Old 02-03-2009, 02:35 AM   #1
SpeedDemon
My Ride: E92M3 E46ZHP Golf7R
Cool How much do these items improve 0-60 acceleration times?
I'm wondering how much these two mods make the car faster in 0-60...
If the ZHP could originally do 0-60 in 5.6 seconds then how much faster do the following items make the car do a 0-60 sprint?
1. LSD
2. 3.46 FD from a 3.07
3. Stickier tires
Thanks!
SpeedDemon is offline   Reply With Quote
Old 02-03-2009, 12:49 PM   #2
tchavis1989
My Ride: 2004 BMW 330i
Send a message via AIM to tchavis1989 Send a message via Yahoo to tchavis1989
they'd shave a couple points of a second off that 5.6 0-60 time and you can buy a 3.46 lsd ...
regards,
tyler
tchavis1989 is offline   Reply With Quote
Old 02-03-2009, 04:22 PM   #3
SpeedDemon
I have a 3.46 LSD with some of the stickiest street tires around
It's just that it's winter time (cold) and there's nowhere that I can accurately measure my 0-60 this time of year so I'm wondering what people's experience is with these mods? I mean would it shave off .2? .1? .3?
Old 02-03-2009, 04:25 PM   #4
SeanC
My Ride: 330i
3.46 diff would actually decrease your 0-60 time, because you cannot achieve 60mph without shifting to the 3rd with the 3.46 diff... It would improve 1/4 mile numbers though.
LSD doesn't have any effect on linear acceleration.
Stickier tires would help a great deal, since at the time of take off, friction is the dominant force to get your car going rather than its horse power or differential.
Black Sapphire MetallicNatural BrownSilver Cube e46 330i ZHP/6MT - Sold
HellrotDove Grey e36///M3 - RIP
Black Sapphire MetallicNevada BrownDark Bamboo e70 X5 xDrive4.8
Alpine WhiteCoral RedAluminum f30 328i Sportline/6MT
Imola RedBlackBlack Aluminum e46 330i ZHP/6MT
SeanC is offline   Reply With Quote
Old 02-03-2009, 06:55 PM   #5
bimmerboi19
My Ride: 05 M3 ZCP
if you got a 3.38 diff that would help your 0-60 b/c you would hit 60 at the top of 2nd gear.
bimmerboi19 is offline   Reply With Quote
Old 02-03-2009, 06:59 PM   #6
JJR4884
My Ride: BMW
accelerating you are correct, however LSD would jump off the line a little quicker due to the face that power is going equally to both wheels, rather than one....
JJR4884 is offline   Reply With Quote
Old 02-03-2009, 07:54 PM   #7
SeanC
My Ride: 330i
Lsd never distributes the power equally to both wheels. There is a certain amount of "locking" while taking a curve, so that the outer wheel gets "some" of that power, as well as the inner one. While accelerating on a straight line, it doesn't matter if you have an lsd or an open diff.
Old 02-03-2009, 11:39 PM   #8
SpeedDemon
It seems like an LSD would have to help off the line. Of course you are still going to slip a wheel, but wheel slip won't be as detrimental as it would be with a Open Diff. Wheel slip with an LSD will cause the other wheel to get the rest of the torque. It seems like this would be especially true with an LSD like my Torsen (Quaife) that is auto-torque-biasing (ATB) all the time.
Yes, a ZHP does have a 6800RPM redline, but the rev limiter doesn't kick in until just after 7000 RPM. A ZHP or any E46 that has a flashed ECU can hit 7000 RPM in 2nd and bounce off the rev limiter at which point it would be doing 60.25 MPH with a 3.46 final drive. Check out the calculation I did over on my330i.com:
Old 02-09-2009, 01:00 AM   #9
jsonli
My Ride: 04 330ci TiAg
LSD does little for us in this regard since we're aren't getting that much wheelspin. Same with tires, if you aren't getting much wheelspin now, I can't see better tires helping.
Getting a good launch is probably the xfactor.
jsonli is offline   Reply With Quote
Old 02-09-2009, 01:30 AM   #10
johnnyg
My Ride: 2003 330Ci
ZHP 5.6 to 60 is a little ambitious. That number is more than a half second quicker than my 330 CI AT and within .5 of my 08 G37S all while giving up nearly 100 hp to the G. These threads are interesting but wildly inaccurate, fun to discuss though. Cheers!
johnnyg is offline   Reply With Quote
Old 02-09-2009, 04:07 AM   #11
SpeedDemon
0-60 in 5.6 has been achieved by multiple magazines.
Your Steptronic slows the car down by at least a whole second and the only reason that it comes close to the manual time is due to it having the shorter 3.46 gearing vs. the manuals 2.93 or 3.07 in a ZHP.
You G37S is heavy and the horsepower means nothing if it isn't developed at the right points in the power curve.
Old 02-09-2009, 10:25 AM   #12
SeanC
My Ride: 330i
FYI, 0-60 was done in 5.4 seconds and 1/4 mile in 14 seconds flat by KrisL, on a %100 stock ZHP... When in doubt, use the search button.
Old 02-09-2009, 10:15 PM   #13
SpeedDemon
Any idea what his launch techniques were?
Old 02-09-2009, 10:23 PM   #14
SpeedDemon
Just wanted to add that I found it pretty easy to spin the wheels with the original tires.
Old 02-09-2009, 10:40 PM   #15
SeanC
My Ride: 330i
Launch at around 2700 rpm and shift as fast as you can. That was it IIRC... No DSC of course.
Old 02-09-2009, 11:05 PM   #16
TxZHP04
My Ride: ESS TS2+ ZHP
FWIW, the C&D video review of the ZHP coupe indicated their 5.6 sec was an estimated value.
Those were GTech Pro numbers, which I believe factors in a 1 ft rollout. You can add roughly 2 - 3 tenths for a standing start. And of course, you can always debate the accuracy of the GTech.
Old 02-09-2009, 11:36 PM   #17
SeanC
My Ride: 330i
^ I am sure those issues were debated in the past without any consensus, but I think 5.6 should be consistently doable
Old 02-10-2009, 08:37 AM   #18
TxZHP04
IIRC, KrisL only got below 6 sec on 1 out of 3 attempts. I know we're all pro drivers but 5.6 is a wee bit optimistic for most people. While it's not impossible, it would certainly be easier to achieve consistently in a car with more torque that would make nailing the perfect launch a little less critical.
