Old 02-08-2009, 06:03 PM   #1
Custom3
My Ride: HellRot 330CI
Valve cover removed and white cream inside *Photos*
It all started when I noticed a white creamy substance on my oil cap a few months ago....First thing I did was get on e46fanatics.com and use the search feature to find answers...within a matter of seconds I have found a few threads about the white creamy gunk and learned what it was and how it might have gotten there.
For those who don't know its actually condensastion that builds up in the engine (aka water) when you use the car in cold weather and use it for short trips....It can come from different places...damaged oil cap seal...bad valve cover gasket...and many other places.
In my case if was a bad valve cover gasket....i had 80k miles so it was time to change it.
I was expecting the worse...I figured I would see oil gunk every were so before I opened the valve cover I poured a bottle of Gunk Remover and I let it run for about 10 minutes...I don't know if that bottle helped clean anything but my engine was very clean...no gunk whats so ever...except for the creamy oil under the valve cover...but everything else was VERY clean....thank you Royal Purple 5W-40!! thats all I used since the first day I got the car.
On with the pics......fyi...taken with a crappy phone camera...sorry
you can see the oil cap on the bottom right
even inside here....
Clean inside...
Old 02-08-2009, 06:06 PM   #2
00bmw323
My Ride: 00 323/91 integra RS
moisture?
-Jorge
All low no go
00bmw323 is offline   Reply With Quote
Old 02-08-2009, 06:06 PM   #3
Custom3
yes
Originally Posted by 00bmw323 View Post
moisture?
Old 02-08-2009, 06:09 PM   #4
NY Z Pilot
My Ride: 05' M3 SMG
cream...
04' Silverstone 350Z 6MT - SOLD!!!
NY Z Pilot is offline   Reply With Quote
Old 02-08-2009, 07:09 PM   #5
TiAg2247
My Ride: E39 M5 | E55 AMG
Someone skeeted inside your engine.
Imola Red M5 | Imola Red Interior
GT Exhaust, Custom BC Coilovers, 19x10 + 19x11 Rial Dayonta Race, Michelin PSS
Daily: 335i M-Sport Alpine White / Coral Red
Too many mods
Past:
'04 E55 AMG
'01 330Ci Titanium Silver / Coral Red
'96 328i Jet Black / Black
TiAg2247 is offline   Reply With Quote
Old 02-08-2009, 07:46 PM   #6
crazyafghanguy
My Ride: E46 M3
01 M3
Black/Black 6 Speed
Style 95
Amber All Around
Street Edge Coilovers
ZCP Brake Upgrade
LED Tail Lights
crazyafghanguy is offline   Reply With Quote
Old 02-08-2009, 07:53 PM   #7
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
i've seen this in ALOT of cars i did vcgs on
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 02-08-2009, 09:36 PM   #8
tradingflare
My Ride: needs a mechanic
From what I've read, that creamy gunk is from driving the car on short trips and not warming up to fully operating temperature...hence, the "moisture" not burning off. But, that's just what I've read.
* I have no good pictures of my car *
**Ignore everything that's written in my post above *
***I can't change my own oil, yet for some reason, my time spent on this forum has taught me about nearly every mechanical part on the car. I can talk to you about belts/pulleys, alternators, battery, Secondary Air Pumps, belt tensioners, you name it. Yet, I have no tools or mechanical abilities**
****Again, ignore my posts above...idiot speaking****
tradingflare is offline   Reply With Quote
Old 02-08-2009, 09:41 PM   #9
inlinesicks
My Ride: E46, Jeep, Subaru
Creampie surprise!
inlinesicks is offline   Reply With Quote
Old 02-08-2009, 09:45 PM   #10
Custom3
yes you are correct...a bad valve cover gasket just makes things worse...and a bad seal on a oil cap as well.
Old 02-08-2009, 09:51 PM   #11
apollotrance1
My Ride: '02 330i, '05 GSXR1k
water in the motor oil, not a good sign. You also might have a bad head gasket. Also check your water/coolant level, could be leaking into your motor.
apollotrance1 is offline   Reply With Quote
Old 02-08-2009, 09:56 PM   #12
EXNoodle
My Ride: 330CI
Send a message via AIM to EXNoodle
Yo, i have the same thing. Its on the inside of the oil fill cover as well. checked the coolent, no signs of oil... weird... anyone else have this?
Gray 2004 330CI ZHP
EXNoodle is offline   Reply With Quote
Old 02-08-2009, 10:06 PM   #13
wolfhead
My Ride: BMW 330ci
It could just be moisture... im gonna do a vanos repair soon, and also do my valve cover gasket aswell. Its probably the same on mine since i had just the same as you shown on picture two.
I have a oil consumption so ive been told my ccv could be it.. so i changed that.. and that was full that yellow cream. They sad that yellow stuff also was symptoms of a broken ccv. And bmw said i didnt need to worry.
If you dont use any coolant i would be so afraid. But i recommend to change your ccv.. i havent seen any of that yellow cream since ive changed it.
wolfhead is offline   Reply With Quote
Old 02-08-2009, 10:42 PM   #14
mkodama
mkodama's Avatar
Correct. My car developed a severe case of this oily cream from it being moved around the repair shop, like 50 feet and then turned off.
Nope, this is completely normal if you drive your car short distances or don't let it get to temperature for a long enough time.
I happens when you drive short distances. It's a lot more more common in the winter when it's colder outside. A good example is the cold glass of water on a hot day and it forms condensation on the outside. Same with your engine except it forms on the inside of places like your valve cover.
My car's creamy goodness which was much worse
The only cure is to let your car warm up fully and to not drive it like a pansy.
Old 02-08-2009, 10:44 PM   #15
Franxta
My Ride: 325ci
Send a message via AIM to Franxta
-Frankie
"But the speed was power, and the speed was joy, and the speed was pure beauty."
--Jonathan Livingston Seagull
Franxta is offline   Reply With Quote
Old 02-09-2009, 12:07 AM   #16
Raine
My Ride: e39
Oops pow suprise!
Raine is offline   Reply With Quote
Old 02-09-2009, 12:21 AM   #17
Polish_328Ci
My Ride: M3
Haha wtf did you guys do? lol.. Luckly I never found anything when I replaced my vanos seals
Polish_328Ci is offline   Reply With Quote
Old 02-09-2009, 12:22 AM   #18
djnekkon
My Ride: MB3ci & z33 HR
Mine used to be parked in my driveway for days. Now I'm beating the **** out of it every weekend. I did not know it could kill my engine. I hope it is not too late.
Old 02-09-2009, 01:57 AM   #19
TxTorqueMade
My Ride: 330i
Send a message via Yahoo to TxTorqueMade
On second look, it resembles a Frappicino from Starbucks... next time, get decaf....
TxTorqueMade is offline   Reply With Quote
Old 02-09-2009, 08:07 AM   #20
vintagegz
My Ride: 2005 330ci/2004 330i
that plastic valve / camshaft cover never warms up like metal ones on short trips, keeps everything cool so moisture can collect on it.
vintagegz is offline   Reply With Quote
