///M3 Forum
Old 04-12-2013, 09:35 AM   #1
sean vaz
My Ride: 2002 m3 convertible
M3 coil packs
Hello, I own a 2002 M3 that has around 91,000mi and when it drives, it has like a stutter on acceleration. I think it might be a coil pack. As i've heard that they are very common. Does anyone have any ideas to which one, has anyone come across this problem before? Aside from going to the dealer and dropping a grand to get it fixed, does anyone have any other options?
sean vaz is offline   Reply With Quote
Old 04-12-2013, 09:38 AM   #2
choxor
My Ride: JDM
A dead coil pack will be very obvious, it'll also be accompanied by misfire codes.
WHat codes do you have.
Old 04-12-2013, 09:43 AM   #3
sean vaz
the check engine light came on, but I dont have a scanner to check the code.
Old 04-12-2013, 09:50 AM   #4
sean vaz
coil packs
Does anyone know if they are hard to change? I was a mechanic, so i know my way around an engine
Old 04-12-2013, 09:58 AM   #5
choxor
My Ride: JDM
No, they are not hard to change.
Step 1: Scan the codes.
Old 04-12-2013, 09:59 AM   #6
toy4to
My Ride: 2004 M3 AA Gen6 1.5
They are very easy to change. You have to remove them in order to change your spark plugs (if you plan to do that at the same time). Buy the bosch ignition coils off Amazon, bosch part 00124. Should cost around $25 a piece.
But as others mentioned, get the codes read. If it points to misfire, then change the ignition coils with what I mentioned above.
toy4to is offline   Reply With Quote
Old 04-12-2013, 12:50 PM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
If you were a mechanic you would know to scan the car for codes first before replace stuff that doesn't need to be...
Old 04-12-2013, 05:55 PM   #8
mzeed
My Ride: 05 M3 ZCP no sunroof
The hardest part is the wait for the parts to arrive.....
and change the plugs while you are there....Codes are usually 300 along with 301 to 306 depicting which cylinder(s) from front to rear is/are causing the SES light to come on....
highly advise to change all 6 of the coils and plugs beyond 60K as opposed to just the bad one(s)
mzeed is offline   Reply With Quote
Old 04-12-2013, 06:41 PM   #9
tinman831
My Ride: M3
Damn where was this post when I spent $75 for a BMW one?
tinman831 is offline   Reply With Quote
