Old 02-04-2009, 10:11 PM   #1
tchavis1989
My Ride: 2004 BMW 330i
Send a message via AIM to tchavis1989 Send a message via Yahoo to tchavis1989
330i ZHP Clutch Job (Flywheel Options ... Single/Dual Mass)?
so i'm in the process of doing a clutch job on my 330i ZHP. i've already ordered my clutch kit from tischer bmw for $320 but the flywheel is what gets me ... $750! i understand that i have a dual mass flywheel which can't be re-surfaced and am wondering if i could put a single mass in it's place ... with that said if i can't what are my options as i want something that'll be just as light if not lighter than the supposently light weight flywheel which came stock on my car. also, will whatever flywheel you guys specify work in conjunction with my stock clutch kit in which i ordered? thank you for your time.
regards,
tyler
tchavis1989 is offline   Reply With Quote
Old 02-04-2009, 10:20 PM   #2
SeanC
My Ride: 330i
Kinda thread we long to see e46f.c... I want to know as well.
Sapphire Black MetallicNatural BrownSilver Cube e46 330i ZHP/ZCW/6MT - Sold
HellrotDove Grey e36 ///M3 - RIP
Alpine WhiteTanSand High Gloss e46 330i SunRoofLess/5MT
For Sale: $300 winter wheel/tire set (sport edition F7s and Dunlop graspics)
For Rent: RTAB Removal/Installation and Preload Tools
SeanC is offline   Reply With Quote
Old 02-05-2009, 07:32 AM   #3
TxZHP04
My Ride: ESS TS2+ ZHP
You don't want to use a stock clutch with any single mass flywheel. The stock clutch is a rigid hub meant to be used with a dual mass flywheel. If you switch to a lightweight single mass flywheel then you should utilize a sprung hub clutch. Either the clutch or the flywheel needs to be "sprung".
The "ZHP" flywheel is not lightweight. It's the same ~ 25lb dual mass used in all other e46 6-spds. It is, however, about 5 lbs lighter than the 5-spd e46 flywheel. The aftermarket LW flywheels are typically in the 8.5 - 11lb range. If you do some searching around the forums, you will find that most people also seem to report some level of transmission gear rattle when using a LW flywheel.
If you're set on going LW, cancel your clutch kit order and start over. The JB Racing + Clutchmasters FX100 combo is frequently recommended as are the UUC offerings.
Old 02-05-2009, 10:33 PM   #4
tchavis1989
mine does rattle when the car is turned off though unless i hold in the clutch? so ... i'm saying light weight
regards,
tyler
Old 02-05-2009, 10:57 PM   #5
TxZHP04
regards,
tyler
Yeah, I have the same stock flywheel and I'm familiar with the rattle when turning off the car. It doesn't rattle at idle though. The 25 lb stock dual mass is by no means lightweight and it neither responds nor rattles like a lightweight single mass... but feel free to call it what you like. Just be prepared for the constant corrections from other members.
Old 02-06-2009, 07:46 AM   #6
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: Evo, 330Ci, Xterra
Mine rattles when i turn my car off, too. It's a BMW thing.
^No longer looks like this
Buy my::
3.46 Differential
Coolant hard line
European Head Unit
Old 02-06-2009, 08:57 AM   #7
SeanC
My Ride: 330i
same here.
Old 04-12-2009, 12:43 AM   #8
jorg323
My Ride: 1999 323i
What's the difference between a single and double mass clutch?
18" Black ASA AR1 Rims | Yokohama Advan S4 Tires | Bilstein Sport Shocks | Eibach Pro-Kit Springs | Brembo Slotted Rotors | 6000k Xenons | 6000k P. Chrom. Angel Eyes | Eagle Eye LED Tail Lights | K&N FIPK CAI | M-Tech II Front Bumper | 35% Tint | Clear Corners | Matte Black Grille
jorg323 is offline   Reply With Quote
Old 04-12-2009, 10:26 AM   #9
TxZHP04
I think you mean single and dual mass flywheel.
http://www.europeancarweb.com/tech/0...els/index.html
http://www.schaeffler.com/remotemedi..._zms_de_en.pdf
Either the flywheel or the clutch should contain a damping mechanism (springs). For this reason, a dual mass flywheel will typically utilize a rigid clutch disc (no springs) and a single mass (all aftermarket lightweight flywheels) should utilize a sprung hub clutch.
Old 04-12-2009, 03:47 PM   #10
jorg323
My Ride: 1999 323i
Thanks for the explanation and links. And yeah, you caught me... I did mean to say flywheel.
