Old 01-22-2009, 10:53 AM   #1
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Power steering pump rebuild?
I finally traced down my chirping noise. It seems that the shaft in my power steering pump has about 1/4 inch of play. I haven't had any luck finding a rebuild kit. I'm guessing everyone just replaces the pump, eh?
Any suggestions before I shell out cash to Autozone?
Old 01-25-2009, 07:10 PM   #2
AlphaVortex
My Ride: jalopy!
Depending on which pump you have (the 20 or the 30) here are some rebuilt ones for cheap:
http://www.partsamerica.com/ProductD...tNumber=215350
or
http://www.partsamerica.com/ProductD...pe=251&ptset=A
Just enter your zip code and it should pull them up.
I'm pretty sure those are cheaper than the ones you can buy anywhere else, as they are rebuilt.
AlphaVortex is offline   Reply With Quote
