flywheel question.. need answers - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-30-2009, 09:56 AM   #1
CUS330CI
My Ride: 01 BMW 330CI
so im going to be putting my new clutch back in soon... heres my question...
my flywheel looked pretty good when i took it out. it did have some hot spots on it but no cracks or anything really bad. i brought it to a machine shop by my house that does all my work. they didnt resurface it, but they just crosshatched it to break the glazing and spotting.
i've read all over the forum about how it cant be resurfaced, and it has to be replaced. I've also come across threads where guys say they just got it machined..... soo... does it even really matter???
CUS330CI is offline   Reply With Quote
Old 01-30-2009, 10:56 AM   #2
CUS330CI
oh yea... 135K miles
Old 02-07-2009, 10:12 PM   #3
IFX
My Ride: M156
You mean your rotors?
I'm confused, but if regarding rotors... You shouldn't turn them.. it's only a temp fix.
Just buy new rotors and be done with it.
IFX is offline   Reply With Quote
Old 02-08-2009, 12:45 AM   #4
TxZHP04
My Ride: ESS TS2+ ZHP
No, he clearly stated that he was talking about his flywheel.
Old 02-12-2009, 08:35 PM   #5
F1004fun
My Ride: '02 330Ci
I did the UUC moderate lightweight steel flywheel with the M5 clutch organic compound, it turned out nice. The final weight with the lighter wheel but heavier clutch is a little less then the stock setup which is good, but the control you gain with a predictable clutch is great. One of the best upgrades I did for overall drive ability of the car
I had very little gear chatter at idle in neutral with the Redline MTL, but I have since switched out to the Redline D4 as per their recommendation and the shifting is way better but I have just a touch more chatter at idle due to the thinner fluid.
F1004fun is offline   Reply With Quote
