Old 03-25-2009, 08:16 AM   #21
xavi330i
My Ride: 2004 330i smg
Cool you fixed it.
I had a similar issue. A couple years ago, I noticed my brake lights would not come on until I press the brake pedal a couple inches. An adjustment was all that was needed on the brake switch.
xavi330i is offline   Reply With Quote
Old 03-25-2009, 10:56 AM   #22
mujjuman
My Ride: not an E46
Yeah but sucks that I had to dish out all the money just to figure out what it was. Next time I'll be smarter.
Good thing I didnt get in an accident due to my brake lights not working!
mujjuman
2003 325xi 5MT
Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP
sig by Solidjake
mujjuman is offline   Reply With Quote
Old 08-02-2009, 06:01 AM   #23
Xelo
My Ride: '01 E46 320i
Hello,
Could you please describe the "adjustment" procedure for the switch ? From what I've seen, it's a plastic carrier for some wires and the end of it it's designed to touch a little arm coming out of the brake pedal.
The switch is now "pushed" all the way to the end (towards front of car) and I still have the brake light warning on the dash. Do I have to pull it a little to the back of the car or how do you suppose to adjust it ?
Thanks.
Xelo is offline   Reply With Quote
Old 08-02-2009, 08:49 AM   #24
mujjuman
My Ride: not an E46
wait, what exactly is the warning? Does it say "BRAKE" or does it show a brake pad? Then you probably need new brake pads.
The switch is just for lighting the lights in the back, and for disabling the cruise control.
mujjuman
2003 325xi 5MT
sig by Solidjake
Old 08-02-2009, 12:40 PM   #25
Xelo
Yes, I am talking about the warning for tail lights. It's on - bulbs are fine, contacts are fine, did the double ground mode, warning's still there so it must be the switch.
Old 08-02-2009, 02:26 PM   #26
mujjuman
My Ride: not an E46
Are you using stock lights/bulbs, or those aftermarket LED drop-ins... because the aftermarket LED tails (some people call them eagle eyes i think) cause the "bulb is out" warning in the dash.
mujjuman
2003 325xi 5MT
sig by Solidjake
Old 08-02-2009, 03:24 PM   #27
Xelo
No... everything is stock.
There is no other cause for the warning (i've read every little bit of info on the net, tried every possible solution), I just wanna know how did you guys managed to adjust the switch, according to the posts above.
Old 08-02-2009, 04:21 PM   #28
mujjuman
My Ride: not an E46
kinda hard to explain..... its really easy though. you just pull/push on the blue part in your pic.
mujjuman
2003 325xi 5MT
sig by Solidjake
Old 06-04-2011, 03:19 PM   #29
styllzs
My Ride: 330 i
my brakes lightss dont come on at all could it be that switch?
styllzs is offline   Reply With Quote
Old 11-12-2012, 02:01 PM   #30
limpiabota809
My Ride: 330 XI
just had that same problem this morning someone broke pretty hard in front of me forcing me to press the brake pedal harder than usual, I felt the switch get pushed in when i broke hard and moments later the light indicating that the switch was messed up turned on, i got to work googled this thread and just moved the switch back in the correct placeand viola we are back to normal
PS (called a couple BMW dealers near me before attempting the adjustment quoted 50$ + tax)
limpiabota809 is offline   Reply With Quote
