Old 02-07-2009, 08:58 PM   #1
alypathan
My Ride: 330Ci
Question Purpose of differential?
what is the purpose or in other words what does a differential do in a bmw? because i need to get a rear differential changed ... does it make any difference if i get it changed or no ?
alypathan is offline   Reply With Quote
Old 02-07-2009, 09:20 PM   #2
SpeedDemon
My Ride: E92M3 E46ZHP Golf7R
Next time you ask a question you may want to try to compose it a little better (so it makes sense)...
What exactly are you asking? Did someone or your mechanic tell you that your differential is going bad? Or are you just asking if it is possible to swap out your original differential for a "better" one?
SpeedDemon is offline   Reply With Quote
Old 02-07-2009, 09:34 PM   #3
davidwarren
Halfway to 2L
davidwarren's Avatar
My Ride: 2010 335i
http://tinyurl.com/afmq47
You down with UCC? Ya you know me!
sowing the seeds of jiggery pokery
davidwarren is offline   Reply With Quote
Old 02-07-2009, 09:41 PM   #4
SpeedDemon
Old 02-07-2009, 10:29 PM   #5
kpeng
Banned User
My Ride: E46 330 and E30 325
Is this a serious question?
kpeng is offline   Reply With Quote
Old 02-07-2009, 10:39 PM   #6
DrM3
My Ride: 05 M3
lmfaoooooooo epic
David
DrM3 is offline   Reply With Quote
Old 02-07-2009, 11:05 PM   #7
IFX
My Ride: M156
Dying when I clicked the link. Had to do it twice.
IFX is offline   Reply With Quote
Old 02-08-2009, 09:23 AM   #8
bernstem
My Ride: 2000 328i
I have never seen that before. Awesome.
To answer the OP. The differential distributes power from the driveshaft to the rear wheels. It also allows the rear wheels to turn at different speeds to prevent the tires from scrubbing while you are turning. The wikipedia article looks pretty good for more info.
Whether it needs to be changed or not depends on what you want or need. If it is failing, it needs to be replaced. If it is not failing and you want a better/newer one that is a rather complex answer that is best served by searching for limited slip differential and differential on this site.
good luck
bernstem is offline   Reply With Quote
