///M3 Forum
Old 02-07-2009, 07:52 AM   #1
TigMik
My Ride: 2004 SMG M3
SMG judder in 1st gear. Help.
My smg m3 has started to struggle setting off in 1st gear. It judders and then picks up speed. Any one have a clue what it could be? Thanks
TigMik is offline   Reply With Quote
Old 02-07-2009, 08:44 AM   #2
realcompm3
My Ride: Your wife
Yeah that happens to mine too. Just easily step on the pedal when you are on 1st gear.
05 330CI ZHP
/// 11 M3 E92 ZCP- Sold
06 M3 ZCP Sold
realcompm3 is offline   Reply With Quote
Old 02-07-2009, 10:35 AM   #3
AllwaysLow
My Ride: 2005 CB SMG M3
Do you mean shutters like it's struggling to keep from stalling the engine? Or do you mean buck back and forth like a bronco?
Does it do it every single time?
AllwaysLow is offline   Reply With Quote
Old 02-07-2009, 10:47 AM   #4
gsh1234567
My Ride: 2003 E46 M3 SMG
Mine, too. It annoy the #$% out of me. Hope it is nothing serious. I also tried either to ease on the first gear or just drive more agreesively. Both work.
gsh1234567 is offline   Reply With Quote
Old 02-07-2009, 01:12 PM   #5
vicz84
My Ride: bmw 320ci
my m3 does the same, judders sometimes in first gear and even second sometimes, been told that a software upgrade can sort this out, hope its not the clutch on the way out, mine has done 62000 miles and have been told that clutches dont wear out that quick in a smg unless you use launch control, which i dont.
vicz84 is offline   Reply With Quote
Old 02-08-2009, 10:32 AM   #6
TigMik
Yeah, like its going to stall, it judders until it gets moving. It doesnt do it every time, but it is becoming more frequent.
Old 02-08-2009, 10:46 AM   #7
IFX
My Ride: M156
Might be the old common "jerk" from the SMG tranny.
IFX is offline   Reply With Quote
Old 02-08-2009, 11:08 AM   #8
AllwaysLow
Does it ever happen without touching the gas pedal, like when you're just sitting still? Or only when you first press the gas pedal? Does it happen more on hills?
Old 02-08-2009, 11:15 AM   #9
TigMik
Only when i touch the pedal, and it has done it once, quite bad, on a hill start.
Old 02-08-2009, 11:40 AM   #10
j-dog
My Ride: 06 m3 zcp
Does it act like the clutch is slipping? Like it is not grabbing? Mine does this only when cold for about the first 1-2 minutes of driving, and only in 1st. After that it is fine. It started at about 5000 miles and has not changed, now I have 26000. I am not worried about mine.
Have you tried an SMG reset?
http://forum.e46fanatics.com/showthr...ight=smg+reset
j-dog is offline   Reply With Quote
Old 02-08-2009, 11:41 AM   #11
AllwaysLow
Have you noticed that it goes away at the same rpm level every time? somewhere around 2000rpm?
Old 02-08-2009, 12:24 PM   #12
AllwaysLow
IMO, there are three possible causes: 1) clutch mapping, 2) airflow, or 3) fuel delivery.
If it goes away at the same rpm every time, then that would make me think it's the clutch mapping, for which there a two fixes that have worked for a lot of people. The first is free, and that's the SMG reset, which will reset the computer and allow the SMG computer to learn your driving style from the beginning.
1. Find a straight open road, and get up to about 40mph.
2. Shift into neutral.
3. Pull back on both paddle shifters for 5-10 seconds.
4. There will be no beep or indicator that it's been reset, you just have to trust the SMG gods.
5. Drive it like you always do.
The second fix is a software update from the dealer. My 05 SMG was hesitating in the lower rpm range and a software update helped me. If you're no longer under warranty then it will cost you to have it done. I believe they updated me with version 31.1, so they should be able to tell what version you have and update it if it's older than that.
A possible third fix is using sport mode, which has helped some people, but I don't really consider that a fix as much as a band-aid.
If airflow is the problem, then cleaning your MAF sensor is a cheap and easy fix, and should be done anyway even if you're not having a problem. Just get some MAF cleaner, remove the sensor, clean it, and reinstall it. And of course, check your air filter, but I doubt that's the problem.
If none of those help, the I would guess it's in the fuel filter, fuel pump, etc. But try everything else first.
Old 02-08-2009, 01:16 PM   #13
TigMik
It feels like it, yes. Why's that then?
Old 02-08-2009, 05:47 PM   #14
M-Power-3
My Ride: ///M-Powerd
check your intake or your MAF and clean it.
Photobucket
M-Power-3 is offline   Reply With Quote
Old 02-09-2009, 10:27 AM   #15
TigMik
Where's the MAF situated? Is it after the air filter box?
Old 02-09-2009, 01:15 PM   #16
AllwaysLow
This will work...
http://www.louv.tv/cars/m5/MAF/
Old 02-09-2009, 03:16 PM   #17
M3 Baddie
My Ride: 05 M3 SMG
it seems to be happening when i've driven mine after an hour or two... and i watch the rpm's drop under 1k maybe to liek 600 or 700 from a stop, then it picks up normally after the shudder.
///M3
M3 Baddie is offline   Reply With Quote
Old 02-09-2009, 05:29 PM   #18
Dirty B1
My Ride: 2002 BMW ///M3
My ///M just recently started doing it . Leads me to beleive somthing is wearing out. Wonder if clutch is starting to slip. Will have to go through all the other possibilities first
Dirty B1 is offline   Reply With Quote
Old 02-09-2009, 05:45 PM   #19
M3 Baddie
My Ride: 05 M3 SMG
im going to try the above posted with a smg reset. If it dosn't work im taking it in for a check up. I do think its clutch tho.
///M3
Old 02-09-2009, 09:31 PM   #20
NY Z Pilot
My Ride: 05' M3 SMG
launch control? we have this?
04' Silverstone 350Z 6MT - SOLD!!!
NY Z Pilot is offline   Reply With Quote
