Old 02-09-2009, 05:07 PM   #1
neil1138
Exclamation Every problem I've had, everything that has gone wrong, has built up to this moment..
This is a semi-long read so... just read it please
I have searched the forums day after day searching for the solutions to many of my car's problems and I have yet to find the answers. My car started out with the dreaded VANOS seals then built up to the Subframe tear. I have been through many common problems, even some bizzare problems nobody knows the answer to. But this last problem has beaten me and I'm tired of it.
http://forum.e46fanatics.com/showthr...742&highlight=
I also have this problem when i am coming to a stop, my RPMs dip almost to 500 RPMs and come back up to idle. Also between shifting into drive from park or from park into reverse, my idle drops... again, i think its transmission related. I have a low idle and its beyond me on how to fix it. I've cleaned the adjuster unit, replaced the intake elbow, cleaned the ICV, replaced the VANOS seals, cleaned the MAF, had the entire car vacuum leak tested... no signs of any possible solutions.
One of my bmw guru friends thinks it might be torque converter related but I have no codes for it. I dont have any SES codes or anything. But i have come to the conclusion that my 50 mph hesitation and this annoying problem are caused by the failure automatic transmission that my car bestowed to me. Also, you guys are familiar with the no reverse problem?? well my car does that sometimes but i just push it out and drive it around and it fixes itself. Its been happening on and off for years. Its not the reverse drum breaking but its something else rather, a solenoid of sorts.
I just am tired of all the problems caused by my autotragic and I have decided to make the switch to a manual. I have found this thread, what else do i need?
http://forum.e46fanatics.com/showthr...diy+speed+swap
I am not sure if I can undertake this. I might have my close indy mechanic do it for me. He's a family friend and has my back so the labor will be reasonable. I also might ask a friend if he wants to help me, im not sure yet...
One question, is there any advantage to the 6 speed? I'm thinking just the 5 speed will do, cause I dont need an overdrive gear. What else should I have done on the car while I'm at it? I think I'm going to have all the O2 and cam sensors replaced. We will see. Another question, in order to do the swap, the engine has to come out right? Or can it be done while in the car? thanks guys, ill keep you posted.
btw, please don't tell me to sell the car and just buy a manual or something. This car is my baby and i have put a lot of money into restoring it. I'm not selling it because after this potential fix, the car will be virtually brand new other than the major engine components.
neil1138 is offline   Reply With Quote
Old 02-09-2009, 05:15 PM   #2
TxTorqueMade
My Ride: 330i
Send a message via Yahoo to TxTorqueMade
1st!!
Good luck with it. Id go 6speed, just cause, but its all good. We all with slushboxes ought to follow you for sure.
TxTorqueMade is offline   Reply With Quote
Old 02-09-2009, 05:22 PM   #3
mav909
My Ride: Rx8 231
Send a message via MSN to mav909
No idea with the rev drops, i remember i had a similar problem with my dirt bike after i replaced the top end, it was because of the new carb not letting enough fuel in at idle. All i did was fiddle with some screws to fix it i wish our cars were as simple.
also wise move with making the swap to manual.
mav909 is offline   Reply With Quote
Old 02-09-2009, 05:36 PM   #4
TxTorqueMade
My Ride: 330i
I assume you put the Turner kit in already for the subframe tear?
Did you replace the ATF and filter already? How did this end up being a tranny problem? Not sure Im feeling that. I would expect that throwing a MT swap at the problem cant have any effect but a benefit overall, but ... IS it necessary? Man, kinda having similar 500 rpms idle issues, but a trans???
Hit me back.. with why/how ok
Old 02-09-2009, 06:04 PM   #5
neil1138
Well, the rpm dip is related because when the car is at a stop, the RPMs are low but as i let off the brake and the car starts to move, the RPMs start to rise. Also if I come to a stop really fast, my RPMs dip so much it feels like the car is about to die. I think its related to the torque converter partially locked up when its not supposed to be.
And changing the fluid is not really an option for me because I'm at 135,000 miles and that's just asking for trouble. I picked up the car at 115,000 and I don't know if the previous owner ever changed the fluid...
In reality... I am just coming up with reasons to switch to a 5 speed. I'm getting bored of my auto and i can tell that it's getting worn. The shifts aren't as smooth as they used to be and the no reverse problem is really getting to be a hassle. I just need to be rid of these problems and make the switch.
Old 02-09-2009, 06:16 PM   #6
wwjbd24
My Ride: e92 JB+ 335i
i dont even have a manual, but like TxTorqueMade said, why not 6?
wwjbd24 is offline   Reply With Quote
Old 02-09-2009, 06:34 PM   #7
neil1138
why not 6? Because I don't do that much highway driving to where I would need an overdrive gear. And to my understanding, it costs a lot more to obtain a 6 speed vs a 5 speed transmission.
Old 02-12-2009, 10:57 PM   #8
neil1138
Well I have the parts list and a firm grasp on how the electronics side of the swap goes. I'm off to the BMW salvage yard tomorrow to find a manual E46 to grab some parts from. I'll take some pictures and let you guys know how it goes. Expect this entire swap to be done within 3 weeks. I will make a wicked DIY after I'm done and it will compliment some of the other fantastic DIYs already on the board. Special thanks to all the members who got me started on the journey, you guys know who you are. Will update tomorrow.
This is going to be a fun one....
Old 02-12-2009, 11:02 PM   #9
tradingflare
My Ride: needs a mechanic
are you the dude with the F'd up cluster from a while back?
* I have no good pictures of my car *
**Ignore everything that's written in my post above *
***I can't change my own oil, yet for some reason, my time spent on this forum has taught me about nearly every mechanical part on the car. I can talk to you about belts/pulleys, alternators, battery, Secondary Air Pumps, belt tensioners, you name it. Yet, I have no tools or mechanical abilities**
****Again, ignore my posts above...idiot speaking****
tradingflare is offline   Reply With Quote
Old 02-12-2009, 11:03 PM   #10
//TRD power
My Ride: 3.0 | 200hp | 214trq
Goodluck with the swap, hope all goes well!
//TRD power is offline   Reply With Quote
Old 02-12-2009, 11:08 PM   #11
neil1138
yes
Hey, that cluster thing was freaking awesome. Now im chillin at 6250 miles thanks to that freak accident. Its a good thing, cause wayyy down the line when I even think about selling my car, it will only have like 50k miles for a car thats 20 years old.
And it will be perfect mechanically! And if I ever do decide that i want to go back to 621,372 miles, all I have to do is reset the cluster... then sell my car to some nerd on roundel! haha
Old 02-16-2009, 07:19 PM   #12
neil1138
I just bought the manual transmission today and all of you guys better be prepared for one wicked DIY thread to be paired with Ivegotissues666's DIY.
Old 02-16-2009, 07:37 PM   #13
tradingflare
^ Good luck man...I seriously hope this is all worth it. If it was me, I would've dumped the car at 621,000 miles...well, the cluster issue, that is. I'm cheering for ya bro!
Old 02-16-2009, 08:38 PM   #14
i0kr1sol
My Ride: 330ci
Good luck on the swap bro ! Ive just done this swap 3 weeks ago, and it feels like a new car, period.
One advantage of 6speed is when you drive on the highways, your rpm's will be lower. But like you said, you don't drive in the highways much so 5speed would be okay.
You should think about upgrading the parts if you will do so down the road anyways. Like lightweight flywheel, shortshift kit, stainless steel clutch line, etc.
i0kr1sol is offline   Reply With Quote
Old 02-16-2009, 08:55 PM   #15
TxTorqueMade
My Ride: 330i
Dayum...sorry to be so late getting back. Been working on my pool not the Bimmer last few days.
Looks like a nice tranny! SS line for sure and why NOT go on and do a short shifter now?!!
Good for you Neil. We will be lookin for the DIY No doubt.
Old 02-16-2009, 09:16 PM   #16
neil1138
Yeah I'm getting the UUC SS Clutch line and the UUC EVO3 short shift. I have written most of the DIY already, I just need to take some more pictures... Well a lot of pictures.
Old 02-17-2009, 01:20 AM   #17
jott5555
My Ride: 01 330ci
ya know i know its off topic.. but what your describing really really sounds like a vacuum leak.. ya know i was thinking.. most of the e46's have the shut off flap in the tail pipe at the very back of the car.. there could be somewhere along the line that has a leak.. considering you have checked all the rest of the vac lines. but if you pressure tested the engine and didn't hear any leaking.. that is at the back of the car where you wouldn't hear with your head in the engine bay
just an idea..
jott5555 is offline   Reply With Quote
Old 02-19-2009, 01:50 PM   #18
neil1138
Haha yeah, my car doesn't have an exhaust flap. I think that came on newer 330s and such.
Old 02-19-2009, 02:13 PM   #19
n2Bimmer
My Ride: Loves Corners
dam, good luck bro, your DIYing it?
Old 02-19-2009, 03:29 PM   #20
dreamdrivedrift
My Ride: 99 M3 & 95 325i
Send a message via AIM to dreamdrivedrift
have fun!
Chris
dreamdrivedrift is offline   Reply With Quote
bmw, diy, hesitation, manual, swap
