Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 01-31-2009, 10:52 PM   #1
imolazhp_ci
imolazhp_ci's Avatar
My Ride: metro.
speaker wire gauge?
quick question. i'm setting up my home theatre system in my room, not super duper hi-fi or anything. why AWG speaker wire will suffice? is 16 AWG okay? no line will be longer than 15 ft. thanks.
2005 Imola Red 330Ci ZHP- SOLD
2006 Sebring Silver S2000- SOLD :(
2007 Silver Gray M Coupe- SOLD :'(
imolazhp_ci is offline   Reply With Quote
Old 01-31-2009, 11:06 PM   #2
GlockMan
GlockMan's Avatar
My Ride: Suburban LT 4x4
good quality 16 is fine under 200w. You could always double it up if you wanted.
I usually use 14 but 16 multistranded is fine for most applications, especially under 200w or $800 receiver.
!!! ROLL TIDE ROLL !!!
National Champs: 1925, 1926, 1930, 1934, 1941, 1961, 1964, 1965, 1973, 1978, 1979, 1992, 2009, 2011, 2012, 2015, 2017?
Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI on a BMW board since 2005.
2016 Honda Accord Sedan V6 Touring (wife)
2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD
1968 Ford Mustang with Polk/ADS (my first car)
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
GlockMan is offline   Reply With Quote
Old 01-31-2009, 11:10 PM   #3
imolazhp_ci
My Ride: metro.
well i trust your advice for the most part.
i am using a Sony STR-DA3200ES ($1000/ 120w x7) connected to Def. Tech Procinema 60.
and was planning on buying this...
http://www.monoprice.com/products/pr...seq=1&format=2
i disagree with you as far as HDMI's as you know, but I know speaker wire requires a bit more precision and has a much greater variance in quality between brands, construction, etc... tell me what to buy.
Old 02-01-2009, 01:17 AM   #4
GlockMan
GlockMan's Avatar
High strand count is really more important than brand.
Since cost is not that much more for such short runs, I would buy 14 or 12 personally.
The longer the run, the more important the gauge, but for pennies more per foot, you will know that wire is not your weakest link.
Run all speaker wire lengths the same regardless of their placement for best time allignment and volume consistancy.
I ran 14/4 to each of my speakers then double up the conductors.
90% of my HDMI quality argument is based on installation in a high end residence. Rarely, do we run HDMI less than 25 ft and rarely would the cost savings justify us having to re-run an HDMI if we got a bad one. Rarely, do we not have some type of HDMI commuincation handshake issue with some piece of the customer's gear. At $100 per labor hour, the customer really doesnt save enough to justify using a $50 cable instead of a $250 on $25K project. Make sense?
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
Old 02-01-2009, 01:30 AM   #5
Dreamliner330
My Ride: 330xi
+1.
Buy what makes sense...the thicker the better, but if its 2x as much to go from 14ga to 12ga...then do the math...
Dreamliner330 is offline   Reply With Quote
Old 02-01-2009, 02:05 PM   #6
imolazhp_ci
My Ride: metro.
thank's guys.
