Old 02-10-2009, 09:34 PM   #1
guest041115
Banned User
Question about wiring AE's
Ok so i have the wire harness and i was reading through a walkthrough and they show this picture:
where they connect the angel eye to the harness. But i see the angel eye wires go back into another connector there, where as my angel eyes only have 2 wires coming from them. So would i just connect 2 wires to each point on the harness in that picture?
if that made any sence.
guest041115 is offline   Reply With Quote
Old 02-10-2009, 09:44 PM   #2
guest041115
Banned User
to clarify, how do i connect these 4 wires (2 black, 2 white):
to this:
ignore my chem, i got a midterm on friday
Old 02-10-2009, 10:10 PM   #3
Spdu4ia
My Ride: changes too much
white is for the positive side and black is for ground on the angel eyes and Red is pos and brown is the ground in your hand.
-Travis
Spdu4ia is offline   Reply With Quote
Old 02-10-2009, 10:16 PM   #4
dreamdrivedrift
My Ride: 99 M3 & 95 325i
Send a message via AIM to dreamdrivedrift
How do you hook the actual wires to the connectors? Is it better just to cut the connectors off, splice the two white wires together, splice the two black wires together, and solder the white to the red, and the black to the brown?
Chris
dreamdrivedrift is offline   Reply With Quote
Old 02-10-2009, 10:19 PM   #5
Spdu4ia
thats what I would do... all your doing is wiring them together and then powering them with one wire source.
-Travis
Old 02-10-2009, 10:28 PM   #6
guest041115
Banned User
thank you, we just dont wanna mess it up!
Old 02-10-2009, 10:35 PM   #7
Spdu4ia
good luck. if it smells or smokes... you did it wrong
Don't worry you'll be fine... its like coloring by numbers. Only with wires... and colors... well... you get the point.
-Travis
