Old 01-21-2009, 08:27 PM   #1
mhallerbach
My Ride: 1999 323i (E46)
Complete Parts diagram for E46
I need a part but don't know what it is, and when going to these BMW parts sites , they ask a zillion questions and in the end, its not the part I need. Is there an online reference where I can look through parts explosions and figure out what I need, and then I can go order it(I'm a visual person)
1999 323i sedan - I need the rubber/plastic part that runs along the bottom of the front windshield that has vents in it, and has holes where the wiper arms are attached. ITs a combo of plastic and rubber. I thought it would be windshield trim, but noe of the online BMW parts companies think that way. Any help would be appreciated to get me headed in the right direction.
Thaanks,
mhallerbach is offline   Reply With Quote
Old 01-21-2009, 08:33 PM   #2
mistrzmiasta
My Ride: GLK350,ML63, Duc1098
ummmm realoem.com
mistrzmiasta is offline   Reply With Quote
Old 01-21-2009, 08:36 PM   #3
BodyMan
My Ride: 2002 325i
That is the cowl cover.Pn# 51718208483 $55.24
BodyMan is offline   Reply With Quote
Old 01-21-2009, 08:43 PM   #4
mhallerbach
Originally Posted by mistrzmiasta View Post
ummmm realoem.com
Thanks - I found it again - had it bookmarked but lost it - I love that site.
The part I need is as mentioned below, called Windshield cover - mines all cracked and falling apart - I had water in my interior last rain and thinking this is maybe the cause. Hopefully.
Thnaks,
Old 01-21-2009, 08:43 PM   #5
mistrzmiasta
Old 01-21-2009, 08:45 PM   #6
DesertMotorWorks
Past Site Sponsor
My Ride: 2004 330CI
Thaanks,
Just like BodyMan mentioned, it's a Hood Cowl / Windshield Cover.
I have them in-stock.
Name:	E46 Hood Cowl.jpg
DesertMotorWorks is offline   Reply With Quote
Old 02-17-2010, 11:17 PM   #7
yeowser
My Ride: 1999 323i
Hi guys, a new member here, so please forgive me if I have overlooked any protocols in my first post.
I've got the same issue with my windshield cover cracking and flaking off... probably happened when a previous owner replaced the windshield.
Any chance if anyone knows where i can source a windshield cover in Melbourne Australia or if anyone out there will send one down under?
yeowser is offline   Reply With Quote
Old 02-18-2010, 06:34 AM   #8
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
OP,
Check your hood drain in the corners where plungers go...also, under the cabin air filter (in the housing) there are also what I believe are drain holes too. Make sure they're clear of debris. If they clog, then water from the cowl will back up and get into car potentially.
I replaced mine and that stopped my leak and I vaguely recall thinking that when cracked it bypasses hood drain and would find a way to 'bad places.' I know some have had it go into ecu...expensive!
Also, my cowl didn't fit tight against the window in all spots, but not an issue...the water infiltration happens when it's cracked...not from the 'seat' between top of cowl and windshield.
Easy diy! Doublecheck all your gaskets are overlapping correctly around cabin air filter housing and other 'walls.'
Doug
Upcoming comedy shows: April 23, Tierney's Tavern, Montclair, NJ, 7:00 p.m. See Facebook for other shows and PM me if you can make one...love to see you there!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 02-18-2010, 09:31 AM   #9
Darth Bimmer
My Ride: 00 328i & 01 Mcoupe
...Check your hood drain in the corners where plungers go...If they clog, then water from the cowl will back up and get into car...
That is true!
...Also, my cowl didn't fit tight against the window in all spots, but not an issue...the water infiltration happens when it's cracked...not from the 'seat' between top of cowl and windshield...
For this part, although what you mentionned above will AMPLIFY and ACCELERATE the problem, look at my post from an other tread, I figured this out after ALOT of testing with a garden hose and the carpet removed...
Originally Posted by Darth Bimmer View Post
What I found after searching a long time on my own car is this...check your front carpet to see if they are wet, you can also lift the whole carpet, but it's kinda hard, you'd be suprised at how mush water you might find there... enough to keep a few gold fishes lol.
If that is the case, replace that black plastic trim around and under the wiper arms. This part has a seal and when it dries over time it does'nt seal any more.
Water then goes underneith and collects in a fold that leads straight into the cabin and it leaks along the fire wall on the inside. It does'nt help that the wipers tend to push water right in that area on their was down.
It gets even worst in winter because, water freezes undneith and lift the rubber clear off the glass plus, it can get dammaged when you scrape your windows...
Before you replace the part, you can check by lifting the carpet were it goes up the fire wall and put a garden hose on your windshield, if that is your problem, you'll see the water comming down the firewall. you might also see some rusty runs on the fire wall, also a good indication of this problem.
Hope it helps.
Darth Bimmer is offline   Reply With Quote
