Old 02-01-2009, 05:13 PM   #1
NicB.
My Ride: 2000 BMW 328i
FIX: Broken/Loose Volume/Power Knob for Stock Head Unit
How many people have this problem where they cannot turn on/off their head units because the power button is broke and loose? If there are enough people who need the fix, I'll post to Youtube, otherwise, I'm going to type up a DIY a little later. Let me know...
NicB.
NicB. is offline   Reply With Quote
Old 02-01-2009, 05:36 PM   #2
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
mine is loose but works
/_________\
OO=[][]=OO
330i ZHP is online now   Reply With Quote
Old 02-01-2009, 05:55 PM   #3
AlphaVortex
My Ride: jalopy!
I just took it apart and super glued the knob bracket back on.
AlphaVortex is offline   Reply With Quote
Old 02-01-2009, 06:47 PM   #4
ToddInLou
My Ride: 2001 330CiC
My volume knob doesn't work like it should. When you try to turn it either way it doesn't really work well so I just use the steering wheel controls or turn it off and listen to the motor.
ToddInLou is offline   Reply With Quote
Old 02-01-2009, 10:41 PM   #5
BadBoostedBmwM3
My Ride: 323i & e36 Turbo M3
Mine does the same... I'd be interested in a DIY!!
BadBoostedBmwM3 is offline   Reply With Quote
Old 02-01-2009, 10:56 PM   #6
e46_619
My Ride: always breaks down!
Send a message via AIM to e46_619
same problem too!
e46_619 is offline   Reply With Quote
Old 02-01-2009, 11:46 PM   #7
w0w
My Ride: 00 323i
mine is messed up too, if i scroll it to change the volume it goes haywire
daron
w0w is offline   Reply With Quote
Old 02-02-2009, 12:04 AM   #8
mxli330ci
My Ride: '01 330Ci Topaz Blue
Send a message via Skype™ to mxli330ci
My Volume knob does the same... I thought I was the only one. I've been using the steering controls since I got the car.
mxli330ci is offline   Reply With Quote
Old 02-02-2009, 12:05 AM   #9
w0w
My Ride: 00 323i
haha me too, i just got over it lol. but it always comes to bite me in the ass when a girl gets in my car and tries to jack my volume up and it goes nuts
daron
Old 02-02-2009, 07:37 AM   #10
NicB.
Okay, well, I can't promise it's the same issue, but I'll get something worked up. That said, it'll be a day or two...been slammed at work. Stay tuned...
Old 02-02-2009, 09:04 AM   #11
Alb89n
My Ride: Goes places
+1
I find that pushing up and turning makes it work a little better.
Alb89n is offline   Reply With Quote
Old 04-28-2009, 12:54 PM   #12
Blind32
My Ride: '07 Z4MC
Send a message via AIM to Blind32 Send a message via Yahoo to Blind32
I also Would like to see a DIY for this. Thanks!
Blind32 is offline   Reply With Quote
Old 07-21-2009, 03:57 PM   #13
KGMonteith
My Ride: 2002 325Cic
I'd also like to see a DIY fix -- my '02 business cd volume knob is loose but still functional.
KGMonteith is offline   Reply With Quote
Old 08-24-2009, 11:40 PM   #14
miclipse
My Ride: 330i
Fix: Broken/Loose Volume/Power Knob
Same issue on E46 330i: At first knob is just loose but fully functional then one good push and the volume pot pushed back inside.
Root Cause: There are two screws that hold the volume pot assembly to the radio front control assembly. These loosen over time. Pushing the knob will cause the top boss to crack and the screw to come out. (Look for it inside before it shorts something.)
Repair:
1.Pull out the radio. (see other threads for this)
2. Remove the entire front control assembly, NOT the black plastic face plate. Here's how >Two screws top >one screw each side > 3 smaller screws on bottom that secure the shield. >Under shield two hidden screws toward the front down inside two small round openings.
3.Carefully pry the front control assy off WITHOUT damaging the flex circuit.
If you can attempt a repair of the boss without disconnecting the flex that would be best but chances are you will need access to the lower screw which can only be accessed by then removing the shield that covers the pcb on the back of the control assy. To remove the flex, flip the brown latch forward toward the flex and the flex should pop free. When reconnecting this flex hold the control assembly close to the radio so you don't pull too hard on the flex. Then by reaching in from the side with a pair of needle nose grab the flex and move it into the connector with the brown lever partially down(not up). While the flex is in the connector use a small flat screw driver
to flip the latch back and upward. This will pinch the flex into the contacts. This flex(ZIF) connector is a bit tricky and you might want to examine it closely to see how it works.
I used super glue and baking soda to fix the boss. The lower boss was ok so I just added some super glue to the threads and screwed it back in. I also snapped off a clothes pin and gently wedged it in behind the volume pot circuit pcb and a heat sink.
Good luck.
miclipse is offline   Reply With Quote
Old 08-24-2009, 11:54 PM   #15
mikeblack330ci
My Ride: JB 330ci
i just yanked on the knob till it came off.Then i pushed it back on lightly and it stays.if you push too hard it will "bottom out" but it dosent need a whole lot of pressure to turn off and on.its a temp fix.
mikeblack330ci is offline   Reply With Quote
Old 08-27-2009, 09:13 PM   #16
miclipse
My Ride: 330i
"bottom out" I recommend you fix it soon while you still might have the screw bosses intact.
Old 09-15-2009, 02:50 PM   #17
km4n
My Ride: 2002 325i
Alright so my volume knob snapped such that it wont power up. The volume aspect seemed fine as it will go scroll left and right fine but when you press it it will just push back.
FIX: Super glued the white plastic portion. See attached pictures. I did not have to take anything apart just did it from the opening at the top.
Tools: Super glue and a toothpick
Time to fix: 5 min once the deck is hand.
ID:	331546   Click image for larger version
km4n is offline   Reply With Quote
Old 09-15-2009, 02:55 PM   #18
jose325i
My Ride: 08 BMW 135i
lol my old headunit did this. I heard a loud crack and it never wanted to power off again. Turning the knob left/right worked, but sometimes I would try to increase the volume and it would decrease the volume instead. Then it stopped reading disks so i just bought another OEM headunit from someone here on the forum lol
jose325i is offline   Reply With Quote
Old 09-17-2009, 07:53 PM   #19
Makakio
My Ride: 03 325i sport
Thumbs Up Haha hooo!
THANKS FOR THIS! Just got my stereo out and that DIY was excellent help!
But I have a question: I'm having difficulty with your instructions on disassembling the stereo. Found the two screws top and a couple on the bottom, but can't find hidden ones and I don't understand if the shield and the flex are the same thing?
Maybe we can chat through, or if you took a pic, or maybe you can steer me to another place? I'd be grateful.
Repair:
Good luck.
Makakio is offline   Reply With Quote
Old 11-01-2009, 01:27 PM   #20
vtrac
My Ride: 2001 330Ci
Repair:
Good luck.
Thanks for this. I just did this fix, but unfortunately when I was taking the radio apart, I knocked loose some spring that I can't figure out where it goes. Now my CD player is broken, but at least now I can turn on the power.
vtrac is offline   Reply With Quote
