Old 01-25-2009, 11:12 AM   #1
GoingNuts
Just Nuts
My Ride: 2004 330Ci
Dumb rear fog lights
There was fog a couple of weeks ago. So I thought I'd use my fog lights front and rear. One of the rears appeared to be broken. So today I got round to fix it.
Symptoms: left rear fog not working
Ahhh, maybe bulb was blown.
WTF. two bulbs on the right. But only one on the left ???!!!
It's now obvious that was how the rear fogs were supposed to be, and nothing was broken. Feeling a bit sheepish, I looked around to see what else I could do. I found lots of cabling on the trunk lid that could be source of rattles, and the bump-stop for the lid wasn't optimal. So I taped up everything and adjusted everything. Now I am absolute sure there could be no noises from the trunk lid. This wasn't what I set out to do. But it was satisfying fixing up the very last place on the rear of my car that could squeak or rattle.
ID:	299878   Click image for larger version
ID:	299879   Click image for larger version
GoingNuts is offline   Reply With Quote
Old 01-25-2009, 11:20 AM   #2
AndrewIndy
My Ride: 2005 Imola 330Ci ZHP
We don't have rear fogs here in the states, but I had a SAAB with a rear fog light (only one), but it was only on the left, not the right. Perhaps, if there are two fog lights it could be confused with brake lights, especially if someone cannot see you well in the fog?
AndrewIndy is offline   Reply With Quote
Old 01-25-2009, 11:35 AM   #3
bimmerboy330
My Ride: Porsche 911 996
Does any one know where I can get the part number for the switch to activate a rear fog. Or is this something I need a more then just a swich for?
EUROPROJEKTZ
bimmerboy330 is offline   Reply With Quote
Old 01-25-2009, 11:55 AM   #4
Sack
My Ride: E46 M3 Blk/Blk
Audis have 2, BMW has 1 rear fog on the drivers side by design, as you well know now. =]
If you want the OEM switch, and the discrete cluster illumination, you need to get a euro faceplate. Faceplate only. If you have a Sedan, and are in the US, you are SOL (BMWNA sucks) on activating the rear fog if you have adaptive brake lights.
Jason at Tischer (getbmwparts.com) set me up with my new LCM, I did the OEM LED retrofit so I bought the whole assembly. You can, just buy the faceplate though.
You also need a sedan bulb carrier, it has two light sockets. Left for side for LHD, right side like original poster for RHD, or you can dremmel out your coupe one. Carrier was <$15 bucks so I didnt bother to f with the dremmel.
Oh, and depending on the year, you may have to run a wire from your deck lid to pin 49 on your LCM (for coupes).
LCM assembly 61-31-9-133-021 (part is superseded and you only need the faceplate)
Bulb carrier 63 21 7 165 743
I have xenons
WTB: Real CSLs, can be rashed, I want to powdercoat, must be true
Sack is offline   Reply With Quote
Old 01-25-2009, 01:33 PM   #5
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
I think the original European idea of OEM rear fog is to have ONE REAR FOG LAMP not two. That is simply what you have there or some lazy SOB never finished the complete rear fog DIY. The DIY Rear Fog Light modification that we have here in the USA usually incorporates putting in two rear fog lamp brackets so you get both rear fogs going for the effect.
delmarco is offline   Reply With Quote
Old 01-25-2009, 03:05 PM   #6
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
yes it it only one on most cars such as porsche, bmw, and mercedes
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 01-25-2009, 03:32 PM   #7
Sack
Nope, BMW vision was one rear lamp not two. Europe's vision, ECE 38, called for ONE OR TWO rear lamps, required. ECE R48 specifies that the rear fogs must be apart from the brake lights.
Obviously, two lights are better than one for visibility because your brain needs two light sources to triangulate the distance. This is also why cars have two headlights, two tail lights.
In North America, rear fogs are not required but permitted.
Old 01-25-2009, 04:24 PM   #8
delmarco
Uhm...what is BMW vision and Europe's vision?
EDIT: I'm guessing you mean "version".
Old 01-25-2009, 09:57 PM   #9
harry_sangha
My Ride: 330i
Your car will only have one. BMW use this to identify on what side to overtake the car. With you being in London,thats why it is on the right hand side. There are only a few exception car manufactures who put in two.
harry_sangha is offline   Reply With Quote
Old 01-25-2009, 10:01 PM   #10
M3_GTR
My Ride: hates driveways
is there a way to get two back fog lights, a part or anything ,i reckon it looks hot with both on
FOR SALE!
M3_GTR is offline   Reply With Quote
Old 01-25-2009, 10:06 PM   #11
delmarco
its oem
Old 01-25-2009, 10:08 PM   #12
Ring Taxi
My Ride: @MRM5MAN
Send a message via AIM to Ring Taxi
90% of the time cars only have one rear fog lol..
I really do wish I had a rear fog, that'd be sick.
Ring Taxi is offline   Reply With Quote
Old 01-25-2009, 10:08 PM   #13
M3_GTR
yeah i know, but isnt there a part to change it?
FOR SALE!
Old 01-25-2009, 10:15 PM   #14
delmarco
uhm....
Its mad easy!
There is like 3 or 4 DIYs in the DIY section for adding rear fogs to E46 BMWs.
You just need a long wire and the brackets which go for like $10 at the stealership.
SEARCH and ye shall find!
Old 01-26-2009, 11:20 PM   #15
Sack
No I meant vision: an experience in which a personage, thing, or event appears vividly or credibly to the mind, although not actually present, often under the influence of a divine or other agency
Prior to forming the EU code, they had some idea of what they wanted. Sry I cant write it in crayons.
Old 01-27-2009, 12:25 AM   #16
MARKS330I
My Ride: 03 330i
maybe im just a retared but im almost positive i have 2 rear fogs on my 03 330i.. ill post a pic tomarrow.
Ig: joshmarks_
MARKS330I is offline   Reply With Quote
Old 01-27-2009, 06:11 PM   #17
MARKS330I
My Ride: 03 330i
i don't have a rear fog light switch either, they just come on when i urn on my running lights.
Old 01-27-2009, 06:27 PM   #18
rorschach
My Ride: '01 318i
Those aren't fog lights.
rorschach is offline   Reply With Quote
Old 01-27-2009, 08:29 PM   #19
MARKS330I
My Ride: 03 330i
oh, my bad ill shut up now
Old 01-27-2009, 09:29 PM   #20
dmz
My Ride: M3
I hate rear fog lights. All it does is to cause glare and anoy other drivers.
dmz is offline   Reply With Quote
