Old 02-05-2009, 01:32 PM   #1
pinoybmr3
My Ride: low and slow
Turn signal burned
Hi fanatics,
i installed my depo clear signal light with solaris bulbs for my sedan, after a week, i noticed my inner part of the signal lens closed to the bulb is burned (driver's side), my solaris bulb is working and is seated correctly since it is 180 degrees. what do you think is the problem? did the same thing happened to anyone here? feedbacks or comments will be appreciated. by the way, i called the sponsor, they said it is not replaceable because it is not a leaking problem or whatsoever, so burning is not included in the warranty i guess.
pinoybmr3 is offline   Reply With Quote
Old 02-05-2009, 01:36 PM   #2
pinoybmr3
picture of the burned signal light
Name:	clear signal 1.jpg
Old 02-06-2009, 09:49 AM   #3
pinoybmr3
looks like nobody experienced the same..
Old 02-09-2009, 03:21 PM   #4
djbradle
My Ride: 2002 325 xit
Happened to my stock passenger clear but that was the previous owner's problem passed on to me. I assume they did not install it correctly but i can;t be sure. It looked exactly the same as your depo though. I does have moisture because of it now.
djbradle is offline   Reply With Quote
