Thread Tools Search this Thread Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Old 01-22-2009, 08:28 AM   #1
mintimperial
My Ride: 2003 530i Sport
Red face VANOS...What the hell is it? (and do I have one)??
Hi Guys, I know youre all gonna be groaning at this one....so I apologise in advance.
Ive searched the forums here and found people talking about their VANOS, but no one really explains what it is and what it does!!!
Do i have one in mine? (1999 318i SE)
1st Bimmer so i'm totally perplexed as to what this thing does, how to know its in need of a seal or repair etc and what improvements will be gained from a little clean and refurb
Could someone enlighten me?
mintimperial is offline   Reply With Quote
Old 01-22-2009, 08:33 AM   #2
Autobot325i
My Ride: 2003 325i E46
Send a message via AIM to Autobot325i
http://www.usautoparts.net/bmw/technology/vanos.htm
and from the people who made our cars
http://www.bmw.com/com/en/insights/t...ble_vanos.html
***NEW UPDATE***
1985 318i E30
Autobot325i is offline   Reply With Quote
Old 01-22-2009, 08:43 AM   #3
mintimperial
Thanks for that....kinda made some sense!
How do i know If it could do with new seals? What does the car do?
Old 01-22-2009, 09:06 AM   #4
Autobot325i
tons of info on this...do a search on vanos
/kill
***NEW UPDATE***
1985 318i E30
Old 01-22-2009, 09:43 AM   #5
mintimperial
I agree that there is a ton of info. if you do a search as I stated i had. there is not however a laymans guide to what the hell the vanos does when its broken and how to know if it needs repair!!!
Old 01-22-2009, 09:48 AM   #6
02m3csl325
My Ride: is Stage 2 AWD!
Guess I'll add to it while I'm in here, do all 3's after 1997 come with double vanos or is this just the m?
02m3csl325 is offline   Reply With Quote
Old 01-22-2009, 09:56 AM   #7
nathancarter
My Ride: 02 330i
http://www.beisansystems.com
make with the clickin' for an explanation of the causes and symptoms of failed VANOS seals.
nathancarter is offline   Reply With Quote
Old 01-22-2009, 02:43 PM   #8
mintimperial
OK, finding this difficult, my engine is a M43B19. Vanos or no Vanos?
Old 01-22-2009, 04:43 PM   #9
Rajaie
My Ride: 528i 06/00
Vanos is a hydraulic actuator. It's part of the engine variable valve timing system. It's a metal component that mounts on the front of the engine head and connects to the camshafts and camshaft sprockets. Its job is to physically change the relative rotational position of the camshafts to the crankshaft.
Your 318i 4 cylinder engine does not have a vanos. The standard i6 double vanos is on all the E46 6 cylinder (non-diesel, non-M3) cars (323, 325, 328, 330). All of the double vanos units have failed seals and replacing them will provide significant performance improvements and improved fuel consumption.
Hope this helps.
Rajaie is offline   Reply With Quote
Old 01-22-2009, 05:50 PM   #10
mintimperial
Hope this helps.
Thanks that reall helps. Guess I should stop worrying about it as I dont have one lol
Old 06-13-2010, 01:31 PM   #11
bernek
My Ride: 318 e46
Hope this helps.
VANOS on: 318i (facelift 1995 cm3 143HP) 320i 323i 325i 328i 330i
bernek is offline   Reply With Quote
Old 06-13-2010, 01:46 PM   #12
TallTravel
My Ride: E46/2
Hope this helps.
When my mechanic replaced my VANOS (330ci, manual, 2001) it significantly increased power and acceleration at all speeds. I am so glad they found it and replaced it.
OP, wait until they start talking about Guibo's.
TallTravel is offline   Reply With Quote
Old 06-13-2010, 02:37 PM   #13
miggynuez
My Ride: 2003 2.0L 318i
Hope this helps.
This is wrong. The N42 (1,995cc 143HP) motor has a Vanos...
The link posted by autobot even shows the N42 motor as an example...
"Take the first step in faith..."
"Anything with t*ts or wheels will give you problems..."
miggynuez is offline   Reply With Quote
Old 06-13-2010, 03:43 PM   #14
02gtstang
My Ride: 2005 zhp coupe
vanos is basically like v-tec if you know what that is, or vvt
2001 325i sport 5spd topaz blue R.I.P.
2005 330ci zhp 6spd black on black
02gtstang is offline   Reply With Quote
Old 12-09-2011, 11:05 PM   #15
InterlagosBlau
My Ride: 2001 325Ci
What did your mechanic charge/what would it cost me to get a new one/rebuild mine in a 2001 325Ci?
If you can't be good, be good at it!
InterlagosBlau is offline   Reply With Quote
Old 12-10-2011, 12:13 AM   #16
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
You don't want a rebuilt one. You just want the seals. A rebuilt one will still come with the faulty seals
Old 12-10-2011, 12:15 PM   #17
InterlagosBlau
My Ride: 2001 325Ci
Ok. How much would it cost to get the new seals on one? Or how hard of a DIY is it? I have some mechanical skills...
Old 12-10-2011, 12:56 PM   #18
Geo31
Ironman
My Ride: 98 M-Z3, 01 325iT
It is NOT like v-tec. V-tec not only changes cam timing, it employs a separate set of cam lobs to alter lift as well.
Vanos only alters cam timing.
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Brag: For the rest of your life
Geo31 is offline   Reply With Quote
Old 12-10-2011, 01:00 PM   #19
Geo31
Ironman
OP, search Wiki....
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Old 12-10-2011, 02:27 PM   #20
VonGeiss
My Ride: 2002 m3
Is there a difference in the vanos between the m54 and s54? they look different on the outside.
2002 Carbon Black ///M3 - current
2002 Stahlgrau ///M3 - RIP
2001 325i - sold
Instagram: @VONGEISS
VonGeiss is offline   Reply With Quote
vanos
