Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 01-22-2009, 07:43 AM   #1
'busa
'busa's Avatar
My Ride: E90 335i (sold)
Connecting PC to HDTV
The way I'm planned on doing this: TV hung on the wall in one room, PC in the other room on the other side of the wall. Use DVI-HDMI to connect PC to TV for video... this is where I start questioning my plan... connect audio to PC speaker AND tv by using a splitter.
Two concerns:
1. Will I be able to use a splitter successfully for this purpose?
2. Can I plug in an DVI-HDMI cable that doesn't carry sound and ADD audio cables?
My TV model is TH-50PZ80U. Thanks!
'busa is offline   Reply With Quote
Old 01-22-2009, 08:22 AM   #2
impulse90
My Ride: .
The splitter shouldn't pose any issues. As for your other question, I would assume you wouldn't be able to do this unless there are RCA inputs in the same bank as the HDMI input.
EDIT: After reviewing a few photos of your set, it appears that your goal could only be met by using the front inputs. Maybe check the menu and see if it allows for alternate audio input while in the HDMI channels. Hell, it may pull audio from the RCA in the back regardless. RTFM!!
2nd EDIT:
HDTV Capability HDTV Tuner Inside
Connectors SD Card Slot
HDMI Input: 3 (1 front)
Analog Audio Input (for HDMI): 2
Composite Video Input: 2 (1 front)
S-Video Input: 2 (1 front)
Audio Input (for Video): 2 (1 front)
Component Video Input [Y, PB(CB), PR(CR)]: 2
Audio Input (for Component Video): 2
Composite Video Output: 1
Audio Output: 1
Digital Audio Out: 1
impulse90 is offline   Reply With Quote
Old 01-22-2009, 09:10 AM   #3
'busa
'busa's Avatar
2nd EDIT:
Audio Output: 1
Is that what I need?
Looking at the manual, it leads me to believe this could work for me:
Old 01-22-2009, 09:17 AM   #4
impulse90
My Ride: .
yeah, you'll connect your 3.5mm phone plug to RCA cable to one of those.
Old 01-22-2009, 09:29 AM   #5
'busa
'busa's Avatar
Awesome. Thanks. Sometimes I just like getting a bit feedback.
Old 01-22-2009, 09:46 AM   #6
John_Peters
My Ride: 2001 325i
DVI does not carry any sound at all, so you will not have to worry about that.
John_Peters is offline   Reply With Quote
Old 01-22-2009, 09:59 AM   #7
'busa
'busa's Avatar
I know. I wasn't sure that there is a connection between the HDMI input and the analog audio input. In other words, I wasn't sure that when I turn to HDMI 1 input, that I would get the sound from the audio input. According to the manual and the pic I posted, it's possible.
Old 01-22-2009, 10:04 AM   #8
The Jerk
My Ride: E46 M3
This may help... I've discovered that some high end HDMI switching amps do not allow you to supplement a non-audio HDMI signal with sound from RCA inputs. It's either 100% RCA, or 100% HDMI. Best way is to simply get the equipment from a store (with no restocking fees) and try it out.
As for adding audio to a DVI-HDMI cable, do you mean that you would cut/solder into it? I wonder if you can do that... tap in an RCA analog signal, or if it has to be digital with a certain impedance.
The Jerk is offline   Reply With Quote
Old 01-22-2009, 10:10 AM   #9
'busa
'busa's Avatar
There's no equipment to get other than an audio cable splitter maybe. I have the PC and I have the TV. It's just that, as it's setup now, I can't connect them, but I will be able to soon.
They sell DVI-HDMI cables. The image posted above leads me to believe that the TV will output digital video with analog audio if connected with an HDMI or DVI-HDMI cable and audio (L&R) cables.
Old 01-22-2009, 10:22 AM   #10
The Jerk
My Ride: E46 M3
You are trying to get your computer's audio/video outputted to your TV, correct?
Old 01-22-2009, 10:24 AM   #11
'busa
'busa's Avatar
Right.
Old 01-22-2009, 10:36 AM   #12
The Jerk
My Ride: E46 M3
HDMI does not seem to like "playing well" with RCA audio. Even if your TV has RCA audio input jacks AND HDMI available for, say, "Video 1"... they don't seem to work together. HDMI takes over! Hopefully my explanation makes sense...
You may need to resort to component (or s-video) to get both audio & video from the computer onto that screen.
At least, this is what I had to do with my setup. When the TV sees that the video portion is coming from HDMI, it won't accept any other audio input. I experience the same thing with my TV and receiver, so I am guessing this is "the way it is".
Old 01-22-2009, 10:46 AM   #13
'busa
'busa's Avatar
Always an option, although not the preferred one.
That was my fear, but doesn't the illustration I posted above claim otherwise?
I'll give it a try.
Old 01-22-2009, 10:55 AM   #14
The Jerk
My Ride: E46 M3
. . . That was my fear, but doesn't the illustration I posted above claim otherwise? . . .
One would think so, however, this did not work on my TV (which I admit is a "cheapo")... and did not work on my receiver (which is $$$).
Old 03-04-2009, 04:15 AM   #15
BruceWonder
My Ride: 2011.5 E92 M3
you can buy the splitter and connect it to your tv w no problem but i read on avsforums that most people just use vga cables. i connect my xpc pc with vga for picture and use an optical cable for sound. looks just as good as my dvd player which uses a belkin silver series hdmi cable
BruceWonder is offline   Reply With Quote
