///M3 Forum
Old 02-10-2009, 09:45 AM   #21
///M3 Power
My Ride: '05 JB/IR M3 SMG ZCP
If it's the clutch going out you would feel slippage through each gear. Does the car pull good and hard as you are moving up the gears? Tach should not move way faster than the speed if I remember correctly which would indicate a slipping clutch.
I to have a bit of a "judder" when taking of and if I gently push the gas or give more aggressive gas it does not do it. It only happens in a certain position and if it is happening I can apply more gas and it stops the judder.
This should be a software update I would think.
///M3 Power is offline   Reply With Quote
Old 02-10-2009, 03:19 PM   #22
persian451
My Ride: Z4M Roadster
it's because you need to give a little gas when at a stop. The car is actual in neutral at a complete stop, despite saying '1' gear.
if you give a little bit of gas before giving more throttle, you shouldnt experience this anymore
persian451 is offline   Reply With Quote
Old 02-10-2009, 03:48 PM   #23
NorthJersey 3er
NorthJersey 3er's Avatar
My Ride: '03 M3 / '72 2002tii
Originally Posted by NY Z Pilot View Post
launch control? we have this?
yah, DSC off...S6 will be revealed then hold the shifter up in the ( - ) and hold the rev
Matt
co-founder of
euro techniks
NorthJersey 3er is offline   Reply With Quote
Old 02-10-2009, 11:41 PM   #24
NY Z Pilot
My Ride: 05' M3 SMG
wow this is new to me... I know S6 is the bar to the right that pops up... explain the rest tho whats the ( - ) all about?
04' Silverstone 350Z 6MT - SOLD!!!
NY Z Pilot is offline   Reply With Quote
Old 02-10-2009, 11:45 PM   #25
AllwaysLow
My Ride: 2005 CB SMG M3
23 seconds in....
AllwaysLow is offline   Reply With Quote
Old 02-11-2009, 01:48 AM   #26
realcompm3
My Ride: Your wife
yeah i know what you mean. i hate when im on a hill, and some idiot is riding my ass.
05 330CI ZHP
/// 11 M3 E92 ZCP- Sold
06 M3 ZCP Sold
realcompm3 is offline   Reply With Quote
Old 02-11-2009, 02:01 AM   #27
persian451
yea.. i feel ya on that.. but at least we got the gradient assist
Old 02-11-2009, 02:11 AM   #28
realcompm3
My Ride: Your wife
haha yeah. nice car man^ i see you got a clear bra. where did you get that?
05 330CI ZHP
06 M3 ZCP Sold
Old 02-11-2009, 09:47 AM   #29
NY Z Pilot
My Ride: 05' M3 SMG
great video, thanks man!
Old 02-12-2009, 12:47 AM   #30
persian451
thank you
alot of people do the clear bra now. it's pretty much clear vinyl with sun protection. it gets pricey for the front end (bumper, partial hood, mirrors) when I did it (2) years ago, it was like around $500-600... but its worth not having the rock chips
Old 02-12-2009, 01:01 AM   #31
realcompm3
My Ride: Your wife
thank you
oh yeah its def worth it. do you by any chance remember who did it for you?
05 330CI ZHP
06 M3 ZCP Sold
Old 02-16-2009, 11:16 AM   #32
BMW Loe
My Ride: is dirty
Mine only does this when I accelerate from a stop position at light throttle. Heavier throttle positions and it's a smooth operator. It does this more then its colder outside, but as it gets above freezing, it dissapears. It's not a clutch slip issue, it shifts and holds fine in all gears and will sure bang shifts in S6, it's just that initial acceleration and it only happens in first gear up between 1,000-1,800rpm, but not in second gear. This might also be called clutch chatter.
I've disconnected the MAF to see if thats a possible cause, nope. I have new spark plugs, ignition coils, fuel pump, fuel filter, air filter. I've tried the SMG reset, so I guess my only solution would be to check for a software update from the dealer.
E92 335i 6spd
BMS JB4 stg 3, BMS DCI, CM methanol injection
04 M3 sold
03 330Ci sold
BMW Loe is offline   Reply With Quote
Old 02-18-2009, 07:40 PM   #33
DJSMG22
My Ride: 325i
What do u mean by this? and how harsh is the jerk, my clutch, hydraulic unit and flywheel just went and they say it"ll cost 8700 to replace..not normal right?
DJSMG22 is offline   Reply With Quote
Old 11-04-2009, 10:31 AM   #34
mtechmike
My Ride: 2004 m3 smg cab
Send a message via AIM to mtechmike
hey, i have an smg with about 55k and experience the same judder symptoms in 1st gear. It isn't the bucking bronco type of jerk which is a separate feeling where the car just wants to take off. So far i've reset the smg computer by holding in the paddles for 5 secs while driving above 50mph and putting the gear in neutral, i've recently had the computer remapped at the dealer. I've tried engaging the gas slowly from a stop, slamming the gas from a stop, and letting the car warm up for 20 minutes and i still get slippage. I thought for sure it was the clutch but one member said it would happen through all the gears if that was the case. I'm gonna clean my maf sensor today with crc cleaner and hope that works. If you correct the problem please let me know what you did that worked. Thanks, Mike
mtechmike is offline   Reply With Quote
Old 11-05-2009, 05:10 AM   #35
ollie2185
My Ride: 2003 M3
Originally Posted by vicz84 View Post
my m3 does the same, judders sometimes in first gear and even second sometimes, been told that a software upgrade can sort this out, hope its not the clutch on the way out, mine has done 62000 miles and have been told that clutches dont wear out that quick in a smg unless you use launch control, which i dont.
I'm exactly same miles and exactly same problem. (also dont launch control) Seems to improve as the engine comes up to temperature. I had just put it down to that.
Dont think its a clutch slip. Hope its not anyway.
ollie2185 is offline   Reply With Quote
Old 06-01-2010, 08:50 AM   #36
HarryMarkCS
My Ride: 05 M3CS
Same problem here, the car is 2005 SMG cs.....its starting to piss me off, been to the dealers twice already and no joy...
ive reset the smg....no joy
Its worse on hill starts...but dont think its clutch as it doesnt happen up the gears
HarryMarkCS is offline   Reply With Quote
Old 04-11-2013, 01:40 AM   #37
ZCP14
My Ride: 2006 M3
Reviving this one.... I have 88k miles and Carmax replaced my SMG pump, and clutch changed about 10 months ago. It shudders/chadders in 1st and 2nd gear starts about 4 out of 5 starts from standstill. It's way worst on hills. After take off all else works smooth. S5 setting seems to decrease it 1 out of 5 starts.
Mass air is clean. Airbox has a little bit of oil in it, was told its normal. Service 2 was done in Jan.
facepalm:
Please let me know what's worked for you guys
ZCP14 is offline   Reply With Quote
Old 04-11-2013, 11:53 AM   #38
///M Powerd
My Ride: 2003.5 M3 Coupe
When I changed my diff fluid from mystery brand (from PO) to OEM +FM it cleared this issue up for me.
///M Powerd is offline   Reply With Quote
Old 04-11-2013, 06:37 PM   #39
ZCP14
My Ride: 2006 M3
I unplugged the battery overnight and that seemed to put it back to learning mode. But it's still there, just less noticeable. I have an appt at Pacific BMW later this month. I hope they can diagnose it once and for all.
If you guys know of anything else please let me know.
Old 04-12-2013, 09:51 PM   #40
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
Clutch relearn / teach-in. Should have been performed when the pump was replaced. If it was and didn't adjust properly, the shop should have done it again.
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
