw the exhaust cams are the same between the 325 and the 330 just a better flowing intake cam for the 330 (minus the zhp)
i have a 3.0 crank if anyone is interested
2010 C300 4matic
2008 yamaha r6
see garage^
R.I.P. John Bryan
http://videos.streetfire.net/video/J...yan_186423.htm
bigdog2003_99 is offline   Reply With Quote
Old 01-20-2009, 11:13 PM   #13
BMW_Stu
My Ride: HPF 330ci
Note: engine names m54b30 (330) and m54b25 (325) they r both m54. M52 engines go the same way.
Old 09-03-2014, 05:31 PM   #14
matt94
My Ride: '99 e46 323ci
What kind of time would be involved in removal of my 323 engine taking off the oil pan and swapping the whole rotating assembly with one from a 330, sealing the whole thing up and dropping it back in thr car. Assuming I have the engine hoist and all necessary tools on hand
matt94 is offline   Reply With Quote
323, crank, swap
